Question about Texas Instruments TI-30 XIIS Calculator
How to i go from DEG to RAD - Texas Instruments TI-30 XIIS Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press the DRG key on the top row of the keyboard and then select RAD from the menu.
Posted on May 26, 2011
I can't get DEG off my TI-30xA calculator
Why would you want to remove it? If you are not doing trigonometric calculations it will not affect any results. It is just a reminder that the angle unit is set to degrees. Change it to radians or gradians, and the DEG will be replaced by RAD or GRAD.
Jan 24, 2012 | Texas Instruments Office Equipment &...
On my TI 30 XA, I can not get it out of Degree mode.
Why do you want to get out od Degree mode. If you are doing trigonometric calculations, the angle unit is pertinent. If you are not doing trigonometry, it is irrelevant. You say you can cycle through DEG, RAD, GRAD. That is the way to set the angle unit.
However, there will always be an indicator on the screen (DEG, RAD, or GRAD).
Nov 18, 2011 | Texas Instruments TI-30XA Calculator
How do you change it to degree mode
Press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Gradappear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press 1.
Let me know if this helps!
May 02, 2011 | Casio FX-300MS Calculator
My HP-12B calculator is in grad mode I need to be in deg, how do I change ?
Is there a button marked DEG->? That is the standard calculator button used to change mode. It could possibly be the shift function of another button.
Mar 05, 2011 | HP Office Equipment & Supplies
How to switch from the decimal degree to degrees, minutes, seconds
Keys 1. I displays the following menu that lets you change the angle mode setting to DEG, RAD, and GRD without affecting the value in the display. DEG Sets degree mode. RAD Sets radian mode. GRD Sets gradient mode. The default setting is DEG. 2. = displays a menu that lets you specify the unit of an angle. º Specifies degrees. å Specifies minutes. æ Specifies seconds. r Specifies radians. g Specifies gradients. DMS Lets you convert an angle from decimal degrees to DMS notation. Notes · The examples on the transparency masters assume all default settings. · Angles with a trig function ignore the angle mode setting and display results in the original unit. Otherwise, angles (without a trig function) are converted and displayed according to the angle mode setting. · You enter decimal-degree angles the same as you would any other number. · For decimal/DMS conversions, the calculator interprets all values as degrees, regardless of the angle-unit setting. · DMS angles are entered as º (degrees), ´ (minutes), and ´´ (seconds You watched 2 videos that were 2:05 (2 hours and 5 minutes) and 1:46 (1 hour and 46 minutes) in length. How long did you watch videos? = Press Display 2 = ¡ å æ r g & - DEG < 2¡ DEG 5 =" ¡ å æ r g & - DEG <T 1 = < 2¡ 5å + 1¡ DEG 46=" << 2¡ 5å + 1¡ 46å ' 3.85 DEG =! % ¾DMS ---- DEG << Ans ¾ DMS ' 3¡ 51å 0æ DEG Degrees, Minutes, and Seconds to Decimal © 1999 TEXAS INSTRUMENTS INCORPORATED TI-30X ùS: A Guide for Teachers 96 How much is 2/3 of an hour in hours, minutes, and seconds? = Press Display 2 N 3 2®3 DEG =! % ¾DMS ---- DEG << 2®3 ¾ DMS ' 0¡ 40å 0æ DEG
Aug 19, 2010 | Texas Instruments TI-30 XIIS Calculator
DEG mode
The DEG indicator has absolutely nothing to do with division, fraction or other operations. It is relevant only when you are calculating trigonometric functions (Sine, Cosine Tangent and their inverse functions.)
When you are calculating trigonometric functions the results depend on the angle unit the calculator is configured for
DEG >> angle values are in degrees.
RAD>> angle value are in radians
From the equivalence 180 deg =Pi radians you get
1 rad= 180deg/Pi=180 deg/3.14..=57.29577951 degrees.
The DEG indicator merely reminds you that angles are in DEG. If you change the unit to RADians the RAD indicator will be displayed instread.
Apr 15, 2010 | Casio FX-260 Calculator
FIX/Mode problem?
I do not think that the DEG and FIX indicators are preventing you from calculating any logarithm. DEG appears to remind you that the CURRENT angle unit is the degree. You can change it to RAD or GRAD if you have to use those units. However, DEG will disappear only if replaced with RAD or GRAD.
The indicator FIX reminds you that the display mode for the results is the FIXed mode, not the SCIentific mode. In the FIX mode you specify the number of decimal digits from 0 to 9 and all your results will show the set number of decimals. So if all your results have a lot of unnecessary 0, maybe you should set the FIX mode to fewer decimal digits.
If you still have a problem with the calculation of logarithms, maybe the syntax you use is incorrect.
Try number then log
If that does not work
try log then number.
Apr 03, 2009 | Casio FX-250HC Calculator
Unwanted letters DEG show on Casio FX-100A display
No!! deg mean degree the system of answers you get, you can change it to rad=>radians but you never get rid of them. Sorry :(
Jan 11, 2009 | Casio FX-300MS Calculator
Problem with Casio FX 260 Calculator
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Dec 03, 2008 | Casio FX-260 Calculator
Texas Instruments TI-30 XIIS Calculator Logo
35 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
