Question about EZ Dupe Publishing Plant 100 Disc DVD/CD Autopublisher Burner
After installation, command prompt still reads " device not ready". (printer) what should be done to get this activated an ready to go?
    President:
  • 3,278 Answers
Hello.
I'm unclear whether you are referring to a printer problem or the EZ Dupe Publishing Plant burner.
If a printer issue and connected by USB cable, try reinstalling your printer:
Note: Here's how to delete a printer icon in Windows 7:
1. Open Printers by clicking the Start button, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
2. Right-click the printer that you want to remove, and then click Delete.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. Install the printer driver.
If still a problem, either your USB port on your PC, or the USB printer cable is probably faulty.
Hope this helps.
Posted on May 26, 2011
Naka online yung printer pero pag nag na click na yung PRiNT . nka "" OFFLiNE "" ?
You may need to re-install the printer drivers; but before you do that, first go to the command prompt:
(1a) For Windows XP: Click Start --> Run --> Type CMD --> Press Enter
(1b) For Vista or 7, go to Start and type CMD directly in the Search box
RIght-click on the cmd icon that appears under the Programs list and select rictutero_13.jpg as seen above (If a User Account Control window comes up, click YES)
(2) In the command prompt that opens up, type NET STOP SPOOLER and press Enter
(3) Wait for the command to finish, then type NET START SPOOLER and press Enter
(4) After the command completes, you can retry printing. If it still fails, then you will have to re-install the printer drivers.
(5) You'll have to insert the printer drivers disc: it usually runs the installation immediately & these applications can detect if you already have it installed. You will be prompted to remove the software; after which you can repeat the process (step 5) to re-install the application and try printing again.
If all these fail, you would have to test the printer on a different computer to see if it exhibits the same symptoms. If they do, then the printer will have to be checked for possible repair/replacement. If not then there's something wrong with the operating system on YOUR computer and it will have to be checked separately.
Aug 14, 2011 | Computers & Internet
Tip
Enable / Disable the Local (Hidden) Administrator Account in Windows 7
Ways to Enable / Disable the Built-In Windows 7 Admin Account Many people familiar with prior versions of Windows are curious what happened to the Local Administrator account that was always created by default. Does this account still exist, and how can you access it?<br /> Recently I ran into an awkward situation where after disjoining a Windows 7 client machine from the domain, I was unable to log in to the computer. This was not because I had forgotten the local administrator password, but because the local administrator account was disabled (which is the default behavior in Windows 7). Like in Windows Vista, in Windows 7 the built-in Administrator's account is disabled by default. Furthermore, this account is not associated with any password. After doing some research, I found the following procedure that worked really well.<br /> <a href="http://www.windowspasswordsrecovery.com/enable-disable-local-administrator-account-win7.htm">Enable Built-in Administrator Account</a><br /> Basically there are 4 ways in order to activate the account:<br /> A) Command Prompt To enable the built-in Administrator's account by using the Command Prompt please follow these steps:<br /> 1. First you'll need to open a command prompt in administrator mode by right-clicking and choosing "Run as administrator" (or use the Ctrl+Shift+Enter shortcut from the search box)<br /> <img src="run-command-prompt-as-administrator.jpg" /> 2. After that you only need to enter the simple command below to activate it.<br /> <b><i>net user administrator /active:yes</i></b><br /> <img src="enable-hidden-administrator-account.png" /> 3. You should see a message that the command completed successfully. Log out, and you'll now see the Administrator account as a choice.<br /> <img src="built-in-windows-7-administrator-account.png" /> You'll note that there's no password for this account, so if you want to leave it enabled you should change the password.<br /> B) Local Security Policy Another way of activating the administrator account in Windows 7 is via Local Security Policy.<br /> 1. Type secpol.msc in the search bar and hit enter.<br /> <img src="secpol.png" /> 2. After the Local Security Policy pops up, navigate to Local Policies-&gt; Security Options where you can see an entry that reads Accounts: Administrator account. Double click the entry to enable it.<br /> <img src="local-security-policy.png" /><br /> <img src="administrator-account-status.png" /> C) Using the Local Users and Groups Snap-in To enable the built-in Administrator's account by using the Local Users and Groups snap-in please follow these steps:<br /> 1. Open Local Users and Groups. You can do so by typing lusrmgr.msc in the Start search box or in the Run command and pressing ENTER. Or, you could open Computer Management by right-clicking Computer in the Start menu and selecting Manage.<br /> 2. Expand System Tools &gt; Local Users and Groups &gt; Users.<br /> 3. Right-click the Administrator account and select "Set Password".