Question about Hobart Handler 125 Ez
My handler 125 has been setting in the garage unused a year or two. i just turned it on and it doesnt try to feed the wire out. any ideas?
    Genius:
  • 1,212 Answers
If you can see the tip of the wire, grab it with a plier, and pull. If it comes out easily, you need to adjust the tension on the feed wheel under the cover a little bit. Do NOT touch that adjustment with power on unless you are wearing good gloves, even then there is still a danger of shock as that is the point the secondary of the transformer ties to.
If it does not come out, open the cover,and look at the tension on the feed wheel- if it spins and no feeding, the welding wire may be jammed up or corroded to the liner of the handle. If it is all bunched up and tangled, that in itself may be the problem.
Posted on Dec 29, 2011
My welder feeds normal for the first 10 to 20 secs then struggles to feed wire. I have replaced feed tube and wire, adjusted tension both ways andput new tips, currently using .035 for.030 wire. I think it...
Depending on how old you machine is, its possible that the wire feed rollers are worn causing the wire to slip in the grooves. Replacing the WFRs may solve the problem. Test this by watching the feed rollers as you pull the torch trigger, place a gloved hand over the nozzle as the wire comes out and watch to see if the rollers slip on the wire when the wire meets the resistance of the glove. If it does that likely the problem. Hope this solves the problem.
Jun 19, 2011 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Welder pulsates
Hello, by pulsates, do you mean that the wire feed is what is pulsating while welding? If so, I have had this as well. I found that by turning down my feed rate, the pulsing stopped and the feed was smooth. I hope this helps. If not, contact me again.
joe
Jan 08, 2011 | Hobart Handler 125 Ez
Installed new spool wire tangled in wire feed compartment and stopped. Now wire feeder doesn't feed.
If the feed wheel mechanism does not move, check for voltage at the motor. If there is none present, you need to look for a failure on the control board, which may be a fuse, or even one of the SCR's. Often an 8 amp 200 volt type.
Jun 27, 2010 | Hobart Handler 125 Ez
Need to try and find a wire feed motor for Hobart 120 Handler.Mine is smoking.I think its a 1997. Thanks
go to praxair ,air gas s j smith or any welding shop they can get it for you,
Mar 16, 2010 | Hobart Handler 125 Ez
My wire dont feed out some time when i pull the triger
Inside your machine just in front of the wire spool is an adjustment to increase the tension on the wire tighten it a little bit at a time until your wire feeds
Feb 05, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Wire doesn't feed and I cannot get an arc
Fist look and check the contact tip. ensure the tip is the correct size for the wire being used as well as the wire feed rollers. the contact tip is were the wire collects the power,
If it's only 3 day's old send it back, dont star strippin it down or you Garantee will be made invalid.
ken
Jan 09, 2010 | Hobart Handler 125 Ez
My fm140a will not feed wire
You may need to adjust the tension just in front of the wire spool
Your gun liner maybe shot
Dec 28, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Wire feed motor not working
I believe the circuit card assembly has failed. It is very rare that the motor is the problem.
Sep 30, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
SNAP-ON FM140A MIG WELDER. HOW TO SET UP WIREING TO UPGRADE TO 30AMP OPERATION FROM 20AMP SYSTEM.
Hi, yes it can be ugraded but,( theres always a but,) you will need a feed from the mains to a rated connection on the main fuse box, this is not a DIY job, certain rules and regulations prohibit the unqualified. the new line will run to it's own fuse box, then to wherever you want, garage or w/shop with electrical cable 1.5biger than your max (30 amps) best be safe , you cooker socket is thirty amp, but thats max, there are some people that would increase the fuse size, ending up,( If they arel lucky), for a total re-wire those unlucky guy's arn't around to tell the tale. contact your provider and get it safe.
lets know how you get on
Feb 26, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Wire feeds too quickly
Some welders control wire speed with the amps control, some control amps with the wire speed control. You might try turning things up until it runs smoothly without pushing back. If you're new at welding, it does take some practice until it feels right.
Jan 15, 2009 | Hobart Handler 140 Mig Welder
Hobart Handler 125 Ez Logo
143 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
