Question about Frigidaire Microwave Ovens
I have a frigidaire Electric Range PGLEF385ES3, everything worked fine last night on the stove top and the oven. I went to use the stove top tonight and all the burners are not heating and the oven does not work as well. The lights all work showing that the burner/oven is turned on and the clock is working. Tried unplugging the stove and it still is not working. Any suggestions.
  • Frigidaire Master
  • 1,902 Answers
Hello & Welcome to FixYa
If you have already left the unit unplugged for 15 minutes and the problem is still there then it means that the clock/timer assembly has gone bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on May 26, 2011
Top stove micro wave-everything works but do not heat the food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 09, 2011 | Frigidaire FMV156D Microwave Oven
Do you know what the average electric cooktop lifespan is? We have a Kenmore that is 9 years old and working fine. However, we are in the midst of a renovation and are wondering if it wouldn't be wise to...
The life span of the range depends on it's use or abuse.... Common issues are burners and the connections that the burner plugs into. These are not hard to change out.... There is nothing that can make the stove useless, if you keep after it. Newer units do a better job of retaining the heat within the unit, oven wise....Which is nice.
A gas range is certainly nicer, so they say. It is faster, but has one odd issue: if you boil water over, you can put out the flame and have raw gas running in. Most work this way, expensive units have thermal sensors that would turn off the gas flow in flame out condition....
My wife loves her gas range....
Mar 08, 2011 | Microwave Ovens
Doesnt heat
heatman101
hfjjf
May 13, 2010 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
11 yr old range/oven ; oven stopped working (clock is out and everything) : stove top is fine. Major expense ro fix ? Am I better off getting new one ?
your clock controls the oven functions. replace clock. probally a little cheaper than a new range but depends on service call fees and labor
Jun 22, 2009 | Kenmore 63792 Microwave Oven
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Fridgedaire stove top micro oven
Blown 20 amp fuse inside the cabinet. You could try just replacing the fuse, but experience on these says that it blew out for a reason. Something has shorted out inside the cabinet; magnetron, transformer... I highly recommend contacting a local appliance repair company and have them come diagnose this for you. They'll have to remove it from above the stove to gain access for diagnosis, big job! I know this is not what you wanna hear, but they are trained on these and have the necessary tools for removal and proper diagnosis. (plus, if they mess anything up getting it down from there... they are insured) To make things go faster, remember to tell the dispatcher that it's an over the range microwave... this way, the tech will be sure to bring the necessary tools on the first trip.
Sep 25, 2007 | Frigidaire PLMV168 Microwave Oven
Microwave Ovens Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
