How do i disconnect the green picture tube in a Sony kp-65ws500 TV\
  • 373 Answers
Unplug the TV and take the back off and you will see a circuit board on each of the tubes located at the bottom of the tubes. The center one is the green. The board will slide off fairly easy but do not use extreme force. Gently rock it back and forth pushing down. Be sure when you get it off that the center board will not touch any other circuit or any grounds before plugging the tv back up.
Posted on May 26, 2011
I have a sony KP-65WS500 Ztv turns on but screen is blue with lines. I can hear sound but cant get tv on.the red light blinks five times.. Does anyone know what is the problem?
Can you confirm the actual model number of this set? Some had issues with the picture tubes being bad but depending on model number there may be a fairly easy way to adjust around this to correct the issue.
Apr 27, 2012 | Sony KP-65WS500 65" Rear Projection...
My sony kp 65ws500 has a all red picture. It looks fine otherwise. nothing i have tried has changed the color of the screen at all. Please help.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it dead.The tv convergence board must be replacing the 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Sony KP-65WS500 65" Rear Projection...
My sony KP-65WS500 had a bad red picture tube. So
It was probably my post--SD TECH--you may want to tweek the red screen a little up or down--if it still acts up it is the picture tube--
The adjustment procedure is only meant to help and not cure the problem--try to get it as good as you can and live with it.
I have been involved with replacing those tubes and it is no picnic--you remove one--send it out for rebuild and put it back and do major adjustments--usual cost for rebuild is near 300 JUST FOR THE TUBE--real problem is that sooner or later the two other tubes will start to act up.
I composed those instructions to try to give people an option--to buy them some time--the picture tube is what some call a bulb--one in the same thing.
Lots of these sets had all three tubes changed when under warranty--what really happened is Sony put the wrong tubes in the sets to begin with.
My best advice is adjust it as best you can and when it goes replace the set.
Regards, SD TECH
Dec 19, 2009 | Sony KP-65WS500 65" Rear Projection...
Kp-65w500 green flash... led blinks 8 times
I am going to guess that model number is actually KP-65ws500
This is one of group of Sony sets that had bad picture tubes---red, green, blue----the tubes are no longer available and can only be obtained by removing the bad one and sending it out for rebuild (very expensive)
There is one easy thing you may be able to do to correct this problem---It involves no replacement of parts and is just adjusting the Green screen control---usually if this is the case when set comes on background will be somewhat (in your case) green---best way to see this is turn set on and have it on a unused video input---if screen appears somewhat green and has curved retrace lines--you may be able to turn the Green screen control down and continue to use the set---set will shut down if any of the 3 picture tubes pulls too much current--ie--goes to bright green, red or blue.
Let me know if you want to know how to attempt this
SD TECH
Oct 03, 2009 | Sony KP-65WS500 65" Rear Projection...
How do I replace the lamp in my 65' sony rear projection TV
Sony KDP-65WS550 is rear projection TV that has 3 picture tubes inside. Let me know what bulb you are asking for help?
It is not DLP TV that has ballast Lamp for back light.
Jul 13, 2009 | Sony KP-65WS500 65" Rear Projection...
KP_65WS500 Tube numbers
Here is the part number for the blue tube B 07MVC61, the Red is R 07MVC61, and the Green is G 07MVC21. The number to contact the company that makes the tubes is 1-800-241-5005 Ext 143
Jun 15, 2009 | Sony KP-65WS500 65" Rear Projection...
Massive Convergence problems even after replacing IC's.
See a pico fuse HERE and find PS8001 to PS8006 on D board of TV
Mar 18, 2009 | Sony KP-65WS500 65" Rear Projection...
SONY KP-46C65 PROJECTION TV
we have repaired 100s of these tv..most have a flicker issuse and it is getting hard to find replacement tubes. the cost sounds right...I suggest to invest in a new tv.
Sep 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
