Question about Esker VSI-FAX
Have a windows 7 64 bit o/s running VSI Fax ver.6.1 and right fax software when my user tries to send a fax from outlook 2007 she gets no pop up box with status bar she then gets a confirmation message not from VSI fax but from right fax followed by a message stating that the fax was not sent
3 Suggested Answers
MohitdTechno
  • 43 Answers
SOURCE: How to create an object of VSI-Fax like in winfax
For VB
Private Sub Form_Load()
Dim sendObject As Object
Dim ret As Integer
Set sendObject = CreateObject("Winfax.SDKSend")
ret = sendObject.SetSubject("TEST!!!")
If (ret = 1) Then
MsgBox ("SetSubject Failed")
End
End If
ret = sendObject.SetKeywords("Test")
If (ret = 1) Then
MsgBox ("SetKeywords Failed")
End
End If
ret = sendObject.SetResolution(0)
If (ret = 1) Then
MsgBox ("SetResolution Failed")
End
End If
ret = sendObject.SetQuickCover(1)
If (ret = 1) Then
MsgBox ("SetQuickCover Failed")
End
End If
ret = sendObject.SetCoverText("This is a Test.")
If (ret = 1) Then
MsgBox ("SetCOverText Failed")
End
End If
ret = sendObject.SetUseCover(1)
If (ret = 1) Then
MsgBox ("SetUseCover Failed")
End
End If
ret = sendObject.ShowCallProgress(1)
If (ret = 1) Then
MsgBox ("ShowCallProgress Failed")
End
End If
ret = sendObject.SetTo("Somebody")
If (ret = 1) Then
MsgBox ("SetTo Failed")
End
End If
ret = sendObject.SetNumber("#######") 'My fax number
If (ret = 1) Then
MsgBox ("SetNumber Failed")
End
End If
ret = sendObject.SetAreaCode("###") 'My area code
If (ret = 1) Then
MsgBox ("SetAreaCode Failed")
End
End If
ret = sendObject.SetPriority(1)
If (ret = 1) Then
MsgBox ("SetPriority Failed")
End
End If
ret = sendObject.AddRecipient()
If (ret = 1) Then
MsgBox ("AddRecipient Failed")
End
End If
ret = sendObject.LeaveRunning()
If (ret = 1) Then
MsgBox ("LeaveRunning Failed")
End
End If
ret = sendObject.GetRecipientCount() 'this shows 1
MsgBox ("Recipient Count: " & ret) 'recipient
ret = sendObject.Send(1)
If (ret = 1) Then
MsgBox ("Send Failed")
End
End If
End Sub
If u like that Appreciate me by giving vote.
And try to be little specific while u ask question, that means, if u want code on any object ask for which language u r in need of?
Posted on Oct 19, 2009
SOURCE: I am using VSI fax
iv had the same problem also with a multi-tech comm modem, only way i'v found to get the problem fixed is to restart the server and run command vfxserver start
Posted on Oct 31, 2011
Fax driver missing
Microsoft Office 2010 has a feature that lets you send Outlook, Word, Excel, and PowerPoint files as Internet faxes. This feature relies on having the Windows Fax Printer Driver or Fax Services installed on the computer to send the faxes. The Windows Fax feature is not enabled by default for all editions of Windows. If your edition of Windows includes the driver or service, you must install it before you can send Internet faxes.
Which operating system are you using? Windows 7
  1. In Control Panel, click Programs, and then click Programs and Features.
Note In Classic view, double-click Programs and Features.
  1. Click Turn Windows features on or off.
  2. In the Windows Features dialog box, under Print and Document Services, select the Windows Fax and Scan check box.
  3. Click OK.
za010077668.gif Top of Page
Windows Vista The Windows Fax Printer Driver is included in the following editions of Windows Vista: Business, Enterprise, and Ultimate.
  2. In the Windows Features dialog box, select the Windows Fax and Scan check box.
  3. Click OK.
Windows XP
  1. In Control Panel, click Add or Remove Programs, and then click Add/Remove Windows Component.
Note In Classic view, double-click Add or Remove Programs.
