Question about Sony KP-51WS20 Rear Projection Television
Sony 51es20 standby is 5 time and no picture, no song just fussy light. and could someone help me out. thanx
  • 455 Answers
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Aug 20, 2011
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
My sony kp-51ws520 will not turn on u hit the button and there is sound but no picture. The standby light flashes fast 10 times ! Can someone please help!!!!!
Ten times standby light flashes denotes a problem with its audio output card. If you wish to get more details about the blinking codes to Sony PTVs, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide / Mosaic option.
Jul 13, 2013 | Televison & Video
Sony wega 51" standby light is blinking 5 times repeatedly. what is this code for?
The picture tube is getting close to failure. Has the picture tube been replaced before? If it hasn't it is probably about due the Vegas were great long lasting T.V. sets but after about 15 years need a new picture tube.
Jan 15, 2013 | Sony Grand WEGA KDP-51WS550 51" Rear...
Sony kv-27v40 standby/timer blinks 5 times
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Apr 23, 2012 | Sony KV-27V40 27" TV
Sony 52" rear projection tc
Hi, thats the code for AKB fault, this requires a tv tech to fix,, not a big bucks repair, video-tek
Feb 09, 2009 | Sony KP-43T90 43" Rear Projection...
Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
Sep 18, 2008 | Sony KV-24FV12 24" TV
Standby Blinks 5 times. Picture goes off but sound stays on. Only hookup is Digital Cable - help!
Plug the electricity to a surge protector. I fixed my that way. Try it and let us know.
Jun 28, 2008 | Sony KP-53HS10 TV
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony KV-21X4U
did you see anything on screen at all event the sound.
Dec 01, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KP-51WS20 Rear Projection Television Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
