Question about Toro Co M/R Blwr/Trmmr Rear Bag Kit
Have a recycler rear bagger...I cannot keep the bag clipped on, pops off usually on the right side as you stand behind the mower. I try and keep the grass from building under the "slot" but sdtill pops off even when its clean...any ideas?
    New Friend:
I can't figure out the remedy either. Very annoying. Replaced the rear door spring, but that didn't help. I even thought the bag wasn't breathing, so I flushed it with the hose.....No cigar! Any other thoughts?
Posted on Oct 31, 2013
  • 246 Answers
SOURCE: Grass clippings won't go into bag
Hello steveacosta:
Check the Blade. If the Lift Area Behind the Sharpened Area of the Blade is Worn, then you will have the Problem you Described.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 16, 2009
  • 16 Answers
SOURCE: I have a 3 year old Toro 22
change the blade
Posted on Aug 20, 2009
vincob
  • 718 Answers
SOURCE: mtd bagger not bagging
Open the door to the bagger chute when you attach the bag.
Posted on Sep 26, 2009
  • 420 Answers
SOURCE: how does one keep the rear bagger on the
Ensure the slots are not filled with grass clippings before installing the bagger.
Posted on May 27, 2010
  • 2926 Answers
SOURCE: to mulch my grass clippings, do I have to use the
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Posted on Jun 10, 2010
PTO wont engage how can you check
PDF]Owners Manual - Mowers Direct
www.mowersdirect.com/manuals/20382OM.pdfSuper Recycler® Lawn Mower. Model No. ... Whenever you need service, genuineToro parts, ... This manual identifies potential hazards and has safety.
You can download the above from google.
You can also check if there is a safety feature keeping the PTO from engaging.
Jul 17, 2015 | Toro Super Recycler Super Bagger Lawn...
Attach bagger
ive got a JD 180 .with a bagger on it if you have the factory bagger
1st bolt bracket to back right hand side of tractor holes should allready be there next assemble bagger top to tractor bracket , hang collection bags (two) from top of bracket (open top to access) then assemble diverter tube all together three sections , snap end (wide) into bagger (no bolts needed) then fold back safety discharge cover on deck all the way snap the inlet adaptor into hole left by this (perfect fit) and last stretch rubber bungee up to deck wheel strut and place clip thru small moon clip there, now you willl need to replace your deck blades with the High Lift type (mulch) avail still from JD (theres a extra wing on back of it) this makes more air to scoot grass up the chute if not your gonna have a lot of cloggs
Oct 30, 2014 | John Deere Original 130 160 165 175 180...
Engines dies after 5 seconds
loosen the fuel cap and try running it the vent in the cap could be plugged up
Jun 11, 2012 | Toro Super Recycler Super Bagger Lawn...
How do I raise and lower the blade
Each wheel has an adjuster on it Usually A is lowest setting and E is highest setting
May 18, 2011 | Toro Super Recycler Super Bagger Lawn...
Where is the model number on the frame of a toro recycler lawn mower?
Toro model plates are white stickers with black lettering. On rear bagging models it is usually under the rear bag flap to the left of the discharge area. On side bag and commercial type units it is frequently on the underside of the plate that is just below where you hold the handle while mowing. On older recycler mowers it was on top of the left rear portion of the deck and usually fell off before the mower was very old.
Aug 25, 2010 | Toro Garden
Saw your post about Black and Decker MM525 Lawn Mower
Most lawn mower mfgs offer a mulching kit which usually consists of a metal plate to block the discharge opening and a mulching blade which just has a longer sharpenned cutting edge.
With a little labor you can make your own.
Johnww1422@aol.com
Apr 19, 2008 | Black & Decker 19" Electric Lawnhog...
Toro Co M/R Blwr/Trmmr Rear Bag Kit Logo
151 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
