Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
It is scrubbing and depositing water/solution on to the floor but is not sucking the water back up. i switch it to wet pickup on the handle from scrub setting. it leaves muddy tracks on the floor.
Check the filter, if it is dirty this will cause the vacuum to lose suction. You can buy a new filter if necessary.
Posted on May 28, 2011
Left hand brush won't spin
sounds like its sticking and the sharp turn releases the catch properly try lubricating it with either oil or wd40 should ease it hopefully this helps
Apr 01, 2014 | Hoover Floormax F5300 Upright Vacuum
Will not dry or suck up water at all...BRAND NEW
If it's brand new your best bet might be taking it to a Hoover service center. That'll have a year warranty on it so the fix would be free.
Apr 06, 2013 | Hoover H3044 FloorMate SpinScrub Wide-Path...
Hoover floor mate sucks up water while in the wash position
They do that. They pickup the water in all stages but lower the squeegee to different heights. At no point does the suction turn off.
Jan 20, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
Dirty water comes out when I stop scrubbing. Floors remain wet.
Try one thing... the filter cover must be clicked into place. I thought it just sat on top, but it has to be pushed into place.
FWIW
Mar 22, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Floormate Spinbrush
Not sure if this will help but these machines are ment to be used in one direction not back and forth like a vacuum cleaner. You should start in one spot and pull towards you slowly with the trigger depressed it is designed to spray scrub and pick up the solution all in one pass by going back and forth you are pushing the rubber across dry parts of the floor and it will make noises. For any parts or cleaning solution you may need visit www.stevessewandvac.com
Jul 27, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I have a H3000 Floor Mat The problem is it want pick up the water after the scrub clean the floor. What could be the causeing the problem?
Hoover H3000 Floor Mat
I have a H3000 Floor Mat the problem is it won’t pick up the water after the scrub clean the floor. What could be the causing the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The problem could be that the Hoover H3000 Floor Mat could be clogged or something is blocking the suction port or you may have a pinched line of some type of which would cause it to not pickup, feel free to check with a local vacuum dealer in your area or in the yellow pages or the Hoover factory phone number is listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1699n proheat clear view problems
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
Sep 22, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Hoover floormate 3060
You should first check to make sure that the machine is set on wet pick up and not dry. When in dry mode ( the front foot pedal on the left side) the machine is held slightly above the floor. When is wet mode, the squeegees drop down to the floor. The other problem may be the wheel assy is broken. Turn the machine over and check the black plastic wheel carrier at the back of the assy to see if the pivots are broken.
Jul 02, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
181 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
