Does the arial end that plugs into the back of the stereo have a black clip on it or are the wires bare??
    Brigadier General:
  • 8,546 Answers
Have you looked at the manual?
The specific product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
Posted on May 26, 2011
  • benita_hodge May 26, 2011
    It is a Panasonic Stereo 5 disc SA - VK860
  • David Dunn
    David Dunn May 26, 2011
    The question remains- have you looked at the manual? That's what I'D have to do to answer.
    If you don't have it...
    Register and download the manual for free at audio.manualsonline.com
    http://audio.manualsonline.com/manuals/m...
    Maybe page 9
I have a "technique ICBM-9774" stereo that was givin to me it has the built in DVD screen that pops out.. I need to know if anyone knows which wires go where in the back. I have the plastic clip for i
Hello;I have the same unit.There should be input and output plug.s listed on the back,these may need R.C.A. jack,s or in some cases are clipped in with bare wires on the ends.There should be plugs that say left and right and the r.c.a. jack,s may have 2 or 3 in the line,it does not matter if you use the blue/red/black or yellow, but write down on A piece of paper what one,s you use for left and right Etc. so when you hook them up to the equipment you want to hook up to you know what color,s goes where.Good Luck and have Patents it may take some getting used to.
Jan 15, 2013 | Cars & Trucks
I have a sony str-DE695 and I am trying to hook up my speakers/record player to it. The record player has an RCA chord with one white and one black end. The speakers has the same chord but with one red and...
the inputs should be marked phone (if on the reciever the colors are red/white and the colors of the rca ends are black white put the black plug in the red and white plug into the white input..if the stereo doesn't have rca speaker output ports you'll need to cut off the speaker rca's and strip the wires bare then comnnect usually copper (red) silver (white) or pos (silver) neg (copper.
Sep 26, 2012 | Sony STR-DE695 Digital Audio/Video Control...
Need a wiring diagram for alpine ktp445 amplifier to install on no alpine system
bassmekanic_3.jpg For this end of the plug: I would plug the other end of the KTP-445 directly into it and match the color of the wires off the other plug, remember to write them down, but most of the wires look like standard plug wires on most stereo plugs. When this is complete you should be able to snip this end off. Then wire it the wiring harness inside the dash (using the notes you took on the wire colors)
bassmekanic_4.jpg This end of the plug looks to have all the standard wires that most after market stereos have, clip this end off and wire it to the wiring harness on your current stereo. (You may not use all the wires, just tape them off because you probably won't need them anyway)
This is just my opinion on how it would be done, I have not tried this myself. But since most aftermarket stereos have the same kind of wire set up I do believe this could work.
If you decide to try it, please give some feedback so others can figure out how to do this also.
Nov 09, 2010 | Alpine KTP-445 Car Amp
I have an old SHARP HK-9000 Multi-purpose Music syatem...we cant find speaker connectors on the rear. The speakers are detachable and dont have input jacks, just bare wires. Where do they connect??
The speaker wire is supposed to be connected to a mono right angle 1/8" male plug. It resembles the same plugs at the end of headphones used for all sorts of walkmans, cd players, mp3 players... But the plug on your speakers is mono so instead of there being two bands on the plug for stereo, you need the mono variety, the one with one band. They plug into two small female holes located on the bottom rear of the boombox. You might see some small black plastic clips along the bottom of the boombox held in place by one screw. These things are meant to keep the speaker wire from hanging out from the bottom of the boombox.
Aug 11, 2010 | Sharp Audio Players & Recorders
Hi there.. i am trying to finded the accessories wire on my radio in a 1995 toyota trooper for my amp. who can help????? thanx
Easiest way is to use a " Test light" , clip the wire end of the light to one of the screws behind the stereo that have a good earth, one of the plugs on the back of your existing stereo will have Black, Yellow, Blue and Red wires ( Black is sometimes White with a Black tracer)
Red and yellow are usually "power " and " accessory" . test by using the test light ( you want the wire that powers up when you turn the key to "accessory" position.
If your Amp is a serious one , the accessory wire is probably too small to run your amp reliably.
Use the accessory wire to activate a relay and run a substantial wire to feed the amp directly from the battery ( don't forget to install a fuse ).
REMEMBER all wires contain smoke! Your job is to keep the smoke in the wires.
When you go to run your wires , disconnect your battery until everything is in place.
Apr 06, 2010 | 1995 Toyota Land Cruiser
Where to hook up timing light+ -leeds to checkbase timing
The red wire goes to the + terminal on the battery. The black wire goes to any ground source, ( brake pedal, handle bars, any bare metal surface ). The heavy black wire goes to the spark plug wire. Some timing lights have an inductive pick up so the end clip simply snaps around the plug wire. Older lights need to hook into the plug wire then to the plug.
Jan 02, 2010 | 2002 Honda XR 200
Aftermarket stereo wiring harness does not fit oem connectors. ordered stereo and harness together fom online car stereo.com. calledout a metra #70-1761. plugs will not fit either male plug. factory plugs...
Theres a standard amongst most stereos, so if these colors apply, then you will be right,
Red is Ignition power
orange is direct power
Black is earth
blue is for phone
White is for electric arial
then there will be four coloured wires with matching color trace wires, these are the speaker wires.
Hope this gets you going, good luck.
Jan 01, 2010 | 1995 Toyota Avalon
I don't know how to attach my speakers to the red
If you have bare ended wires , you simply unscrew the red and black plugs at the amp they should have a hole in the end of the plug and on the side also just place the red wire into the side hole of the red plug and finger tighten the red screw the same on the black plug
Jun 06, 2009 | Polk Audio RTi100 Main / Stereo Speaker
Adding extra wire to speakers so I can move speakers.
Red and black are high end and blue and grey are sub speakers.
Apr 15, 2017 | Panasonic SC-AK500 CD Shelf System
Nakamichi RE 10, Ser # D14104843
The end holes are designed for plug-in speaker jacks, either single-ended or double ended to span the red black simultaneously (the spacing has to be right, though). Tighten the red/black parts first.
Otherwise you need to bare a little wire (not sure you either can or want to do that with Monster Cables); unscrew the black or red connectors sufficiently and wrap the bare wire around the base, being careful to avoid stray conductors reaching across to other terminals. If you look closely there might be a small hole drilled through the terminals, accessible from below. Ideally you would bare the wires, tin the ends with solder, stick them through those holes and tighten the plastic knobs.14-ga lamp cord would work fine, too, and it's cheap, cheap, cheap.
The 901's will absorb unlimited amounts of CLEAN audio power.
Jun 24, 2008 | Nakamichi RE-10 Receiver
21 people viewed this question
 Grubhead
Grubhead
