Question about Thermador MBBS Microwave Oven
I need to replace the waveguide in my Thermador MBBS / 01 microwave.
  • Thermador Master
  • 9,098 Answers
Waveguide "cover"I presume? The waveguide is part of the chassis and cannot be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on May 26, 2011
Is there a replacement microwave for the Thermador MBBS/01
The MBBS sereis was replaced by the MBES series.
Specs are here.
Nov 27, 2012 | Thermador MBBS Microwave Oven
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
Thermador built in microwave turns on but wont heat worked great this morning. model# MBBS/01 serial# FD8602
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 02, 2011 | Thermador MBBS Microwave Oven
Thermador Microwave Oven Model MBBS Serial No FD 8402000337 Runs but no longer heats food. Deep growling sound Light flashes from behind 4.25 x 5.5 " metal plate on right vertical side of oven...
Oh dear, I hope the magnetron still works. That plate you describe is called the Waveguide Cover. This cover must be kept clean otherwise the food particles will carbonize and cause exactly what you have described.
Contact the manufacturers web site for a supplier in your area or look on ebay, espares.co.uk depending on your location.
When it has been changed, I hope the magnetron/aerial is OK.
Dec 29, 2010 | Thermador MBBS Microwave Oven
Mbbs/01 microwave makes noise when turned on and doesn't get hot. Is it fixable or need to be replaced?
Sorry to read about your problem, I hope this helps you out.
yes they are all fixable..just depends on repair cost
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Thermador MBBS Microwave Oven
Is there a replacement microwave for thermador MBBS that fits MT30S trim kit?
Thermador doesn't make one, but we found the GE JEB1860SM1SS from Home Depot fit perfectly. For only $259. The repair to fix our Thermador was $618. It was only 5 years old. I couldn't believe it already went out. I won't be buying anymore Thermador appliances.
Dec 20, 2009 | Thermador MBBS Microwave Oven
TURNTABLE INOP on mbbs/01 thermador microwave
easy...first thought it was a program glitch. turntable could be turned off manually. nope ...just a bad motor needed replacement
Sep 14, 2009 | Thermador MBBS Microwave Oven
Sparks aplenty!
This is usually just due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
If so, please double-check your model number on the tag so we can help you better.
Jan 05, 2009 | Thermador MBBS Microwave Oven
Sparks
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
You should be able to order one here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 21, 2008 | Thermador MBBS Microwave Oven
Thermador MBBS/01
The waveguide cover is usually about the size of a playing card and held in place by a plastic rivet.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
Nov 26, 2007 | Thermador MBBS Microwave Oven
Thermador MBBS Microwave Oven Logo
293 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
