How do i record tv shows. i'm getting tv channels thru the vcr. i do not know how to record. i do not have the manual. vcr was given to me by bro.
    Problem Solver:
  • 6 Answers
Set the channel you want to record on your vcr and then click the red record button.
Posted on May 26, 2011
Have just retuned digital terrestrial receiver Matsui DTR -2 for our area, how do I now record tv programmes with my Bush VCR925NSILXI? On analogue TV the recording channel was Channel 9
Recording, amazingly, has nothing to do with your TV, it only monitors the playback or recording input of your VCR or DVD recorder - the Channel 9 you mention.
They have their own tuners, indeed DVD recorders have Freeview (or DTV) tuners so no need for a separate box at all - given that your TV has a DTV tuner too and if a recent flat screen type it will.
If you can afford it, this is a good time to drop VHS and get a DVD recorder. You'll find plenty on Amazon Electronics for a start.
Your Bush VCR will be redundant the moment the analogue service goes off, they haven't made a VHS VCR with a DTV tuner.
Depending on your area this is a few months off, even for the last area to change over anyway, here in London there's just shy of nine months left.
Sep 21, 2011 | Televison & Video
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Proper vcr connections to operate on a television
Since the cable is connected to the VCR and from there to the TV. The TV should be tune to channel 3 or 4. Using this connection, the VCR tuner will be changing channels when is ON, if you want to change channels on the TV; the VCR should be on standby.
Let me know if you need further assistance.
Apr 02, 2010 | Sanyo SRC-800 VCR
Can;t record on VCR since Comcast went Digital
I have Dish Network and a DVR and I do not know what I would do without it. I can record 2 shows at once and watch to 2 recorded programs while recording two shows. But getting to your problem... It sounds like the vcr cannot process the digital signal. You could try hooking up the vcr to the rca inputs from the cable box but you will only be able to record whatever channel the cable box is on. Any way you hook them up the programming of the vcr to change channels at different times for different programs probably won't work now. It sounds like Direct TV with two DVRs will solve your recording needs.
Sep 13, 2009 | Toshiba Televison & Video
How to setup my VCR to record programs from my Panasonic 42 Inch HDTV Plasma TV?
TV doesnt matter, you need to list what kind of VCR your trying to program with.
if you are programming from cable, the cable box, box or not, should be ran thru VCR then VCR to TV.
to record. easiest.
if you are doing cable to tv to vcr. make sure that tv is in one of the AV spots, so when you select input on vcr itll show your tv again. program as accordingly.
Feb 26, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Cannot record VCR thru Cable Box
make sure that the cable runs first through the cable box then through the VCR then to the TV.
if you know how to set timers on your cable box (if you have that option), set those in addition to your VCR timer. If you don't have that feature or are not sure, you will, unfortunately, have to keep the cable box on a certain channel before you record.
hope this helps!!
Feb 10, 2009 | Panasonic Televison & Video
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
RCA VR355 recording problem
Are you sure the reciever is coming through the vcr.? are you hooking it up through a/v on vcr?
if so hook from a/v out from directv to a/v in
jacks on back of vcr. and turn vcr on a/v channel
to record it. you will see the picture as you record it. if the vcr isn't on a/v channel it won't record it
If you use ch 4 or 3 to record it you
hook up directv to cable in on vcr and you
have to turn vcr on that channel and see it coming
through it you have to push a button on satlette
remote to make it come on the vcr on the channel
or it will record snow. and you have to push
another button on vcr remote if you haven't
already to get the vcr on ch 4 or 3 on your tv
or if u got it through a/v turn tv to a/v channnel.
just beacuse you see the picture coming through
your tv doesn't mean it going through your vcr
you could be just seeing it through the tv only.
you will see the vcrs graphics or vcr channel number on your
tv too along with the directv channel if it's hooked
up right. notice the vcr won't record it's own
graphics or channel number on the screen but it will record the directv's graphics. and it won't record the tv's own grapic channel number either.
to make sure it's right you will see 3 graphics on
your tv the own tv's channel number or a/v
the directvs and the vcr's channel number or a/v
on your tv if you see these you know it's hook up
right.
Nov 11, 2007 | RCA VR355 VHS VCR
How do I Record?
well, seems like your vcr is attached to your tv by the antenna cable which you need to program to get it to record. but he is an easy way to record and you will get a perfect sound and picture. Well, you need an RCA cables. you either have rca cables or scart plug. either on will do the job. you need to take the audio and picture cable OUT source of your channels IN to the vcr. now, OUT of the vcr IN to your tv. on the vcr you should change the channel to either AV or LINE..then you will get sound and picture. let me know how it goes
Jan 15, 2007 | Panasonic PV-8451 VCR
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