  1. In the Windows Component Wizard, select the Fax Services check box.
  2. Click Next.
Windows Server 2008 To create a fax server, you must install the Fax Server role. This installs the Fax Server role page, Fax Service Manager, Windows Fax and Scan (with faxing capabilities only), the Fax service, and the Fax printer.
  1. In Control Panel, under Programs, click Turn Windows features on or off.
  2. Right-click Roles, and then click Add Roles.
  3. In the Add Roles Wizard, under Select Server Roles, click Fax Server role.
Note If Print Services are not installed, you are prompted to install it.
  1. Click the users or groups that you want to send faxes.
  2. Click who you want to have access to the fax server inbox.
  3. Click Install.
Windows Server 2003 The Fax Service is included in all editions of Windows Server 2003 except the Web edition.
  1. In Control Panel, click Add/Remove Programs.
  2. In the Add/Remove Programs dialog box, click Add or Remove Windows Components.
  3. In the Windows Component Wizard, select the Fax Services check box, and then click Next.
  4. If you want to share the fax printer so that everybody in the network can send and receive faxes, click Yes.
  5. Click Finish.
Click here for fax driver
Jul 26, 2011 | Office Equipment & Supplies
Three users of Outlook 2007 shut down their computer and the next time they turn them on, they get the error message "A data file did not close properly" in Outlook and Outlook check's its...
Are you using any trend micro anti virus? If so, try the following
1. Open your Outlook 2007
2. Click on Tools.
3. Click on Trust center.
4. The Trust center window will pop-up and click on Add-ins on the right part of the screen.
5. Under Manage: COM Add-ins
6. Click on Go.. (Middle bottom part of screen)
7. Uncheck all the Add-ins Exept for TMAS (TMAS is Trend Micro) then Click on OK.
7. Restart your computer.
Or if using a anti virus program and you see that in the "add in" options just substitute.
The following link has some problems and solutions for that event ID you gave.
Click here
Regards,
G33k
May 05, 2011 | Computers & Internet
I'm trying to configure outlook 2007 with my yahoo. I through the set and manually configure it. I get to the finish part, but I can't send or receive message the network log on box keeps popping up. I get...
To read Yahoo mail with Microsoft Outlook you must be a Yahoo Mail Plus user, this is a paid service.
Should you sign up for Yahoo Plus there should be no further issues setting up your software.
May 05, 2011 | Microsoft Office Computers & Internet
I am using VSI fax on a server running Windows Server 2003 and I have recently had problems with the modem loosing connection with the com2 port. Is this a problem that occurs with vsi fax? Also, my...
Apr 10, 2011 | Esker VSI-FAX
What ''Fax server'' is good?
1) The first is the obvious one....Microsoft Windows 2003 Server! 2K3 server has basic fax services built right into the O/S for free. This is the perfect solution for a small office such as a real estate office or doctor's office. All you need is a basic fax/modem in the server, and you're ready to go. Server 2k3 can be configured to route faxes to a particular email address, print the faxes to a network printer, or store the faxes in .TIF format on a network share, or any combination of the three.
The disadvantage of this setup is that it does not distinguish between users or phone numbers. ALL incoming faxes will be routed to the same email address. Again, this is why I say it is perfect for a small office. My smaller customers use this method to simply route all faxes to a receptionist, who in turn reads the fax, figures out who it's for, and then forwards it on to the appropriate recipient. The fax server does not support multiple trunking phone lines and does not distinguish between recipients or senders, but treats all faxes the same. SBS 2k3 also supports this feature. Server 2000 does not support this feature, and no add-ins are available to add it, to my knowledge.
The MS software allows you to send a basic fax if it is properly formatted. I believe it only accepts .TIF files, but this is easily verifiable on Microsoft's website.
