SOURCE: Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
SOURCE: spool comes out one end and wraps around trimmer bottom: Grasshog gh700 model electric dual line
Yes, the lines should spool in the same direction.
SOURCE: try to replace fuel line craftman weedwacker
You will need to get some TYGON fuel line. Match it up to the size of each fuel line, some of these trimmer use two different size lines, and remember which size went on which connection. You will want about a foot of each. Cut one end of each line at a 60 degree angle. With a pair of needle nose pliers, feed the angled end of the fuel line into the hole going into the tank and feed it into the tank untill you can see at the tank fill. You cut the angled end off and put your filter on the line. Pull it back until the filter lays at the bottom of the tank. Hook this line up to the supply side of carburetor. Take the other line and put it in the tank about 1" or 2"
then cut it off to fit on the carburetor. HTH
Good Day.
SOURCE: I have a 32cc Craftman
This problem seems to be the biggest and most popular one by far in these forums and has been answered several times. Try and post your problem using the search feature on this site. Don't use too many words. Craftsman Weedeater Fuel Lines should be sufficient. If you can't get it, then post back here again please.
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