<br /> 4. In the"Set Password for Administrator" click "Proceed".<br /> 5. In the"Set Password for Administrator" enter the Administrator's desired password twice, and click "Ok".<br /> 6. Next, enable the Administrator's account. Right-click the Administrator's account and select "Properties".<br /> 7. Un-chek the "Account is disabled" check-box. Click on the "Ok" button.<br /> Administrator's account is now enabled and configured with a password.<br /> D) During the Installation Process There is a 3rd method which advanced users can use. This method can be used during the installation process itself.<br /> 1. During the installation, after being prompted to configure the new user account, you will be able to set the new account's password.<br /> 2. At that phase, press SHIFT and F10 keys together. A Command Prompt window will appear.<br /> 3. In the Command Prompt window, type:<br /> <b><i>net user</i></b><br /> Note how the Administrator account is there, yet the new user account has not been yet created.<br /> 4. To set the Administrator's account password:<br /> <b><i>net user *</i></b><br /> 5. Then enter the required password and confirm it.<br /> 6. To enable the Administrator's accoun:<br /> <b><i>net user administrator /active:yes</i></b><br /> 7. Close the Command Prompt window and continue with the installation process.<br /> If you log off you will now see the Administrator's account as a valid logon option.<br /> Disable Built-in Administrator Account Make sure you are logged on as your regular user account, and then open an administrator mode command prompt as above. Type the following command:<br /> <b><i>net user administrator /active:no</i></b><br /> <img src="disable-local-admin-account.png" /> The administrator account will now be disabled, and shouldn't show up on the login screen anymore.<br /> <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">Hack into Windows 7 Administrator Account </a> [Free Trial] Article source: http://www.windowspasswordsrecovery.com/enable-disable-local-administrator-account-win7.htm<br />
on May 23, 2011 | Computers & Internet
Tip
Steps to create a bootable Vista or Windows 7 USB flash drive for the purpose of...
<b>Steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS<br /> <br /> <br /> Microsoft Provides a tool to do this for you - Windows 7 USB/DVD Download Tool which is available for <a href="http://images2.store.microsoft.com/prod/clustera/framework/w7udt/1.0/en-us/Windows7-USB-DVD-tool.exe">download here</a>. If you need instructions on how to use the tool, see the Microsoft Store Help on the ISO-Tool (<a href="http://store.microsoft.com/Help/ISO-Tool">http://store.microsoft.com/Help/ISO-Tool</a>).<br /> <br /> or <br /> <br /> <br /> <span style="text-decoration: underline;">Please follow the steps below</span><br /> <br /> </b> <b>Required:</b><br /> <ul> <li>USB Flash Drive (4GB+)</li> <li>Microsoft OS Disk (Vista / Windows 7)</li> <li>A computer running Vista / Windows 7</li></ul> <b>Step 1: Format the Drive<br /> </b>The steps here are to use the command line to format the disk properly using the <i>diskpart</i> utility. [Be warned: this will erase everything on your drive. Be careful.]<br /> <ol> <li>Plug in your USB Flash Drive</li> <li>Open a command prompt as administrator (Right click on Start &gt; All Programs &gt; Accessories &gt; Command Prompt and select "Run as administrator"</li> <li>Find the drive number of your USB Drive by typing the following into the Command Prompt window:<br /> <span>diskpart<br /> list disk</span><br /> The number of your USB drive will listed. You'll need this for the next step. I'll assume that the USB flash drive is disk 1.</li> <li>Format the drive by typing the next instructions into the same window. Replace the number "1" with the number of your disk below.<br /> <span>select disk 1<br /> clean<br /> create partition primary<br /> select partition 1<br /> active<br /> format fs=NTFS<br /> assign<br /> exit<br /> </span><span>When that is done you'll have a formatted USB flash drive ready to be made bootable.</span></li></ol> <b>Step 2: Make the Drive Bootable <br /> </b>Next we'll use the <i>bootsect</i> utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:<br /> <ol> <li>Insert your Windows Vista / 7 DVD into your drive.</li> <li>Change directory to the DVD's boot directory where <i>bootsect</i> lives:<br /> <span>d:<br /> cd d:\boot</span></li> <li>Use <i>bootsect</i> to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I'm assuming that your USB flash drive has been labeled disk G:\ by the computer:<br /> <span>bootsect /nt60 g:</span></li> <li>You can now close the command prompt window, we're done here.</li></ol> <b>Step 3: Copy the installation DVD to the USB drive<br /> </b>The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you've copied all of the files the disk you are ready to go.<br /> <b>Step 4: Set your BIOS to boot from USB<br /> </b>This is where you're on your own since every computer is different. Most BIOS's allow you to hit a key at boot and select a boot option.<br /> <br />
on May 19, 2011 | Computers & Internet
After I changed the ink cartridge, my printer will copy but it will not print.
Check your data cable and the printer status. (Start > Devices and Printers in Win7, Start > Printers in XP for example.)
