Fuji FinePix F460 Digital Camera Logo
Posted on May 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn on my camera, it shows a black screen, so I'll take a picture anyways and its black.. no picture ..is it fixable or should I throw it away? Next to where the flash goes off..there is a light that should go on but doesn't so that might be the problem ...I can still see pictures that I have taken in the past.
Anonymous
Level 3:
  • Master 43,501 Answers
  • Posted on May 26, 2011
Anonymous
Master
Level 3:
Answers
43501
Questions
0
Helped
10844329
Points
101584
Is the lens protector opening in the front of the lens???
If it is and things are still black then throw it out... it will cost more then it is worth to fix...
Lens Errorfix for Digital Camera
heatman101
1helpful
Turn on the camera, the start screen shows up and slowly turns to black. I don't see a thing. I tried to take a picture and check it using card reader, I saw picture I took was very clear on my co
Hello, On the C743 this will require that the LCD unit be replaced. This will get very costly real quick unless you can do it yourself. Not much more I can tell you.
Best Regards, Russell
My pentax k1000 has a black splotch in viewfinder, does not show up in images.
It would depend on exactly where the splotch is. If it's on the outside of the viewfinder, you could simply clean it off with a damp cloth (and maybe some Windex or Formula 409). If the eyepiece is damaged, you can order a replacement part here.
Remove the lens and look at the mirror. If their is something on the mirror, you can carefully clean it. The mirror is very sensitive and vulnerable to scratching. If the reflective coating has been removed then you'll need a new mirror.
Look up at the bottom of the focusing screen. That's the more-or-less clear piece of glass that the mirror will reflect light from the lens onto. If there's a splotch on the outside, you can clean it off.
Those are the parts you can get to. If the splotch is on something on the inside, then you'll have to take the camera to a good camera shop to have a trained professional disassemble and clean it.
Olympus vn8500pc will not turn on...
This is a digital voice recorder, not a camera. Try posting this query in the office equipment forum.
Apr 21, 2017 • Cameras
My pictures have lines across the screen in the viewer and are also sometime dark. this happened suddenly. The message boards point to a shutter problem with this camera. Is it fixable, worth fixing, a...
Sound like a malfunctioning CCD-image sensor. Rare, but possible problem with your LCD screenviewer... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Samsung service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
2helpful
Blank screen when taking a picture
Yes it is. Press the DISP button on the back of your camera. This manually turns the screen on and off to save batteries.
Camera dropped in pool.
Throw it away and buy the next one- keep this one away from water.
I keep getting a black screen when i try to take a picture
Not fixable - check Olympus for a repair estimate - be prepared to junk it and start over
1helpful
Black Screen/Viewfinder
Mine too! Thank you so much for posting this issue!!
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
