Question about Samsung Cameras
My lens are stock up..whenever i start the power it only activates the power for a second.
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Posted on May 26, 2011
Sony cyber shot dsc h200 lens is stuck, will not take pictures. says to turn off and turn on again, but does not work.
Hi Susan,
If you cannot find the power button, just simply remove the battery wait for few seconds and put the battery back. What I assume of this behavior is 'If the coming out lens is obstructed by anything' the camera will show such error. If it does again, I would suggest calling Sony and getting their advice. Regards
Feb 27, 2014 | Sony Cyber-shot DSC-H200/B 20 Megapixel...
The lens will not retract and the camera will not power on except for a second when it will seem to start up when I turn it on. We bought a new battery, and tried it out at the store, but it did nothing so...
Your camera most likely has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Oct 04, 2010 | Kodak V803 Digital Camera
Lens Error:20e,1,0,0 appears on the screen whenever I turn on my camera and the camera instantly shuts itself off. How can I fix this? I really like this camera but it doesn't work at all
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Oct 03, 2010 | Kodak EasyShare C743 Digital Camera
Whenever I turn on my camera, the lens error 0x0111 pops up, then the camera turns off. I have a Sanyo 12 mp VPC-S1275P2. Please tell me how to fix it.
This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
If your camera is still under warranty and has definitely not been subject to misuse then contact the Sanyo service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Sep 24, 2010 | Cameras
Lens mount plastic is broken on Lens
Unfortunately your lens is one of the kit versions which were built as cheaply as possible with a plastic lens mount. They were never intended to be repaired, but to be fair they usually seem to last quite well on the 18-55mm versions but the 18-105mm is heavier and longer and I've found that the plastic mount is particularly intolerant to any handling errors on this lens.
A professional repair will normally cost more than the lens is worth, but you can sometimes buy new replacement mounts.
Use your favourite search engine to look for part number 1C999-488. Unfortunately they're rarely in stock whenever I've needed one. You may also want to search for a scrap lens with a good mount which you can replace yours with, but scrap lenses of the correct type usually have faulty or badly worn plastic mounts as well.
Carefully assess your lens before making the repair: unless it's in perfect working order in all respects except for the broken mount then you'll be better off buying a new or used complete replacement lens.
Aug 31, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I need a replacement bayonet mount for the above lens.
Unfortunately your lens is one of the kit versions which were built as cheaply as possible with a plastic lens mount. They were never intended to be repaired, but to be fair they seem to last quite well.
Jul 29, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
May 11, 2009 | Alpine SPX-17MB 300 Watts MIDBASS Speaker...
Only power and pc/activity light are on.
Only thing to do is buy a new modem. Mine did the same after a power surge. Left it all night off and in the morning started working again.
a month later, another power surge and never started egain. Just got me a new one and called Comcast to activate it. Problem solved.
Good luck there
Aug 05, 2008 | Arris SURFboard SB5120 Modem
Problem with camara
Lens isn't working and need to be replaced.
Jun 07, 2008 | Cameras
Cameras Logo
18 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
