Question about Sony PlayStation® 3 (60 GB) Console
I have a connection problem the error code is (8013031B) I already tried the solution and didnt work when I ran the connection test it failed. I hope you guys can help me out.
  • 127 Answers
Visit my website xbox360repairspro.webs for more help
Posted on May 29, 2011
What does Error Code: HD521-2W mean and how to fix it
http://h30434.www3.hp.com/t5/Desktop-Hardware/SMART-Short-Self-Test-Failed-Error-Code-HD521-2W/td-p/1181885
Nov 09, 2013 | Samsung SP2004C 200GB 7200RPM 3.5in 8MB...
Error code 0142 message error code 2000-0142
My computer did boot up to the desktop, but was completely unresponsive from there when trying to open anything. I ran a system diagnostics and got this error with the status byte of 70. I rebooted into Safe Mode and was then able to open files. I backed up my stuff to a flash drive and then ran Error-Checking in the HD Properties which runs the CHKDSK function the next time the computer is rebooted. That found 2 bad file clusters and repaired them. One was a file called Windows.edb, which does the hard drive search indexing for Windows and was most likely my problem with the lockups. The other was a Napinsp.dll file. After these were fixed and the computer was rebooted, everything worked normally.
This HD is only 9 months old, but if this happens again, I'll replace it again.
Apr 21, 2012 | Dell Inspiron 6400 Notebook
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
How can I fix ps3 error 8013031b
prez330 answered this question in a post a while back. Google is your friend on problems like this, I found his post by searching "ps3 error 8013031b".
According to Sony, these are the steps you should take to fix this error code. It has something to do with the way your system obtains its IP address from the network you are connected to. This should fix it.
SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > WIRED CONNECTION OR WIRELESS >
WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
Aug 12, 2011 | Sony Playstation 3 (PS3) Console
Error code 00F0:136C IDE FAILED BLANK MEDIA OR NO MEDIA IS PRESENT IN OPTICAL DRIVE. IS THE HDD FRIED OR WHAT?
You probably ran the 32-bit diagnostics in this Dell computer.
The error code 00F0:136C, actually is talking about the "OPTICAL DRIVE,"which is your CD/DVD ROM; not the hard drive.
That will fail since, I am assuming you didn't put anything inside the CD-ROM.
The diagnostics tests everything and in this case, it tested the CD-ROM and failed since there is no CD inside the CD/DVD-ROM.
Hope this helps.
Thanks,
Oliver
Jul 28, 2011 | Dell Inspiron 6000 Notebook
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
How do you solve the 8013031B error code on the ps3
I have researched your issue and found that people who were experiencing the 8013031B error message resolved the issue in a few different ways.
1. Try rebooting your internet connection. You can do this by turning off the ps3 and disconnecting the the power from both the modem and router. wait 1 minute then plug the power back into the modem. Wait for the modem to establish a connection to your internet service provider (typically takes between 2 and 4 minutes). after the modem gets a connection plug in your router and wait for the router to connect to the modem (typically 1 to 2 minutes). Then power your ps3 on and retest.
If your still getting the same issue try bypassing your router.
If this fixes the problem then there is a issue with the router.
Your best bets are to try updating the firmware on the router and or resetting the router to it's defaults.
If none of the above steps resolve your issue then try resetting your ps3 to it's system defaults. This will cause you to lose all your data so be sure to back it up first on a usb drive.
Please post a follow up to let me know how this goes for you.
If possible please rate the solution I have provided. Thanks.
Aug 25, 2010 | Video Game Consoles & Games
My Dell Inspiron 6000 has Samsung Model MP0603H hard drive. The computer was working fine till this morning when it would not boot. I ran diagnostic using the Dell CD and the results stated: Error Code...
Those codes all apply to the hard drive itself..
Replacing the hard drive is all you should have to do.
Below is a link to a brand new hard drive that will work in your Inspiron 6000
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350216497944&rvr_id=119484484159&crlp=1_263602_263622&UA=%3F*F%3F&GUID=1ca6610412a0a0aad456d986fffd8c0c&itemid=350216497944&ff4=263602_263622
Aug 03, 2010 | Samsung ( MP0603H) 60 GB Hard Drive
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
Sony PlayStation® 3 (60 GB) Console Logo
240 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
