Question about Dell Inspiron 5160 Notebook
Dell Inspiron 5160. When plugged in then power light lights up (before hitting the power button like my 5150) and the battery light is amber. The 5160 will not do anything - not power on at all.
    President:
  • 3,278 Answers
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Posted on May 26, 2011
Flashing amber and green when charging
I don't know your computer, have you read the Trouble Shooting chapter in its manual? You could try plugging the computer in and leaving it to charge for several hours; my notepad will not display if the battery is flat. Good luck!
Jun 25, 2013 | Dell Inspiron 5160 Notebook
Only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
Dec 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5160 Won't start up or charge battery
I have the dell inspiron 5160 works great a little slow but no big deal. The problem I have as of Monday the power cord will not stay in and now will not charge. Is it the power port? Can this be fixed?
Jun 27, 2009 | Dell Inspiron 5160 Notebook
Power button pushed battery light blinks twice won't turn on
I have the same problem for my dell note book
This is how i solve it
Unplug your note book from any power source
then remove the battery from the Notebook for
30 minutes after 30 minutes put back the battery and reconnect your adapter to power source turn on the power
Feb 19, 2009 | Dell Inspiron 5150 Notebook
Dell inspiron blinking orange battery light. keybrd not respondg
Try this: remove your battery, unplug power, press and hold power button for at least 20 seconds, plug power cord back in but not the battery, press power and see if you get normal boot. If this is the case, your battery probably needs replaced.
Feb 17, 2009 | Dell Inspiron 5160 Notebook
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Jan 24, 2009 | Dell Inspiron 5160 Notebook
Dell 5160 orange light
removed battery, and acadapter FROM UNIT, HOLD DOWN THE POWER BUTTON 60 SECOND That should drain the power from it
Mar 26, 2008 | Dell Inspiron 5160 Notebook
My Dell Inspiron 1150 PC Notebook Won't Turn On
Norm.. Suffice to say these are a problem. Is it a P35 Adapter? If so look for a replacement and retry. If this does not help Check the CMOS battery voltage as crazy as it may seem but the Dell adapters are a little more complicated than a standard 2 wire output adapter. They have a 19V Feeder or main supply, The Negative or Ground as some people/techs call it as well as a 3.3V data circuit thats related to the Embedded controller chipset, BIOS and other circuits on the board. Also see if you can find a friend local with a known good working battery/adapter if you cannot afford or dont want to spend money on it. If all else fails yell back weve repaired a ton of these and they should have been included in the 5150/5160 Dell Class settlement in my opinion as they have a ton of similar components/issues..
Good Luck! Ken
www.ikenfixit.com
Jan 15, 2008 | Dell Inspiron 1150 Notebook
Dell Inspiron 5160 Notebook Logo
388 people viewed this question
Alun Cox
