Question about Vulcan AUW230A Heater
How do I get the front of a vulcan built in gas heater. It is an older type heater that has the no lighter for the pilot. We just need to restart the pilot.
  • deborah_c193 May 26, 2011
    Joe - thanks but we live in a regional area and origin don't offer this service.
    Do you have any instructions in the actual removal of the covers to access the pilot light area, as I asked in my request.
  • deborah_c193 Jun 06, 2011
    Interesting but I do know how to use a screw driver.
    The issue is where are the pivot points to remove the cover to access the screws and then the pilot light.... The cover seems to be spring loaded, with a locking mechanism....
    I am not impressed by your customer service level to date...
    I will not be recommending your service to others, but the opposite.
  • 1,238 Answers
Good day!
if you need the instructions in the actual removal of the covers to access the pilot light are.
Just unscrew the cover by using screw driver.
If you still don't remove the cover just look for the possible lock inside to access the pilot light.
Thank you
Posted on May 26, 2011
  • 10,865 Answers
Hello deb.... your best solution is to call your gas provider. they have a free service whereby they come to your home and do a safety check of your heater. then they instruct you on the best way to light it etc. Joe
Can't light pilot due to breeze coming out of unplugged gas wall heater
It sounds like you have a direct vent heater so you have to take off a pilot access cover to light the pilot. So what happens is the draft coming out of the cover is blowing out the match before you get it in the hole. The trick is to get the match or lighter in the hole quickly as possible so the pressure inside the heater will equalize and the match will stay lit. Then you should be able to lite it. Get it inside the hole fast and it will work. Don't forget to put the cover back over the pilot access or the draft may cause the pilot to go back out.
Feb 10, 2018 | Empire Heating & Cooling
Pilot light is lit but won't turn on water heater
What band and type water heater do you have? And about how old is the water heater? Add a comment with more information.
Following general information applies to tank-type residential water heater.
If pilot light is working, then thermocouple is good. Otherwise, if thermocouple was bad, or fallen out of place, then there would be no pilot flame.
Carefully read instructions for lighting water heater located on front of tank ... make sure you have the gas control valve set to ON.
At this point, troubleshoot varies widely depending if your water heater is older and air enters front of heater, or if water heater was made after 2007-9 and has sealed combustion chamber and FV system.'
Troubleshoot also varies widely depending if you have power vent and which type of gas control valve.
Copy following link for troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Also post detailed question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 16, 2012 | Whirlpool Water Heaters
Vulcan wall heater gas issues...
The igniter may be bad and needs replacing.
Jul 01, 2017 | Vulcan Heating & Cooling
Hi i live in reservoir melb vic i have a old vulcan fireplace gas heater Cat 9-14 1972 seriel no 4442. AGA OR ALP GA App no 1805-002 It has 5 white heat elements behind the glass front approx...
The part you described is the heaters Control Valve for your Infrared Gas Heater. It is an expensive part to replace. If one is still available for your older unit.
You failed to mention where (what country you're in), but Vulcan has been popular in Australia for many years, So I'm assuming you're in Australia.
Below is a link to contact information for Vulcan in Australia, b region. Hope this helps you find a service technician.
http://www.vulcan.com.au/contact.htm
l
Jun 01, 2011 | Heating & Cooling
I have purchased a house with a Vulcan gas space heater. The pilot light was on but since the gas was temporarily turned off I can not turn on the pilot light. I am in Adelaide South Australia.
you have air in the gas line , the pilot being so small it would take ages to come through , you need to purge the line to get the air out , se if you can undo the pilot line to pruge it
Oct 14, 2010 | Vulcan Heating & Cooling
Pilot lights but won't stay on in my older style vulcan space heater. thermo couple was replaced last year.any ideas that i could try thanks
Most common cause of pilot light problems is air movement. If your space heater exhausts gas through the roof, ensure the cap is on and level. If not, outside air movement will blow out the pilot. If you do not have an exhaust gas duct, check that the unit is positioned so that it does not blow air back onto itself from walls, furniture, etc, and ensure no other devices that move air are aimed towards the unit. The unit also needs to be placed away from central ducting, including return vents.
Hope this helps!
Aug 09, 2010 | Vulcan AUW230A Heater
How do you light a pilot light for my GE gas dryer? Model = DDG7188PHLWH
How old is your dryer? Only models from the 1980's and older have actual pilot flame lighters. If it's newer it will have either a spark igniter or an electric glow bar. If you have a large front access panel across the bottom, then you may have a pilot light. Remove the panel and look for the gas valve. (NOTE: Before lighting anything, make sure you do not smell gas. If you do, you'll need to air the room out before trying) There will be a burner coming out the back of the gas valve control and this control will have a red push button in the front or side of it to allow gas to the pilot only. Using a extended bbq type lighter, light the pilot at the pilot assembly and hold the button for about 60 seconds. The pilot assembly is connected to the gas valve control by a small diameter aluminum tubing with a copper thermocouple right next to it. Release and make sure the pilot stays lit. Before putting the access panel back on, turn on the dryer and watch for the burner to light. It should be a strong blue flame. Let us know if we can help you further. Not knowing why your pilot went out in the first place, there may be a unforeseen issue that may need attention. If you have a propane gas dryer and you ran out of gas, then it may take a while to get gas to the pilot, so be patient when trying to light it. Never hold the button down without the lighter lit at the pilot assembly, so there is not a build-up of gas. If you are not comfortable doing this, I recommend you call your gas co to light it for you, as many will do it for free! Good luck and be careful!
May 20, 2010 | GE Dryers
Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
Have a 20yr + old vulcan gas heater and I cannot turn pilot off
Hi, If you are talking about the knob on a gas valve that you use to light the pilot and turn it off also, you have to turn the knob either ccw or cw to turn it off. To light the pilot is when you turn the knob to pilot and push down and hold it, light the pilot while you continue to push it down for a minute, and then slowly release it and pilot will stay lite. So, if this is the type you have just turn knob one way or the other and it will shut off. If you do not have this type set up, just turn off the gas to the furnace at the flex line as there should be a hand valve by code and by law that supplys gas to you're furnace. You can shut it off there and the pilot will also shut off.
Sincerely,
Shastalaker7
PS If you don't have either one of these shut off's, on the main gas valve it self, you should have a place marked pilot adjustment. Pop the small chrome cap and insert a very small screw driver to turn it cw to shut off pilot.This would be you're last choice.
Jan 19, 2010 | Heating & Cooling
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Vulcan AUW230A Heater Logo
162 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Oloyede Monsuru
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
