Question about Bernina Artista 180
"Please check hook system" ?
  • Bernina Master
  • 1,122 Answers
Clean out rotary hook area following manual instructions on how to do this, usually removing bobbin holder and bobbin, then the rotary hook area by undoing the latches each side.
Could be a thread jamming in there causing the error message.
Posted on May 26, 2011
How can I open/clean hook system?
Unable to assist without knowing the make & model. Consult the owner's manual. There should be instructions re how to remove the bobbin to access the hook area. Check the maintenance section.
Feb 16, 2016 | Sewing Machines
Baby lock quest
The top thread is looping right? This particular machine loves a well oiled hook system, and it needs to be vacuumed out regularly. Compressed air is not good on this machine, actually it is not good on any machine if the covers are on. So check for thread trapped inside the hook system by flooding with oil and oscillating the machine back and forth for a few minutes.
Two other possibles: something is snagging the top thread like thread trapped inside the hook system or a little burr on the stitch plate. Moving faster means the fabric tractors harder, so any burrs will be mre noticeable.
Dec 03, 2013 | Baby Lock Imagine
I think timing is correct because hook catches thread every time, but when the hook finishes its rotation and releases the thread, the thread loop doesnt make it all the way around the bobbin case......it...
the catcher/hook on the bobbin case system loosen or not fix properly probably becoz of vibration or something( check or replace new), then check upper system either tension/ tighten of your thread/yarn or correct..
Oct 27, 2013 | Consew CP206R Sewing Machine
Artista640 bernina message : main motor failed please check hook system
Could have threads wrapped around hook. Remove the bobbin case, the hook lid and the hook and clean this area. Hope this helps
Machine Tech
Oct 20, 2013 | Sewing Machines
Loose top thread bernina 1008, tension problem but no solutions yet...
Are you sure you are getting the top thread between the tension discs? You should be able to tell the difference when you lower the pressed foot.
Jan 27, 2013 | Bernina 1008
My phaff wheel seems to be locked up -- what can i do to fix it the needle will not go down to pull the bobbin thread thru ,and it "sticks " when i try to turn the wheel
There may be a piece of thread logded between the hook and the bobbin case holder. Try turning the handwheel very firmly backward (opposite the sewing direction).
Jun 16, 2011 | PfaFF Creative 7570
NEEDLEPLATE "A" IS ALREADY ON THE MACHINE BUT IT
please chnge to needle plate "B" bec your needle "A" is damaged,please refer to the service centre.
Jan 17, 2011 | Janome Memory Craft Compulock
A friend in Kansas with a Singer Athena 1000 (German make) needs a "hook gear." Suggestions?
I think that she will find it at www.sewingpartsonline.com, I am not too sure what she needs but they do have the bobbin case and repair kit listed. She can also talk to them and they can advise her. Good luck
Oct 30, 2010 | Singer Sewing Machines
While sewing, the needle suddenly hit the side of the foot-plate which bend the needle, but now the entire machanism is stuck and won't move up or down. How can I fix it and what is the cause of the...
hi there
1- how old your machine ? please check needle par play left and right or no? maybe lower needle bar bushing need to change.
2- maybe ur presser foot played need to change it but check firist.
3- sometimes when needle is broken there is small metal goes insaide the hook and make it dosn't move up or down, if you can adjust timing for hook please remove the hook and check your machine by hand move or not?
4- maybe some thread goes insaide the finger ( stopper for hook ) check this earia .
Best regards
ashraf abozid
aabozid@hotmail.com
Aug 28, 2010 | Sewing Machines
Sewing Machines Logo
357 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
