Question about Toshiba Satellite A665 Notebook
I GOT A NEW LAPTOP AND WHEN I OPENED IT, A MESSAGE APPEARS STATING " RECOVERY OF FACTORY DEFAULT SOFTARE" AND IT JUST STAYS THERE NOTHING HAPPENS CAN U HELP ME WITH MY PROBLEM ???
    Sergeant:
  • 281 Answers
I would take it back If it's still under warranty a get another one.If that's not an option you can call
Computers: (800) 457-7777 (toll-free) or (949) 859-4273 I did a factory install with my Satellite but I don't remember how but it had something to do with holding zero down when I turned it off or on.The first thing I do is make a back up copy.Takes 3 DVDs and you can just put them in and laptop is good as new.You will lose any thing that you had added so save anything you want on CDs.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 26, 2011
  • Toshiba Master
  • 32,281 Answers
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Where would the reset button be inside a laptop.
Disconnect the power, remove the battery then press and hold the power button for 15 seconds. Reassemble.
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. On machines with the F key numbers on the top edge of the keys and in White:
    • Press and hold the 0 (zero) key and power up the laptop.
    • Release the 0 (zero) key when the recovery warning screen appears.
    On machines with the F key numbers on the bottom edge of the keys and in Gray:
    • Power up the laptop.
    • When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu.
    • Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
  5. The TOSHIBA recovery wizard warning screen appears stating that when the recovery is executed all data will be deleted and the original factory software image will be rewritten. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. After you are sure you have everything you want from the laptop saved, click Yes.
  7. When the Toshiba Recovery Wizard opens, the default and recommended option is "Recovery of Factory Default Software".
  8. After selecting your desired recovery method, select Next.
  9. On the next screen you may have recovery method options. The default and recommended method is to Recover to Out of Box state.
  10. Select next to continue.
  11. Follow the on screen instructions as you navigate through the system recovery steps.
  12. The laptop will restart multiple times and install the needed components.
Dec 11, 2014 | Computers & Internet
How can i reset a toshiba satellite pro m15 s405
Most Toshiba laptops with come with the factory software recovery image stored in a special hidden partition on the hard drive of the laptop. The factory software recovery image allows the user to recover the laptop to its factory fresh condition as when it was new.
This partition may also be referred to as the Partitioned Recovery Method or Free Recovery option.
IMPORTANT: The recovery process deletes information stored on the internal storage drive. Be sure to save your work to external media before executing the recovery.
Nov 25, 2014 | Toshiba Satellite Pro M15-S405 Notebook
Got toshiba sat C55t-A, yesterday. Turned it off last nite, turned on this morning it says configuring windows update. After long while it says ipdatte failed. Now wont shut down or respond to even F8 on...
follow the steps supplied below from your manual.
To recover the original factory image using the utilities on your computer's internal storage drive:
1Make sure the computer is turned off.
2Press and hold the 0 (zero) key on your keyboard while powering on the computer.
3If your system offers a choice of Windows® 7 32-bit or 64-bit
operating system, select one at this time. If not, skip to step 4.
4A warning screen appears, stating that when the recovery is
executed all data will be deleted and rewritten. Click
Yes to continue.
5When the Toshiba Recovery Wizard opens and the Selecting a
process screen displays, select
Recovery of Factory Default Software and then click Next.
6The Recovery of Factory Default Software screen appears.
Select
7 Click Next.
A confirmation message displays reminding you that all data
will be lost during the recovery process.
8Click Next to begin the recovery.
When the process is complete, a message displays indicating
that the internal storage drive has been recovered.
9Press any key on the keyboard to restart the computer.
Nov 07, 2014 | Computers & Internet
Need to restore my laptop to factory settings.
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Jan 12, 2013 | Toshiba Satellite 1800-S204 Notebook
Problems during Recovery of Factory Default Software
Don't stop the presses during recovery
its too bad to stop
wati more than 3 or 5 hours
cuz it depends on your pc specs
Dec 13, 2012 | Toshiba Computers & Internet
Yes I have forgot my password on my toshiba Satellite L3550 and I cant do any thing on my laptop. I dont have a boot disk either, is there anything I can do to beable to use my computer again
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
Restore Partition C: of HDD without changing current partition size
CAUTION:
Restoring the C: drive to its factory default state formats your drive. Your information on the drive will be overwritten, and lost. Be sure to back up all important files first. If you have created other partitions (for example, a D: drive) those partitions and any information on them will not be affected and will remain intact.
