Question about Mitsubishi VS-50502 50" Rear Projection Television
Mits 50" Model VS-50502 turns
  • twelzien May 28, 2011
    Hi:
    Unplugged TV for 15+ seconds, relay clicked, plugged back in, hit power button, power light came on, relay clicked off, went to front panel and held MENU + INPUT buttons for about 15 seconds, NOTHING, no lights.
  • 10,515 Answers
Sorry to hear about your problem, I can help you today.
The first step is to get the error code after the Tv goes into shut down:
Plug in the Tv.
After light on the front stops blinking rapidly (initialization), press power.
The power light should come on for a second then go out.
Now on the front panel press and hold MENU + DEVICE (INPUT) buttons until the light on the front starts blinking a two digit code like 3 blinks pause 4 blinks repeat, or 2 blinks pause 4 blinks repeat, etc.
Post back here withe the error code.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 26, 2011
I have a Amana model#ARS266RBW, about 12 hrs ago it had defrosted itself, I turned it off for about 2 hrs and started it back up and it won't get cold? HELP????
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 16, 2011 | Refrigerators
My Dad has whirpool Gladiator it only cools to 50 deg in the freezer . We unpluged it and let it set over night to see if it was a defrost problem.Compressor cycles and then shuts down @ 50 deg Still will...
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
Leo Ponder
Aug 16, 2011 | Whirlpool Gladiator Refrigerator
We moved our whirlpol gold refrigerator and now it won't work
Leo Ponder
Aug 14, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Unit does not get cool. I can hear the compressor kick on, but it goes off about 15 seconds later. After a minute or so it goes on again only to shut off again
Hi!
Leo Ponder
Aug 13, 2011 | Danby Silhouette DWC512BL Wine Cooler
Does anybody have a download of a repair manual for a mitsubishi
User-Manuals.com has them in .pdf for $14.99 for download. Not a fix for a borrow but yours to keep.
Mar 25, 2009 | Mitsubishi VS-50502 50" Rear Projection...
Mitsubishi Projection TV Model # VS-50502
The power supply section is having trouble.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 13, 2008 | Mitsubishi VS-50502 50" Rear Projection...
Mitsubishi VS-585R
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Dec 21, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi 50 in vs-5043
Needs convergence circuit O/h==replace convergence IC's & any damaged/over-heated resistors.re-align as needed.
Oct 01, 2007 | Mitsubishi VS-50502 50" Rear Projection...
Televison & Video Logo
112 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
