Question about SMC TigerSwitch 8606T (SMC8606T)
Hi, I have a smc 8606T tigerswitch but i lossed my password and how can i reset it? pls help me. Many thanks
3 Suggested Answers
etaf
  • 779 Answers
SOURCE: I have forgotten my password
I assume this is your wireless KEY
The user manual is here http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_GBR&knowsPartNumber=false&productCategory=1&modelNumber=955&partNumber=3552&downloadType=8&os=0
you can choose the exact model from here http://www.smc.com/index.cfm?event=downloads.searchCriteria&localeCode=EN_GBR&knowsPartNumber=false&productCategory=1&downloadType=0&os=0
You should be able to see how to view or reset the wireless password.
Connect your PC to the Router with a LAN cable:- You will need to login to your router- you do this by typing a number into a web browser, Internet explorer, is best as some routers do not work with other browsers The way to log into the router is usually to use the IP address, thats a number which will be in the manual - Page 29 on the manual (33 on pdf screen) To access the Wireless Barricade’s management interface, enter the Wireless Barricade IP address in your Web browser http://192.168.2.1. Then click LOGIN. (By default, there is no password.) Goto the wireless section - secruity and you should be able to see the KEY - IF its all * - the you can type in a newone
I would also remove the wireless profile from your PC - to do this have a read of this link. Remove the wireless profiles from your PC http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Posted on Mar 25, 2010
HOW DO I RESET A SMC 10/100 TO FACTORY DEFULT
Remove the power cord from the back of the switch.
Remove all cables from the front panel ports.
Connect port 1 to port 2 on the front panel using a standard patch cable.
Reconnect power to the switch.
Wait at least 40 seconds before disconnecting the patch cable between port 1 and port 2.
After the above is completed, the password will be "smcadmin" and the switch IP will revert to 192.168.2.10
Mar 01, 2013 | SMC Tigerswitch 24-port 10/100 Switch...
I have a problem with 2 smc tigerswitch 6724Al2 to connect them via fiber port
You can take a look at the installation guide and check the guideline about optic connection there if you didn't. If LED light up then you might need to check something on the second document on troubleshooting part.
http://www.smc.com/files/AB/MN_6724AL2_INS.pdf
http://www.smc.com/files/AU/MN_6724AL2_MAN.pdf
Jan 05, 2011 | Computers & Internet
How Can I reset the SMC 8612XL3 switch to default factory mode?
hi there Ramesh -- please rate me
i believe i have what you asked for .. read on
i found the following information
a 2 page overview for this item
http://www.smc.com/files/AR/ds_8612XL3.pdf
home page for this item
http://www.smc.com/index.cfm?event=viewProduct&cid=8&scid=44&localeCode=EN%5FUSA&pid=1179
**MOTHERLOAD**
manual http://www.smc.com/files/AQ/MN_8612XL3_MAN.pdf
command.
Default Setting
None
Command Mode
Privileged Exec
Command Usage
This command resets the entire system.
Example
This example shows how to reset the switch:
Console#reload
System will be restarted, continue ? y
i hope this helps you
Nov 05, 2010 | SMC 8612XL3 101001000Mbps TigerSwitch 1000...
Hi, how to reset smcwbr14-g2 password? I forgot username and password thanks
Hi ,
I got your issue, Inorder to reset the username and password to the default setting the only way is to reset the router , look on the router you will have a pin hole button, push that reset button for 10 -20 sec. Then you can login to the router using username 'smcadmin', password - 'admin' or 'blank'.
Thanks & Regards,
Prema.
Oct 09, 2010 | SMC Barricade g SMCWBR14-G2 Wireless...
The default password isnt correct, cant log in. I reseted the device many times, and unpluged for hours/days but the default password still doesnt set back...so i cant use the device because with default...
According to SMC the default password which is case sensitive is: smcadmin you enter that into the SMC web interface found by typing 192.168.2.1 into Internet Explorer's address bar.
The full manual is here,a nd their support site is here
If this helped you then please help me and vote, thank you
Oct 12, 2009 | SMC Barricade SMC7004VBR (SMC7004VBR-CA)...
Default login & password
Default password for most of the modem is "admin"
If it doesn't help, then it will be mentioned in your modem user manual. For resetting your modem, you can use the hardware reset switch also. You can reset using that by inserting a small pin/needle into the hole located somewhere behind the modem.
Aug 03, 2009 | SMC Barricade g SMCWBR14T-G Wireless...
Adding a PC to the network
Make sure your network card on the computer is enabled and properly installed. Also try replacing the cable with one that is known to be good. I hope this helps. Good luck.
Nov 05, 2007 | SMC TigerSwitch 6508TT
SMC TigerSwitch 8606T (SMC8606T) Logo
59 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
