Question about Refrigerators
I AM WORKING ON A KENMORE 106-8617167 REFRIGERATOR,CAN YOU TELL ME WHERE THE LEADS FOR THE DEFROST BI-METAL GO?THE TERMINAL BOARD IS LOCATED INSIDE THE PANEL COVER FOR THE FREEZER
    President:
  • 1,654 Answers
This link will provide the instructions on this as well as many other fridge repairs and tests. Once at the site simply look over the parts and repair lsist as well as schematics and many other tips. Basically on your fridge once you get acces to the leads that are connected to the board they simply unplug and plug in on the board. There are tips on how to remove the panel as well.
This is a very helpful page with lots of information I hope this is what your looking for.
www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on May 26, 2011
Freezing up
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Jun 21, 2012 | Kenmore Refrigerators
Freezer working but refrig not cooling
Jun 19, 2012 | Kenmore Refrigerators
My kenmore refrigerator model 56544400 is not as cold as it should be.
Jun 02, 2012 | Kenmore Refrigerators
Is not cooling properly
Kenmore fridge model l63250759 not cooling good at the bottom temp is 52 degree
Jun 01, 2012 | Kenmore Top Freezer Refrigerator
Kenmore Coldspot Model 106.71182100
May 29, 2012 | Kenmore Refrigerators
I'm getting frost in my freezer and loosing temperature in my frig
Hi, Unplug the refrigerator. The automatic defrost is not working properly. You will need to remove the rear panel inside the freezer section and test the defrost heater and bi-metal switch. The bi-metal switch located on the top of the evaporator coil needs to be tested while it is still cold. Check and see if the switch has continuity. If the bi-metal switch shows an open circuit, replace it. If it shows a closed circuit, test the defrost heater the same way. If both the defrost heater and the bi-metal switch are ok, the defrost timer will need changed.
You will need to defrost the evaporator coils with a hair dryer. Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Aug 14, 2009 | Refrigerators
I have a whirlpool side by side model #GD5YHAXNL.
Hi, The frost you are seeing is because the self defrosting cycle is not working. Remove the rear inside freezer panel and test the defrost heater and bi-metal switch for continuity, Ifeother part does not have continuity, it will need replaced. The bi-metal switch is the most common problem and is located on the top of the evaporator coil.
If both of these parts prove ok, the defrost board will need replaced. The defrost board is located in the fresh food section in the control panel.
I hope this helps you. Please let me know if I can assist you further with this issue.
Thanks
Vic
Jun 27, 2009 | Refrigerators
2001 top freezer won't defrost
Hi, You will need to check three different parts of the defrost cycle. The most common problem is the bi-metal switch. UNPLUG the refrigerator and remove the rear inside freezer panel and locate the bi-metal switch attached to the evaporator coil in the upper corner. You will need a voltage/ohms meter for this test. Check the switch to see if it has continuity. Note: This switch has to be cold in order to test it! If it tests open circuit, you will need to change the bi-metal switch. If the bi-metal switch tests ok, then test the defrost heater the same as you tested the bi-metal switch.
IIf both of these parts test ok, you will need to change the defrost timer.
Please get em a model # and I can assist you on locating the timer.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 29, 2009 | Kenmore 64802 Top Freezer Refrigerator
Freezer side not freezing
It appears that the defrost bi metal control is hanging up and during the defrost the temp in the freezer is going too high. It is supposed to terminate the defrost at around 50 degrees. This usually occurs in about 20 minutes, if the defrost heater stays on for too long the freezer temp goes too high. Change the defrost bi metal
Jan 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