2) The big boomer in the faxing industry is called RIGHTFAX. This is a completely different animal than the basic little faxing package that comes with windows. Rightfax is quite expensive to set up, deploy, and support from Captaris is also expensive. However, the software is very powerful. The main difference is that RIGHTFAX can distinguish between incoming and outgoing faxes, and routes faxes directly to the users.
First, you to set up and reserve from the phone company a range of phone numbers that all "trunk" (or ring) to the same physical location. For example, I have ONE phone line coming into the building, but I want that ONE line to have 100 different phone numbers. So Sprint will set me up with all the numbers from 555-5000 to 555-5100 and they all ring to the same line.
Then RIGHTFAX does its magic. Using a special kind of "super modem" called a Brooktrout board, it can actually receive faxes on all of these lines. (100 lines is not the limit, I'm just using that as my example, the limit is crazy high, like over a thousand lines) Then, based on the phone number that was dialed, it can route the call to the appropriate user. It integrates in with Active Directory AND MS Exchange, so it can email faxes directly to Exchange recipients. It's truly amazing that it works at all, but it is very consistent.
Outgoing faxes are even more impressive. RIGHTFAX supports faxing in a variety of formats. You can feed it an MS Word document, .TIF, .jpg, excel files, Raw text, whatever...and it automatically converts it to fax format before sending it. The only format that is not supported is .PDF, but it is available as an add-in for an extra cost.
There are multiple ways to send faxes, also. The best thing about it is that it adds a button into MS Outlook. When you click it, you create your fax just like you'd create an email, including attachments, and when you click send, it is faxed automatically through the server. This is especially cool because it reads Exchange data, so you can pick a user off an exchange or outlook contact list, and the fax server will automatically use whatever phone number it finds in the "fax" field. It even puts the user's custom (virtual) phone number on the outgoing fax for easy replies. You can also print to a fax machine, or use their little quick fax utility to send one-time faxes. There are a lot of great options for sending.
The user interface on the server modules is a bit clunky, but you get used to it. Also, like I said, the software becomes expensive VERY quickly, especially if you figure in all the add-ins you need, plus the trunking lines from the phone company. It's not for everyone, but it's extremely powerful and versatile if deployed properly.
Their tech support is pretty good, they got me up and running in a week or so, and were extremely knowledgeable about their product.
I'm not sure if there's anything more specific that you wanted to know about the software, I could go on for hours, it's extremely complicated. But, if you have any more questions about either of those platforms, let me know!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 30, 2010 | Computers & Internet
Outlook send /rec error 0x8004210a /fail sync with blackberry
I found Outlook Password Unlocker is helpful,
recover forgotten passwords for emails in Microsoft Outlook.
Your Outlook password will be displayed in a minute no matter how long and complicated it is.
Besides, the compact interface makes it easy to use.
Oct 06, 2009 | Microsoft Office Outlook 2007: Windows
Microsoft office outlook, word, excel all stop working-shut down
you can try fixing the problem by diting your registry.
1. go to your desktop.
2. on your keyboard, hit the "windows key" (between ALT an CTRL) together with the "R"
3. a little box should pop up. In the box, type "regedit" and press enter.
4. registry editor should open up. (it looks something like windows explorer)
5. navigate to the following registry key: HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\ Office\ Outlook\ Addins\ Microsoft.VbaAddinForOutlook.1
6. Right click on the "Microsoft.VbaAddinForOutlook.1" and delete it.
7. close registry editor,
8. restart PC and run outlook!
Jun 16, 2009 | Microsoft Computers & Internet
Outlook network password pop-up
You might look at this http://blogs.msdn.com/outlook/archive/2007/06/15/microsoft-office-outlook-connector-beta-released.aspx or look at this http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=819756&SiteID=17 it would be helpful to know what server you are trying to logon to AOL, Hotmail, etc... and I doubt it but are you on a network? if so specify
Nov 05, 2008 | Computers & Internet
Computers & Internet Logo
133 people viewed this question
Top Esker Computers & Internet Experts
David Payne
David Payne
Are you an Esker Computer and Internet Expert? Answer questions, earn points and help others
