Question about KVH Additional M2 Or M3 St Receiver Kit Includes Splitter
RF Remote Problem
I am having a problem with a KVH M3 Marine Satelite Receiver. The RF Remote works sometimes but only within a range of around 6 feet. Very frustrating. It should work no problem through the one wall that the signal needs to go through. The RF antenna is outside of the cabinet that the receiver is mounted in, but the remote still won't work from more than 6 feet away. I've tried new batteries and also purchased an IR to RF convertor. but can't use it because the satelite receiver doesn't even have an IR sensor on it. Any ideas?
  • DC Media Aug 18, 2008
    The satelite receiver is specifically designed for marine use, so it should be able to handle all of the other electronic interferences. Has anyone dealt with this problem before. Bad RF transceiver? Bad remote?
    I'll try a universal remote to try to nail down the problem. I'll have to find the right RF frequency to match the transceivers frequency...I'll let you know
    Scholar:
  • 163 Answers
For added convenience, the TracVision M3's remotecontrol uses an RF signal, rather than the IR signal standard to homereceivers, allowing the remote control to change channels even if thereceiver is safely and stylishly tucked away in a cabinet or stateroomcloset.
http://www.spacemart.com/reports/KVH_Unveils_Worlds_Smallest_Stabilized_Marine_Satellite_TV_System.html
If warranty has not expired ask dealer to repair or replace it
Posted on Aug 18, 2008
    Brigadier General:
  • 6,966 Answers
May I offer an alternative view...
It is not that the KVH's RF remote receiver is affected by external interference, it is a limitation of the RF Power output of the remote control so as not to cause interference. The primary reason KVH opted for an RF type remote is to allow use even when the receiver is inside a cabinet. I was made to understand that a competitor, SeaTel, makes use of combo IR/RF on some of their versions.
A clarifying questions pls, your post "The RF antenna is outside of the cabinet", are you referring to the dome antenna (satellite receiver) or a small antenna for the remote receiver? If it were for the remote receiver, a possible workaround is to install a reflector behind the antenna so as to improve its forward gain (db) and therefore increase receiving range.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Sergeant:
    Champion:
  • 298 Answers
It could as simple as a bad remote , i have run in to that before
i used to install satellite systems and home theater systems aswell
bad remotes are common.
contact the manufacture they may replace it free.
    Master:
  • 521 Answers
Check the signal is being blocked somewhere.change the position.
  • 928 Answers
The thing here is you cant really say its a bad transceiver or remote since it works. Would it be possible for you to use a universal remote instead of the one that you are using so you might have a point of comparison?
  • 876 Answers
Could anything other electronics be interfering with the signal?
I have two RC65RX remotes set for RF. One operates the DVR from one room and the other operates it from another locally. Both remotes have a problem with making the receiver work properly. If for example I...
On r15s, for rf, you need an antenna on the remote f-connector. I usually took coax with one connector on it and the other end strip 6 - 10 off with only center conductor exposed. The rf board is on the same board as the modem. Not the front panel board. Frequency is roughly 413 - 417mhz. All coded by the last 6 of rid number.
Dec 26, 2013 | Directv Used Original RC65X Remote Control
Can not locate satellite continues to search
There are few possible reasons.
Antenna can't "see" satellite.
Wrong data programmed.
Wrong skew angle.
Damaged RF board.
If you make log-file it will be much easy to understand your problem.
Jun 26, 2013 | KVH 01 0277 01sl Tracvision A7 Mobile...
Remote control not recognizing codes
Codes for many of our TVs can be found at InsigniaProducts.com. For the Blu-ray player, we recommend using your universal remote's scan or learning feature.
Apr 28, 2010 | Hughes HRMC9 Remote Control
What is the best marine satellite system
Intellian for ease of installation and leading edge technology. KVH seems built better, but the Korean Intellian i2 is really reliable and cheap! Plus it is a really easy install, especially for HD.
Jan 03, 2010 | KVH Tracvision M3 Satellite Tv System
My KVH M3 will not lock on to a satellite, when I run anttena diagnostics everthing is OK except RF Low: 500 and I do not know what this means
RF low means low signal from dish. Maybe blocked satellite, maybe poorly crimped coax, maybe bad sat receiver. Most likely, bad coax crimp!
Dec 23, 2009 | KVH Tracvision M3 Satellite Tv System
Not tracking satalite.
If you can hear the dish actually serching when it says "searching", there is a good possibility that you have a bad LNB on the dish. Unfortunately, this is not the only thing that can cause the problem. Your best bet is to call KVH @ 4018473327. Make sure you are on the boat when you call and they will run you through all of the programming checks to narrow down your issue. Good luck.
Sep 01, 2009 | KVH Tracvision M3 Satellite Tv System
I have a Direct TV box and just bought a Direct TV remote with RF antenna. I have attempted to program the remote to work in RF mode, but for some reason it's not accepting the programming. The remote...
Connect the supplied anttena on the reciever. Once you have done that, then:
1. dtv symbol device
2. press and hold MUTE & SELECT for two blinks
3. enter 9 6 1
4. press CH UP
5. enter the last 6 digits of the Receiver ID #, found on a sticker in the access card compartment
6. press SELECT
Now the receiver will accept both IR and RF, but the directv device on the RC32RF remote will only emit RF signals. The av1, av2, and tv are all still IR only.
Jun 22, 2009 | Televison & Video
URC-9910 remote: The RF part for this remote stopped working.
I have the same remote as yours and occasionally the RF remote is not working due the interference signal from outside or next door at certain hours.
My suggestions:
(1) To relocate the receiver and reposition the anntena for better reception of the RF signal from the remote unit.
(2) Replaced the battery.
Hope these help!
Aug 04, 2008 | One For All URC-9910 LCD Remote Control
IR frequency determination
The remote could be using RF, which is why your Niles equipment cannot handle it. There is no way to duplicate the RF or convert it to an IR signal.
If the remote is using IR, make sure the batteries are full and the light is low when you are learning the codes with tne Niles equpment. There is no way if it's IR that the freq is > 100.
Apr 22, 2008 | Televison & Video
KVH Additional M2 Or M3 St Receiver Kit Includes Splitter Logo
196 people viewed this question
Top KVH Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a KVH Boating Expert? Answer questions, earn points and help others
