Question about Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades
I cant get the blade to lower. Where is the release?
  • 2,176 Answers
Without a model number I am going to guess. Most circular saws have the blade depth adjustment towards the back of the handle and usually on the left side. If you need an owners manual you would need the correct model number and then go to managemyhome.com and you can probably find it there. If you want to reply to me with the model number I will find exactly where the release is for you.
Posted on May 26, 2011
Can not get blade out of B &D hand saw. Release button not working.
Insert a middle size screwdriver between the teeth of the blade and to lower against the sole to lock the blade
Jul 14, 2016 | Saws
How to remove passenger door panel
Important: When removing a door trim panel or switch plate, disconnect the negative battery terminal. This will eliminate the possibility of shorting out the switch if you use a screwdriver, an awl, or other metal object in order to remove the switch from the harness.
Remove the window regulator handle, if equipped. (manual windows only)
Remove the front door warning reflector.
Remove the door panel screw (1) through the hole in the door warning reflector opening.
Use a flat bladed tool in order to remove the rear deck release switch bezel.
Disconnect the rear deck release switch.
Use a flat-bladed tool in order to remove the lower switch bezel trim screw access cover.
Remove the lower switch bezel trim screws.
Remove the lower switch bezel trim panel.
Use a flat-bladed tool in order to pry the front door switch bezel upward.
Disconnect:
Power door lock switch connector, if equipped.
Power window switch connector, if equipped.
Power mirror switch connector, if equipped (left side only).
Gently disengage the front door trim retaining clips and remove the door trim panel from the door.
Reverse procedure to install
Oct 10, 2011 | 2000 Oldsmobile Alero
Need to know how to change the agle on the blade for a protech 10 in table saw
Hi Ron,
You didn't give your model.
Protech is out of business so I could not find a user's guide for you.
The knob on the front that you use to raise and lower the blade also adjusts the angle. Depending on your saw, normally the knob releases from raise/lower mode to angle adjustment by either pulling the knob out and moving it or by pushing a lever to release it and then moving the knob.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Skil 10" Table Saw
I have a Babylock 5260 serger and have changed the blades before but this time when I changed them I can't get them to align correctly. the top blade comes down and hits the bottom blade. I cant figure out...
First make sure that both blades have no burrs on the them from hitting pins. Then set the lower blade so that the cutting surface is flush with the surface of the needle plate. Then adjust the upper blade so that when it comes down to it's lowest position on the downward stroke of the cutter arm, that the cutting edge comes down past the lower blade at least 1MM. That will ensure a full cut of the blades.
Apr 26, 2011 | Sewing Machines
Window on drivers side froze and fell down and won't roll back up. How to take door panel off to fix the window
  1. Disconnect the negative battery cable. Important: When removing a door trim panel or switch plate, disconnect the negative battery terminal. This will eliminate the possibility of shorting out the switch if you use a screwdriver, an awl, or other metal object in order to remove the switch from the harness.
  2. Remove the window regulator handle, if equipped.
  3. Remove the front door warning reflector.
  4. Remove the door panel screw (1) through the hole in the door warning reflector opening.
  5. Use a flat bladed tool in order to remove the rear deck release switch bezel.
  6. Disconnect the rear deck release switch.
  7. Use a flat-bladed tool in order to remove the lower switch bezel trim screw access cover.
  8. Remove the lower switch bezel trim screws.
  9. Remove the lower switch bezel
  10. Use a flat-bladed tool in order to pry the front door switch bezel upward.
  11. Disconnect:
  1. Gently disengage the front door trim retaining clips and remove the door trim panel from the door.
Installation Procedure
  1. Install the front door trim panel to the door. Ensure that the retainers are locked into place.
  2. Connect the rear deck release connector.
  3. Install the rear deck release switch bezel. Press the bezel firmly into place.
  4. Install the window regulator handle to the door.
  5. Connect:
  1. Install the front door switch bezel assembly to the front door trim panel.
  2. Install the lower switch bezel trim panel. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the lower switch bezel trim screws.
  4. Install the lower switch bezel trim screw access cover.
  5. Install the door trim panel screw (1) through the hole in the front door warning reflector.
  6. Install the front door warning reflector.
  7. Connect the negative battery cable.
Oct 15, 2010 | 2000 Oldsmobile Alero
Elna 704 serger sews well but cutter won't cut. replaced cutter -- same problem
Make sure that the blades are being held firmly together. I have seen the knob used to lower the moving blade come loose and releases much of the pressure intended to hold the blades together.  If so, the set screws on knob have come loose.
Sep 03, 2009 | Sewing Machines
How do i change the circular saw blade on my saw? because i cant get the blade out to swap it as its blunt and the blade is now blunt
After removing the blade bolt and the outer flange you will need to fully retract the lower guard (remove battery) and sometimes wiggle the blade but it will come out.
Aug 29, 2009 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
How to change the belt on a bissell powerbrush deep carpet cleaner.model 1694
Turn the machine OFF (O) and unplug from
the outlet. To check if the brush belt or
pump belt has broken, you will need a flat
head screwdriver. Insert the blade end into
the lower slot of the belt access door to
release the lower snap. If necessary, insert
the blade end into the upper slot to release
the upper snap.
Hope this helps.
Richard
Mar 10, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Grizzly bandsaw cannot fit blade
I lowered the spacer (on the threaded rod) and got enough drop in the upper wheel to fit the blade.
Jan 11, 2009 | Saws
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
76 people viewed this question
Top Sears Saws Experts
Mike Squire
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
