Question about JVC HD-61Z886 61" Rear Projection HDTV
I have a JVC 61"
  • JVC Master
  • 2,098 Answers
Hi clodfelter00,
Dim picture was a symptoms of lamp peak burning life and needs a replacement. Click this LINK to place your order online.
HOW TO REPLACE THE LAMP UNIT
(1) Turn off the TV power. (2) Disconnect the power cord from the AC outlet. (3) Loosen 1 screw from the rear side, then take out the the left speaker panel. (4) Loosen 1 screw then take out the lamp cover. (5) Loosen 2 screws then take out the lamp unit. (6) Install the new lamp unit. (7) Re-install the lamp cover. (8) Re-install the left speaker panel. (9) Re-install the screw to the rear panel.
NOTE: After installing the new lamp unit, do not forget to reset the lamp timer.
HOW TO RESET THE LAMP TIMER
(1) Press the [MENU] key to select CLOCK / TIMERS. (2) Select the with UP/DOWN key. (3) Enter the mode the message will appears. (4) Press the [OK] key while the above message appears on the screen. (5) Turn off the power, then turn on the power. (6) The lamp timer has now been reset.
Watch this VIDEO for more info.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 26, 2011
JVC HD-61Z886 61 picture is dark. Is this fixable.
Could be dust in your light engine or build up on your mirrors.
Jun 21, 2012 | JVC HD-61Z886 61" Rear Projection HDTV
Lamp needs to bereplaced,,,,, tv jvc model 61z886, need to know model of lamp i need and where to buy it
Google "DLP lamp" and you'll get many places from which to order lamps. Go to one of these sites and they should have a search box. Enter your model number and it should give you the part number of your lamp. Try several sites if the first one doesn't give you what you need to know. Once you have your lamp number you can shop the various sites for the best price. Note: You can buy your lamp complete (with the housing it comes in),..... or just the bulb and replace the bad one in the housing (cheaper)..... if you have the skills needed. If not buy it complete with housing. If you change the bulb only,.. don't touch it with your bare hands. Most bulb only packages come with rubber gloves.
Aug 24, 2010 | JVC HD-61Z886 61" Rear Projection HDTV
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
My jvc 56' flat screen is showing a message in blue to replace lamp but there still is a good picture?
Well, the message is trigger by the passing of time. The TV simply counts the hours the TV has been on, then when the counter hits the designated amount... the message starts to appear. Best thing to do is order a lamp and have it on hand. You can go into the TV menu and reset the lamp timer for now, just to get the message out of sight. When the lamp does fail, change the lamp and reset the timer again. I hope this was of some assistance, best wishes.
Apr 12, 2010 | JVC HD-61Z886 61" Rear Projection HDTV
I have a green hue to my jvc hd 61z886 61 rear
Hi
More than likely the lamp ,go to JVC website and get the part number for your lamp,google it and all the suppliers will come up,usually easy to change for customer and may be in your operation manual "how to"
Jun 04, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
How to replace bulb
Hi, i have retrieved your manual. it has all instruction on how to replace the bulbs. Click here for your manual.
A fix ya rating would be most appreciated. Thanks:)
Mar 05, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
Hdmi cable not working
You have a bad main board it sounds like.
Jan 06, 2018 | JVC HD-61Z886 61" Rear Projection HDTV
JVC HD-61Z886 61" Rear Projection HDTV Logo
54 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
