Question about Haier Heating & Cooling
I have a Haier Commercial Cool air conditioner, model CPRD12XC7, 12,000 BTU that has 2 hoses off the back and is made to be vented thru a window. I want to install it in a closet with no windows. Can I vent both hoses thru the wall and are both hoses exhaust or is one intake and one exhaust?? Please advise. Thanks Mark Bushman
    Brigadier General:
  • 4,736 Answers
Mark, the two hoses serve different functions (Fresh Air Intake & Hot Air Exhaust). Therefore, they would have to remain separate. Also, Haier does not recommend extending the length of the hoses, to accommodate a specific change in installation. And yes, they can be vented through a wall to the outside. But, you would need to use something similar to a clothes dryer vent termination on the outside. Most exterior dryer vent terminations have insect screening and a flap door that opens when air from the dryer pushes it open. This would be fine for the exhaust hose, but not the Air Intake Hose. I guess if you could carefully remove the flap door. it could be used on the Air Intake hose. Also, keep in mind that the unit requires a minimum of one foot air space clearance off the back of the unit, for proper air circulation around the unit. If clothes will be hanging in this closet, that may present an air circulation issue.
Hope this helped you, please let me know. Thanks.
Posted on May 26, 2011
Remove exhaust hose
U need that hose to direct the warm air outside the area to be cooled. If you remove it, the hot exhaust will stay in the room being cooled and negate the cold air being directed into the room.
That is why regular room AC units are mounted on window sill. Cold air in, hot air out.
Oct 08, 2015 | Haier Commercial Cool 8,000 BTU Portable...
Where do I check the freon gas level in my Haier CPRB08XCJ
There are generally no fitting to connect to the sealed systems of portable air conditioners. You can buy a 'saddle valve' that will pierce the suction side and allow you to check low side pressure, but they will allow a very slow leak in most cases.
It likely uses R134a instead of Freon.
Jul 23, 2014 | Haier Commercial Cool 8,000 BTU Portable...
My commercial cool unit cpro7xc9 leaks from the port in back .should there be a plug in the port
that port is for a hose drain use, if not using a drain hose the port must be plugged
Jul 08, 2014 | Haier Commercial Cool 8,000 BTU Portable...
Fan is making rubbing noise
Time to have an expert look at it as it might be a fan about to fail or something worse.
Aug 30, 2012 | Haier 8,000-BTU Commercial Cool Portable...
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
We just purchased a Haier Commercial Cool 12000 BTU portable air conditioner and the window exhaust slider is too short for our window...how can we correctly add on to the slider? We are short about 10...
At one time, Haier had an optional window kit for taller or wider windows. Contact their Product Support 1-877-337-363, to see if it's still available.
Jul 09, 2011 | Heating & Cooling
Haier 5000 btu thru wall or window vents on top and both sides how far out the window should it be?
just a few inches, main thing is that its slightly tilted at the back to drain the condensated water outside
Jul 23, 2009 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
232 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
