Question about Dometic Rooftop RV Air Conditioner
Everything seems fine,but evaporator freezes up after about an hour.any idea?
  • 4,336 Answers
Yes, sounds like you have a system that may allow you to set it to too cold.
Here are the highlights: One of the processes of A/C is to remove moisture. Same as condensation corms on a cold glass of ice water....Natural and normal. The process of refrigeration needs to be stopped when the evaporator core gets close to freezing. NOT ALL SYSTEMS do this automatically (which makes ZERO SENSE to me!!,) An automatic system would cycle the compressor to OFF, enough to allow the evaporator to not accumulate ice buildup. So, if your system is automatic, have it checked. My guess is your is not automatic
IF your system has a coldness/compressor control, you may need to set it warmer, to actually get maximum cooling. NUTS to ask a user to do this, because, as the evaporator freezes, the HUMIDITY goes up, the user NEEDS more cold and forces the unit to freeze up. Totally unnecessary, but even Mercedes has made cars that work this way....Nuts...
Try putting a thermometer in or very soon after the evaporator. IF you could keep the evaporator core at 34 to 36 degrees, that is the max cooling that you can get, period.
This presumes that your A/C system is in good state of repair, with the proper amount of refrigerant, open drains, etc.
Posted on May 26, 2011
    Sergeant:
    Novelist:
  • 185 Answers
Sounds like an air flow problem.......... Dirty Filter, not all of the supply vents open, return air blocked, Evaporator coils dirty, Blower motor quiting after it runs for awhile Check run capacitor.
Check to see if you are getting an even frost pattern.... if you are not , may be low of freon Thermostat set to low not letting the unit cycle off...... Are you running the AC with low ambient conditons outside..... Which will lower the head pressure which will lower the suction pressure and get the evaporator coil down under 32 degrees which will cause it to freeze up So take your pick it can be any number of problems....... Hope this helps.......
Hello Experts, I have a 2004 Murano. The AC works fine, but after an hour running on a long trip for instance, everything seems to work fine but very little air flows. Please help.
Check for clogged blower filter, water may be staying inside the evaporator unit, the condensation frezzes the condensator and littel air or no air flows thru it, check the a/c fans for the evaporator functionality.
Jul 08, 2009 | 2004 Nissan Murano
Samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Apr 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
2005 LS Jag engine - air conditioning works on long trips sometimes, then all of a sudden we get no cold air and the air flow reduces to about nothing. I stop the car (gas station for 5 minutes) and go...
Sounds like your evaporator is freezing up.There are several things that could cause this like low freon charge,restricted orifice tube,ambient air temp sensor,evaporator discharge air temp sensor,AC pressure transducer sensor.
You might want to get someone experienced on that vehicle to take a look at it.
Feb 25, 2009 | 2001 Lincoln LS
Whirlpool model ED25TW intermittent freezing
HI. it looks to me like a failing fan motor . it stops sometimes, then you close the door, and it goes. or could be hitting ice. remove the back panel ov the freezer, and check the fan motor
Oct 15, 2008 | Whirlpool Refrigerators
Refrigerator not cooling Freezer is fine
The defrost drain is blocked..This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle.Seems like it is blocked with water or ice.
Unplug the refrigerator, empty out the freezer compartment
pull off the back panel or the bottom panel (in the freezer compartment) Look for that defrost drain hole..
pour small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. Repeat this until I get the water to go down the drain tube..
Hope this works..
Regards,
Eagle.
Oct 19, 2007 | Refrigerators
Cooling problems
Did you make sure the evaporator fan is working? I would check that and also make sure the evaporator is not all iced up. If it is iced you have a defrost problem and not with the sealed system. so check that out and get back if you can. Thanks
Jul 15, 2007 | GE GTS16BBSL Top Freezer Refrigerator
Kitchenaid refrigerator/freezer
SORRY, YOU NEED A TECHI. THERE. EITHER YOUR TH/STAT IS STICKING OR THERE IS AN ISSUE WITH YOUR AUTO DEFROST UNIT. ALL THINGS TOLD CHECK THAT THE FREEZER OR EVAPORATOR FAN IS RUNNING. IF NOT IT COULD ALSO CAUSE PROBLEMS.
May 21, 2007 | Whirlpool GD5SHAX Side by Side...
Fax Machine freezing
TRY REPLACING SMPS (MAIN FILTER CAPACITOR) --IF NOT SOLVED THEN REPLACE THE MAIN PBA(MAIN BOARD), HAPPY FAXIONG OMNIPRESENT
Apr 13, 2007 | Samsung SF-330 Plain Paper Inkjet Fax
Dometic Rooftop RV Air Conditioner Logo
158 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
