Question about Samsung HLR5087W 50" Rear Projection HDTV
Samsung hl-r5087w has black vertical lines - Samsung HLR5087W 50" Rear Projection HDTV
  • kawaakoa808 May 27, 2011
    mines again has small black lines thru the whole screen.picture is good but its like looking thru a fence
  • 26 Answers
SOURCE: HL R5087W DLP
try reseating the dvi cable inside the set
Posted on Jun 13, 2009
ladywinn
  • 5138 Answers
SOURCE: I have samsung DLP TV HL-R5087W with pink/green discoloration
NO ,its not the Lamp it is your Light Engine. Call UED for price of rebuilt one 1-800-648-6657.
Posted on Sep 24, 2009
sabreusa
  • 271 Answers
SOURCE: HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Posted on Nov 09, 2009
  • 148 Answers
SOURCE: My Samsung HL-R5087W HDTV turns itself off
Sorry to hear this, but fortunatly this is going to be an easy and cheap fix-BUT ONLY IF YOU DO IT YOURSELF!!...A repair man will charge you $ 200/$300 to order a powerboard and install that, something a novice can do in 20 minutes ( a pro in 4 minutes), by replacing the "popped" capacitors yourself...Let me explain;.........The "caps"(capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Now go fix the neighbor's tv/monitor, just to show off :P
I really hope you take my (experienced) advice, it is well worth the time.
Please rate if this has/ has not helped you!
Posted on Feb 02, 2010
  • 1156 Answers
SOURCE: my samsung hl-r5087w has black
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help to fix the fault, do take care in handling the solution
Posted on May 26, 2011
My samsung hl-r5087w has black verticle lines how do i fix that
May 26, 2011 | Samsung HLR5087W 50" Rear Projection HDTV
How do I reset the timer on my tv HL-R5087w
press mute+1+8+2 and power it will take you to Your TV set should now say "Loading Factory". and go what it tell you
Dec 17, 2010 | Samsung HL-R5087W Replacement Lamp
Good luck
N Sabre
Nov 09, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
Replaced buld still no picture only sound
I have been having a similar problem with my Samsung # HL-R5087W.
I will be watching the TV and then it will lose the the picture, just sound. I then, turn off the TV for a minute and turn it back on. Works for another 30 minutes to 2 hours til it happens again. Weird!
Oct 19, 2009 | Samsung HL-R5087W Replacement Lamp
I have a hl-r5087w and it won't come on. The
the lamp light will light if the lamp or color wheel is defective.
Sep 29, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
Sep 24, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
On a Samsung HL-R5087W TV i have 10 rows with 8 lines per row going across the screen vertically. These lines are Black. Please HELP!!!
Single Pixel width Verical Lines in all video inputs including OSD
This is caused by a defective DMD Board
Jul 22, 2009 | Televison & Video
HL R5087W DLP
Jun 13, 2009 | Samsung HL-S5087W DLP TV
Samsung HL-R5087W 50 in. green tint
usually that means you have external speakers to close to tv and magnets in the speakers do that
Apr 17, 2008 | Samsung HL-R5087W 50" HDTV-Ready...
Instruction Manual for Samsung HL-R5087w
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010300&prd_mdl_cd=&prd_mdl_name=HL-R5087W
Sep 09, 2007 | Samsung HL-R5087W 50" HDTV-Ready...
Samsung HLR5087W 50" Rear Projection HDTV Logo
Henry  Thomas
Henry Thomas