Try a new cable. (if USB, try a new port. Use a direct connection - remove a print server or USB hub.) Does the computer think that the printer is ready or offline? Are there files stuck in the printer queue? They may need to be manually removed by stopping and restarting the spooler. In Windows this can be done in the Command Prompt (tun as administrator by right clicking in Vista or Windows 7) window. Type "net stop spooler" <enter> without the quotes. At the next prompt, type "net start spooler" <enter>. Then restart the computer.
I hope this helps.
Apr 15, 2010 | HP PSC 2410 All-In-One InkJet Printer
The printer is conected and thing but it wont print anythink and i haven't got the disc for it
What type of connection and OS are you using? Software is still available for most HP printers from the HP support but not all OS's. ( hp.com and search for your printer) Does the printer show up in Devices and Printers (Windows OS)? Do you have jobs in the printer queue (spooler)?
In general, try a new printer cable. If you are using a hub or print server, try a direct connection to the computer. If the printer reads as ready but has jobs stuck in the queue, stop and restart the spooler. (One way to do this on all Windows OSes - open the command prompt (Run as Administrator in Vista or Win7) type "net stop spooler" < hit enter key> without the quotes. At the next prompt, type "net start spooler" <enter> again without the quotes. Restart the computer.)
I hope this helps.
Apr 07, 2010 | HP Office Equipment & Supplies
Tip
Enable / Disable the Local (Hidden, Built-In) Administrator Account in Windows 7
Ways to Enable / Disable the Built-In Windows 7 Admin Account Many people familiar with prior versions of Windows are curious what happened to the Local Administrator account that was always created by default. Does this account still exist, and how can you access it?<br /> Recently I ran into an awkward situation where after disjoining a Windows 7 client machine from the domain, I was unable to log in to the computer. This was not because I had forgotten the local administrator password, but because the local administrator account was disabled (which is the default behavior in Windows 7). Like in Windows Vista, in Windows 7 the built-in Administrator's account is disabled by default. Furthermore, this account is not associated with any password. After doing some research, I found the following procedure that worked really well.<br /> <a href="http://www.windowspasswordsrecovery.com/enable-disable-local-administrator-account-win7.htm">Enable Built-in Administrator Account</a> Basically there are 4 ways in order to activate the account:<br /> A) Command Prompt To enable the built-in Administrator's account by using the Command Prompt please follow these steps:<br /> 1. First you'll need to open a command prompt in administrator mode by right-clicking and choosing "Run as administrator" (or use the Ctrl+Shift+Enter shortcut from the search box)<br /><img src="run-command-prompt-as-administrator.jpg" /> 2. After that you only need to enter the simple command below to activate it.<br /> <b><i>net user administrator /active:yes</i></b> <br /><img src="enable-hidden-administrator-account.png" /> 3. You should see a message that the command completed successfully. Log out, and you'll now see the Administrator account as a choice.<br /><img src="built-in-windows-7-administrator-account.png" /> You'll note that there's no password for this account, so if you want to leave it enabled you should change the password.<br /> B) Local Security Policy Another way of activating the administrator account in Windows 7 is via Local Security Policy. <br /> 1. Type secpol.msc in the search bar and hit enter. <br /><img src="secpol.png" /> 2. After the Local Security Policy pops up, navigate to Local Policies-&gt; Security Options where you can see an entry that reads Accounts: Administrator account. Double click the entry to enable it.<br /><img src="local-security-policy.png" /><br /><img src="administrator-account-status.png" /> C) Using the Local Users and Groups Snap-in To enable the built-in Administrator's account by using the Local Users and Groups snap-in please follow these steps:<br /> 1. Open Local Users and Groups. You can do so by typing lusrmgr.msc in the Start search box or in the Run command and pressing ENTER. Or, you could open Computer Management by right-clicking Computer in the Start menu and selecting Manage.<br /> 2. Expand System Tools &gt; Local Users and Groups &gt; Users.<br /> 3. Right-click the Administrator account and select "Set Password".<br /> 4. In the"Set Password for Administrator" click "Proceed".<br /> 5. In the"Set Password for Administrator" enter the Administrator's desired password twice, and click "Ok".<br /> 6. Next, enable the Administrator's account. Right-click the Administrator's account and select "Properties".<br /> 7. Un-chek the "Account is disabled" check-box. Click on the "Ok" button.<br /> Administrator's account is now enabled and configured with a password.<br /> D) During the Installation Process There is a 3rd method which advanced users can use. This method can be used during the installation process itself.<br /> 1. During the installation, after being prompted to configure the new user account, you will be able to set the new account's password.<br /> 2. At that phase, press SHIFT and F10 keys together. A Command Prompt window will appear.<br /> 3. In the Command Prompt window, type:<br /> <b><i>net user</i></b><br /> Note how the Administrator account is there, yet the new user account has not been yet created.<br /> 4. To set the Administrator's account password:<br /> <b><i>net user *</i></b><br /> 5. Then enter the required password and confirm it.<br /> 6. To enable the Administrator's accoun:<br /> <b><i>net user administrator /active:yes</i></b><br /> 7. Close the Command Prompt window and continue with the installation process.<br /> If you log off you will now see the Administrator's account as a valid logon option.<br /> Disable Built-in Administrator Account Make sure you are logged on as your regular user account, and then open an administrator mode command prompt as above. Type the following command:<br /> <b><i>net user administrator /active:no</i></b><br /><img src="disable-local-admin-account.png" /> The administrator account will now be disabled, and shouldn&iexcl;&macr;t show up on the login screen anymore.<br /> <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">Hack into Windows 7 Administrator Account </a> [Free Trial]
on May 03, 2011 | Computers & Internet
I cannot print a document from the computer
Try a new data cable. Check that the USB port is working - try a new port and check if a known-working device is seen by the computer. If you use a print server or a hub, try a direct connection to the computer.
