Question about Motorola Cell Phones
Dropped my phone a few too many times. now when i shut the phone, the screen appears "blank" or not illuminated at all. keys are illuminated, but not the screen. still haven't gotten the id screen on the front to work right. but after taking battery out, and waiting a few minutes after turning it back on, top screen appears and works fine. did i pinch a cable or something?
  • gremwill Aug 16, 2008
    it is a motoroa razr v3 by the way.
  • Motorola Master
  • 1,800 Answers
Its the electronic belt that connect the screen to the keyboard is might be cutted or got a lil bit moved from its original place disassemble the phone and see what can u do about that if its cutted buy a new one and solder it its edasy u can
Posted on Aug 16, 2008
SOURCE:
Won't boot up. Error message "
did you try pluging into charger, my galaxy 2 if i run battery all the way down it wont do anything after it shuts down. at times i have had to plug in and wait sometimes 15-20 min before it will even flicker. hope it helps
Dec 31, 2012 | Cell Phones
My samsung galaxy s 4g will turn on but then just vibrates with a blank screen. I tried to reset it with volume down+ power but the reset menu doesn't come up
do this to wipe partition cache
  1. Turn off the phone
  2. Note: If the phone will not power down, remove the battery and reinsert it.
  3. Hold the Volume Up, Volume Down and Power Key simultaneously.
  4. Release the keys when the Android recovery screen appears.
  5. Press the Volume Down key to highlight Wipe Cache Partition.
  6. Press the Power key or Home key (this varies based on the software version of your phone) to select.
  7. The phone will display Cache Wipe Complete after a few seconds.
  8. Press the volume keys to highlight Reboot System Now.
  9. Press the Power key to select.
i advise you to back up everything first before doing master reset
Mar 28, 2017 | Samsung Galaxy S GTI9000 Smartphone
Blank Screen
Sounds like you have a broken LCD screen. Go to your carrier, they might replace the phone for you altogether for free or at a discounted rate. If they refuse,the only way to get it up and running again is to open your blackberry2_bing.gif to physically replace the part. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry curve Repair Guide that shows how.
Feb 05, 2010 | Verizon Communications BlackBerry Pearl...
My g1 has a blank white screen screen locked
I dropped my G1, picked it up and it was fine went home a few hours later starting going through my apps it started running weird then it shut off...I took the battery out and put it back in when i did that it vibrated telling me there was life in the battery but the screen stayed blank no G1 intro no android nothing...then screen is not black but a grayish white depending the angle you hold the phone at. I called my carrier we did the reset nothing happened its still stuck at the blank screen? Any help with this?
Sep 25, 2009 | HTC G1 Smartphone
Blank screen
Check screen settings, you may have Screen saver activated for too short period.
Sep 10, 2009 | Sony Ericsson K850i Mobile Phone
Sony Ericsson w580i. Dropped it screen blank and calls dont work
I had this same phone and the same thing happened to me. I kept shutting it off and on - also taking the battery in and out. I eventually got the screen to light up but it would only last a few seconds. Sorry to say but you will most likely need a new phone. I had to replace mine.
Jul 15, 2009 | Sony Ericsson w580i Cellular Phone
Power on/off problem
format ur phone by using code * + 3 + Call key + On/Off key till formatting appears, if this does not work u have to flash ur phone
Dec 14, 2007 | Nokia 7610
Cell Phones Logo
Top Motorola Cell Phones Experts
Ekse
Damen Wong
Damen Wong
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
