Question about MotorGuide FW71 FB Freshwater Series Foot-Control Fishing Trolling Motor
I have a motorguide fw71fb trolling motor. Speed 1 and Speed 2 quit working but 3, 4 & 5 work fine. I looked in the manual and it said to check the wiring in the top unit. All looks fine. I read on this site that the lower unit may need cleaning but it's a little tricky putting it all back together. I'd like to have a better specs manual before I take it apart. Please advise. Kelly
  • 1 more comment
  • kjs78003 May 26, 2011
    All they had was the operator's manual. I'd like to find a schematic of the lower unit or other recommendations as to why only Speeds 3, 4, and 5 will work properly.
    Thanks
  • kjs78003 May 29, 2011
    All they had was the operator's manual. I'd like to find a schematic of the lower unit or other recommendations as to why only Speeds 3, 4, and 5 will work properly. Thanks
    I have a motorguide fw71fb trolling motor. Speed 1 and Speed 2 quit working but Speeds 3, 4 & 5 work fine. I looked in the manual and it said to check the wiring in the top unit. All looks fine. I read on this site that the lower unit may need cleaning but it's a little tricky putting it all back together. Please advise on what is causing the problem.
    Thanks
    Kelly
    Master:
  • 448 Answers
Im sending you the pics i found i hope this helps you (BOB)I have a motorguide fw71fb - bigguy810_0.gifbigguy810_1.gifbigguy810_2I have a motorguide fw71fb - bigguy810_3.gifmibigguy810_4.gif
Posted on May 29, 2011
  • 683 Answers
Try visiting www.motorguide.com and checkif the manuals you are looking for is there.
Posted on May 26, 2011
    President:
  • 1,654 Answers
Http://www.trollingmotorparts.com/default.aspx?act=documentdetails.aspx&Documentid=89&category=Motor Guide Motor Diagrams 2004&MenuGroup=Home&SMID=195&SMSubID=57&nosearchprompt1
I did manage to find a diagram on this site, others want to charge for the service manuals
The bottom is basically all motor, the top part with the wiring is where all the selections take place. There may be something wrapped around the shaft and to get to it, the prop just slides off the shaft after you remove the retainer. Taking off the back part will get you to some bearings that might need lubricated but that is usuall not the case in these. These problems usually stem from a bad switch or fouled prop shaft. When you get to this site simply go down to your model number and select it for the diagram
Why does my motor guide 50 trolling motor fuse
It depends on how much current the trolling motor is supposed to draw when set to 5. If it's more than 40 amps, then you need a larger breaker. If it isn't more than 40 amps, then your current 40 amp breaker is weak and needs to be replaced.
May 13, 2014 | MotorGuide Electrical Supplies
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
Only have 5th gear on my trolling motor its a 5 peed but 1 thru 4 do not work already replaced the switch
I have the exact same problem gears 1 through 4 don't work but 5th gear works fine, any help from anybody would be greatly appreciated. There are 4 red wires going into the switch also a yellow and a blue. The 4 red wires all have power going through them in 5th gear but when I switch to the other gears only the two middle wires have power.
Aug 14, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I'm looking for a manual for Motorguide- Laser
standard motorguide manual
http://sites.mercurymarine.com/pls/portal/docs/PAGE/MOTORGUIDE/MOTORGUIDE%20SUPPORT/ONLINE_MANUALS/MANUAL_CONTENT/MM6900%20-%202004%20-%20OWNER%27S%20MANUAL_0.PDF
Aug 11, 2009 | MotorGuide Electrical Supplies
New MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
May 23, 2009 | MotorGuide Electrical Supplies
Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide FW71 FB Freshwater Series Foot-Control Fishing Trolling Motor Logo
822 people viewed this question
Top MotorGuide Boating Experts
Mike
Phil Walker
Phil Walker
Angel Joseph Jr.
Angel Joseph Jr.
Are you a MotorGuide Boating Expert? Answer questions, earn points and help others
