Question about Craftsman Garden
Looking for Owner's Manual for a Craftsman LT 1000 (model number 944.602151) lawn mower/tractor.
SOURCE: Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
Posted on May 25, 2010
  • 19 Answers
SOURCE: adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
Posted on Jul 19, 2010
  • 19 Answers
SOURCE: lost key to craftsman lt 1000, where can I get raplacement
sears has them on a hook where the filters are located.
  • 251 Answers
SOURCE: My craftsman LT 1000 lawn tractor will not start.
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
  3. Engine stalls immediately when started
    1. Check the ignition switch condition and operation. The electrical contacts in the run position may be worn or damaged. Try restarting the engine with all electrical accessories in the off position. Sometimes turning the key on an off will help in emergency situations, however once the switch has shown signs of failure, it should be replaced as soon as possible.
    2. Check for loose, corroded, damaged or shorted wires for the ignition system and repair or replace.
    3. Check for manifold vacuum leaks or vacuum hose leakage and repair or replace parts as necessary.
    4. Measure the fuel pump delivery volume and pressure. Low fuel pump pressure can also be noticed as a lack of power when accelerating. Make sure the fuel pump lines are not restricted. The fuel pump output is not adjustable and requires fuel pump replacement to repair.
    5. Check the engine fuel and ignition management system. Inspect the sensor wiring and electrical connectors. A dirty, loose or damaged sensor or control module wire can simulate a failed component.
    6. Check the exhaust system for internal restrictions.
Posted on Jun 07, 2011
richroth
  • 9472 Answers
SOURCE: I have a craftsman lt 1000 riding lawn mower and
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Posted on Oct 18, 2011
Owner manual for 917.258572 has no images on pages on belt replacement
Hi, I don't know about the exact model, but I've discovered that there is a much larger abundance of help on YouTube than on any manufacturers website. Videos seem to be much more educational, and you can replay them. Here's a link to get started.
Craftsman LT 1000 Mower Deck Belt Replacement wmv
May 14, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Repair manuel for craftsman lt 1000 mower
Call Sears. They do sell owners manuals for some models. Not sure if they sell any repair manuals but that's who to try.
May 19, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I don't have an owners manual. I need a new oil filter for Craftsman LT 1000
You need the model number off the engine. With the model number and the brand you can go to the local lawn mower repair parts shop and get the filter for that engine. But if you would like to send me the complete model number and the brand of your engine I will look it up for you to get you the part number so you know what to look for when you go to get it.
Aug 12, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Adjusting brake on Craftsman LT 1000 lawn tractor manual
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
103 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
