Question about Verbatim Acclaim 750GB Portable USB 2.0 Hard Drive
My mac recognizes the verbatim hard drive, then says it was unplugged incorrectly, then recognizes it, then says it was unplugged incorrectly, etc. in a continuous loop. I have purchased two of these hard drives and it is doing the same thing with both of them.
  • 343 Answers
Make sure that you are connected to a usb port on your computer and not thru a usb hub. Also try a different port on your computer. It is unlikely that two hard drives would be bad, but I would try them on another computer. Thanks for using fixya
Posted on May 26, 2011
Why wont windows recognize my verbatim 500gb serial no JB0094011152
Go into Device Manager and if it doesn't appear there click "scan for hardware changes". If that doesn't work, makes sure you have plug and play enabled. Always use the safely remove hardware option when unplugging it.
Jul 11, 2016 | Verbatim 500GB USB Desktop 500 GB Hard...
Verbatim customer service
MACs does not recognise windows NTFS format. So backup the data (if exist) and format drive to FAT32 or ExFAT.
Jul 31, 2014 | Verbatim SmartDisk USB1TB 1 Terabyte 1TB...
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
Maunual and drivers for the portable verbatim 120 hard drive
hard drives don't require any special drivers. Windows/Linux/Mac can recognize them with their respective built-in drivers. If your computer isn't detecting it. One of a few things
  • The drive isn't initialized (Windows)
  • The drive isn't partitioned
  • The drive is corrupted
  • Physically damaged
I can post a video if needed to fix the first three
Dec 19, 2012 | Computers & Internet
My mac does not recognize the verbatim 1.5tb drive any more. drive is less than two weeks old
> less than 2 weeks old
Take it back to where you bought it, and exercise the WARRANTY to get it repaired/replaced.
Dec 31, 2010 | Verbatim Computers & Internet
I am trying to write files to a terabyte verbatim portable hard drive, but it saids the drive can not be modified. How do I write to the verbatim hard drive on my mac?
Most verbatim drives are formatted to by default to NTFS which is a windows file system. NTFS can be read and copied from on Mac but not written to.
You will need to offload the data to one of your computers and reformat it with the mac.
Apple, Utilities, Disk Utility.
Once formatted for Mac you will be able to read and write to the drive but you will need to add macdisk to the windows PC to allow it to read and write to a Mac formatted disk.
I more information on my FAQ about recovering data from Mac drives on PC
http://www.aitsavemyfiles.com/datarecoverybasics.php?faq_id=6545&category_id=8247
Hope this helps FixYa,
Crankstart
Mar 22, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I bought a Verbatim Clon USB Portable HardDrive to back up files from my Mac Computer. When I click and drag, I get this pop up " items can't be move because verbatim can't be modified." It says the hard...
You have to partition your Verbatim Drive to work on a Mac. Go to Macintosh HD / Applications / Utilities / Disk Utility. When in Disk Utility select the 232.9 GB SAMSUNG HM250HI Media to the left.
Dec 19, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
My Verbatim suddenly stopped working on my Mac OS
It sounds like your hard drive is damaged. Hard drives are very, very dilicate pieces of machinary. The disk is paper thin and any sudden jarring, especially dropping it creates a warp in the drive. It could also be just a mechanical failure. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Jul 13, 2009 | Verbatim VER95327 USB Hard Drive
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Verbatim Acclaim 750GB Portable USB 2.0 Hard Drive Logo
162 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