Do you have the latest driver for your device? Check the Dell web site.
Is the print queue holding any documents? What does the Devices and Printers Control panel say about the printer status? If the printer is listed as ready but has jobs in the queue, you may want to stop and restart the spooler. In all versions of Windows since Win95 at least, you can do this in the command prompt (Run as Administrator in Vista or Win7). Type "net stop spooler" <hit enter> without the quotes; at the next prompt, type "net start spooler" <hit enter> again without the quotes. Restart the computer.
I hope these ideas help.
Apr 07, 2010 | Dell V305w All-In-One R840635AU InkJet...
I have connected d145 printer to my new dell laptop with Windows 7 but although installed as default printer it won't print
Do you have files in the queue? What is the printer status in Devices and Printers area?
Since this is a USB printer, my usual trouble-shooting starts with checking the USB connectivity. If you are using a hub, try connecting directly to the printer. Change to a new USB cable and try a different port. Check if a known working device will work in the port. Make sure the ports are not disabled for power-savings or security (power savings is adjusted as an advanced option in the same area as setting the Screen Saver, Security shut downs are in the Device Manager).
Frequently, you can reset the printer by unplugging the USB cable from both the computer and the printer and pulling the power cord for a minute. If the items in the print queue cannot be deleted from the queue, use the Command Prompt (run as administrator by a right click - Start, All Programs, Accessories) to empty the queue. Once in the command prompt, type "net stop spooler" without the quotes and then hit <enter>. Then type "net start spooler" (again without the quotes) and hit <enter>. Once the commands have been processed, reboot the computer.
I hope this helps.
Mar 25, 2010 | HP OfficeJet d145 InkJet Printer
Computer doesn't detect printer on installation
is it a usb printer? if so follow this:
Device Manager displays only non-Plug and Play devices, drivers, and printers when you click Show hidden devices on the View menu. Devices that you install that are not connected to the computer (such as a Universal Serial Bus [USB] device or "ghosted" devices) are not displayed in Device Manager, even when you click Show hidden devices.
  1. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. At a command prompt, type the following command , and then press ENTER: set devmgr_show_nonpresent_devices=1
  3. Type the following command a command prompt, and then press ENTER: start devmgmt.msc
  4. Troubleshoot the devices and drivers in Device Manager.
    NOTE: Click Show hidden devices on the View menu in Device Managers before you can see devices that are not connected to the computer.
  5. When you finish troubleshooting, close Device Manager.
  6. Type exit at the command prompt.
    Note that when you close the command prompt window, Window clears the devmgr_show_nonpresent_devices=1 variable that you set in step 2 and prevents ghosted devices from being displayed when you click Show hidden devices.
If you are a developer or power user and you want to be able to view devices that are not connected to your computer, set this environment variable globally:
  1. Right-click My Computer.
  2. Click Properties.
  3. Click the Advanced tab.
  4. Click the Environment Variables tab.
  5. Set the variables in the System Variables box.
Dec 24, 2008 | Brother MFC-640CW All-In-One InkJet...
Printer Problem
two possibilities, if you are in possession of the motherboard drivers you will need to install them as windows xp will be using generic ones and may not be suitable for your board, also try installing in a different usb port. The other is that the drivers you are using will probably be win 2000 and in your case it wont work with XP, so go to your printer manufacturer web site and download and install XP drivers.
May 24, 2007 | AOpen AX34-U Motherboard
EZ Dupe Publishing Plant 100 Disc DVD/CD Autopublisher Burner Logo
Top EZ Dupe Computers & Internet Experts
Gene
alwaysreddy
Are you an EZ Dupe Computer and Internet Expert? Answer questions, earn points and help others