To restore only the C: drive:
  1. Press 2 to restore only the "C:" drive (the letter C is traditionally used to designate the first volume on the hard disk drive) on your computer. A confirmation message will appear, indicating that all information on the drive will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
Restore Image to C: Partition with user specified size
CAUTION:
Resizing and restoring your C: drive to its factory default state formats all partitions on the HDD (for example, if you created a D: drive, it will be deleted during the recovery process) your information will be overwritten, and lost. Be sure to back up all important files first.
To resize and restore your C: drive:
  1. Press 3 at the Toshiba HDD Recovery Utility screen. A confirmation message will appear, indicating that all partitions will be reformatted and all information will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click "Yes" to begin the recovery and to specify the size of the C: drive.
    • Press the Left/Right Arrow keys to increase/decrease the C: drive size by 1 GB increments.
    • Press the Up/Down Arrow keys to increase/decrease the C: drive size by 5 GB increments.
      NOTE:
      The size of the C: drive will be displayed on the progress bar as you make your selections.
  3. Click "Enter" to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
  4. Press any key to restart the computer.
Aug 12, 2011 | Toshiba Satellite L355D-S7815 Notebook
I have an older toshiba laptop and i want to reset it to factory defaults because it used to be my sisters and now its mine. help?
try this
Hard Disk Drive Recovery using the recovery partition
You have the options of recovering your system using the Hard
Drive Recovery partition
to the factory-set default, or recovering
just your C: drive and leaving other partitions (for example, a D:
drive) intact, or changing the size of your C: drive and then
recovering it.
To recover your hard disk drive using the utilities stored on your
computer's HDD:
1 Make sure the computer is turned off.
2 Press and hold the 0 (zero) key on your keyboard while
powering on the computer. When the computer powers on, the
Toshiba Recovery Wizard screen displays.
3 Select one of the options, and then click Next. The options are:
? Recovery of Factory Default Software
? Erase the hard disk
1 On the Toshiba Recovery Wizard screen, select Recovery of
Factory Default Software, and then click Next.
(Sample Image) Recovery of Factory Default Software screen
2 Select Recover to out-of-box-state, and then click Next.
will be lost during the recovery process. Be sure to save your
work to external media before proceeding.
3 Click Next to begin the recovery.
Once complete, a message displays that the HDD has been
recovered.
4 Press any key on the keyboard to restart the computer.
To recover only your C: drive:
1 On the Toshiba Recovery Wizard Screen, select Recovery of
2 Select Recover without changing the hard drive partitions.
A confirmation message appears, reminding you that all
information on the C: drive will be lost during the recovery
process. Be sure you have saved your work to external media
before proceeding.
3 Click Next to begin the restoration.
recovered.
4 Press any key on your keyboard to restart the computer.
Jun 12, 2011 | Toshiba A105-S4054 Notebook
Please tell how to reset my computer to factory defaults
If you Toshiba is a fairly recent laptop and there is a Restore partition on your hard drive.
To restore your Toshiba to "Out of the Box" condition then please click on this link and follow my instructions :-
http://www.fixya.com/support/r8248520-restore_toshiba_out_box_condition
Mar 11, 2011 | Toshiba Satellite L455DS5976 Notebook
I have an acer aspire 4736g, i need to restore my notebook to factory default, i wait for the acer logo to appear on the lcd screen. then i press the "Alt" and "F10" keys at the same...
Instructions
Things You'll Need:
Acer PC or laptop
Step 1:
Click "Start" menu.
Step 2:
Click "Programs."
Step 3:
Click "Acer Recovery Management."
Step 4:
Click the "Restore" button on the bottom of the dialog box that opens.
Step 5:
Click "Restore System to Factory Default."
Step 6:
Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Step 7:
Click "Start" to restore the computer to the default factory settings.
Tips & Warnings
If you are unable to access the Start menu, use the recovery CDs that came with the computer or visit Acer's website (see Resources below).
Always make a back-up CD before restoring a computer to factory defaults.
Resources
Acer Website
Mar 01, 2011 | Acer Computers & Internet
I have a toshiba a210 1as laptop and i want to restore to factory settings...But i dont have any discs with the laptop...Can i still do this without the disc? Im being told by friends that these laptops...
What your friends have told you is correct for newer Toshiba models, they do have a "recovery partition"
Here is how you recover the OS >>>>>>
1, Make sure the laptop is turned off.
2, Hold down the zero (0) key and turn the laptop on, keep it pressed in until you see the "Toshiba Recovery Wizard" screen.
3, Choose the "Recovery of Factory Default Software" and click next.
4, The "Recovery of Factory Default Software" will appear.
5, Choose the "Recover to out-of-box-state" you will then get a message that all your data will be lost. Click next and the recovery process will start.
Once complete you will see a message that the HDD has been recovered.
Before you start the recovery process its a good idea to back up any data you have unless you not bothered or have already done so.
Reagrds.
Dec 04, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite A665 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
