Question about Technics SL-1210 Turntable
Got the chance of a 1210but it has the following fault the turntable spins at 100 bpm, which means the signal from the motor to magnet needs restoring, and it needs a fuse Anyone know if this sounds correct and is it easy enough to do? Cheers Gerry
  • Technics Master
  • 5,158 Answers
I would be careful of getting this machine. The motor problem could be feasible. But if it needs a fuse that shows that there could be an overload in the power supply, which could be caused by the transformer or any semiconductor going short circuit. A transformer would cost a lot of money and that's if you can get one!
Posted on May 26, 2011
CDJ800mk2
better take it to the dealer and get it changed since you have the warranty for it.
Jul 29, 2008 | Pioneer CDJ-800MK2 Turntable
Hitachi washing machine sf6500px washes ok but wont spin, digital signal says dE, does anyone know what that means please?
im not 100% on hitachi gear dont see alot where im from, but for most washing machines DE normally means the lid is open as they have small magnets in both the lid and frame of the washer, most machines will not begin to spin if the lid is not shut they will fill and wash but not spin purely as a safety precaution, if the lid is shut it means the lid (you may have a latch that actually locks the lid shut or just a reed switch magnet sensor that simply detects if its opened) reed switch or lid lock is broken or faulty normally pretty quick and easy to repair
Jan 18, 2011 | Sprint Hitachi P300 Cellular Phone
Motor problem?
If its still working then GREAT! The direct drive system uses magnetic frequency to drive the table platter. If you havnt already....Remove the platter and clean the coke off the magnet under it. Not sure at this point but hope that helps!
Apr 04, 2010 | Technics SL-1200MK2 Turntable
My hp clj 2600n printer wont stop reading initialzimg on control panel machine not spinning
This is the Power On Sequence
Power-on sequence
The power-on sequence is for the purpose of the printer initialization and checking for possible malfunctions.
The following is the sequence from when the printer is turned on until it enters STBY mode.
  1. Power on
  2. Central processing unit (CPU) initialization
  3. ASIC initialization
  4. Video interface communication start
  5. Residual paper check by each sensor signalling paper presence
  6. Initial drive for main motor, pickup motor, and fuser/delivery motor
  7. Fuser heater initial drive by controlling fuser temperature targeting for 100°?C
  8. Initial drive for scanner motor
  9. Failure/Abnormality check
    • Detect scanner failure
    • Fuser failure
    • Door open during the above periods
  10. Communication with memory tag
  11. Cartridge presence detection
Main motor failure detection
The CPU determines the main motor failure, stops the printer, and notifies the formatter of error
status, when it encounters the following conditions.
  1. Main motor start-up abnormality.
The interval of the MAIN MOTOR SPEED DETECTION signal (/MAINMFG) does not become the specified interval after 1000 ms of the main motor drive start.
  1. Main motor rotation abnormality. The interval of the /MAINMFG signal stays at an irregular interval for 100 ms and longer after once it has become the specified interval.
Fan motor failure detection
The CPU determines the fan motor failure and notifies the formatter when it encounters the following
condition.
The FAN LOCK signal (FANLCK) is “H” for approximately 10 seconds and longer during fan motor
rotation.
Your description makes it sound as though the printer has a main CPU failure as all other faults should display an error or error code. In the light of this it seems that the printer will need to be looked at by a service engineer asap.
Sep 21, 2009 | Office Equipment & Supplies
Turntable not rotating
HI, the turntable motor is weak and failing at this point, simply replace this damaged motor. this will eliminate this distraction.
Jul 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver XL
fixed the problem with my GE microwave turntable motor without having to replace it.
I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate.
Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ‘bumps’ on the underside of the gear on top and washer on the bottom.
Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place.
If this worked for you please let me know – karlet@bellsouth.net
Jun 20, 2009 | GE JVM1339BW/WW Microwave Oven
No turntable
I fixed the problem with my microwave turntable motor without having to replace it. I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate. Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ?bumps? on the underside of the gear on top and washer on the bottom. Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place. If this worked for you please let me know ? karlet@bellsouth.net
Jun 18, 2009 | GE JE1860 Microwave Oven
Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
http://www.youtube.com/watch?v=rPSWi_z7M58
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Mar 14, 2009 | Microwave Ovens
Turntable not turning
Sep 11, 2007 | GE JTP85 Electric Double Oven
Technics SL-1210 Turntable Logo
21 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
