Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Sounds like marbles or ice dropping in refrigerator (not freezer side). Looking into vent in back upper left corner, noise seems to coincide with a flap going up and down. The flap movement is being interferred with I believe. Our whirlpool is about one month old and this just started today.
  • 4,070 Answers
The flap is what open and closes to allow more or less cold air in from the freezer. There could be ice buildup inside the freezer causing this or a mechanical noise of the flap and motor running. See if you can see it from the freezer side of the vent.
Posted on May 26, 2011
My whirlpool gold two sided refrigerator, model #6D5RHAXNB00, the refrigerator side is not getting cold enough! I can't feel any cool air coming through the vent on the left upper corner.
your freezer may be iced up not allowing the cold air from the freezer to blow into the frige .you may see a ice build up on the back wall of the freezer.an ice build up can also stop the fan.if you can leave the unit off for 12 hrs or longer to thaw and that helps after restarting you may need to change the defrost timer ,defrost heater or both.a faster way is to remove the covers if you can do that.
Jan 15, 2013 | Refrigerators
Kenmore side by side model 106.5xx. The ice bucket has ice but the dispenser on the door will not release the ice. I hear a click but nothing happens. I removed all of the ice from the bucket and the...
The freezer part is working but the refrigerator part is leaking water from the left side upper corner .there is like a vent from, where the water is leaking and the refrigerator side is not cooling any hint or advice will be appreciated thanks
Sep 19, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The defrost cycle seems to stay on too long-ice already made will start melting & then refreeze into 1 big chunk. Eventually the "melt" will build up in the bottom of the freezer & will eventually...
if think your defrost cycle is ok . there is a defrost terminator that controls the heater at 50 deg in the back of freezer , the problem is the water delivery tube is iceing oven and causing water to run down the back of freezer wall . change the tube to newer style. it will be open on the top side . they work better. and the water valve may be leaking through. and may have to be changed .. ,,
Jul 29, 2010 | Refrigerators
Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Jun 12, 2010 | Refrigerators
Ice build up on a corner of the coil.
could be low on freon or insuffencient compressor...
Jun 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
I have a GE GSS25WGMD BB Fridge. I have already replaced the Defrost Heater and Freezer Thermostat. The lower sections of the fridge and freezer are very cold. The ice maker will not produce ice and the...
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Kenmore Bottom Freezer Ice maker installation
in the bottom style freezer the plug will be in the upper left hand corner of back of the freezer ,,, may have a cover plate over it but thats where it is and should be a couple small holes with plugs on the upper left hand side for the mounting screws / larry
Dec 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Kennmore model 253
Unplug the unit, open the freezer door and look through the vents at the bottom of the back wall. With enough light you should see the alluminum coil through the vents. If there is ice/frost in the vents your coils are frozen up. Remove the cover on the inside back wall of the freezer you may need to remove the ice maker as well if you have one it just plugs into the back wall there is also a plug behind the cover to the back upper left corner. Once the cove is out of the way use a hair dryer to defrost the coils or leave the unit unpluged for a while. After all the ice is gone reinstall the cover and turn the unit on it will probably work for 3-10 days and then the process must be repaeted again. I replaced the defrost thermostat on mine 2 weeks ago and all is good so far. The defrost thermostat is a little round device that snaps onto the small copper line in the upper right corner behind back cover it has 2 blue wires and cost's about $20.
Hope this helps
Oct 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool Side by Side Refrigerator
hi- there might be a switch inside freezer to turn the ice maker on and off- it will be located on the upper left corner-
Nov 22, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
116 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
