Question about Texas Instruments TI-83 Plus Calculator
Three times a number is 50 more than the number. define a variable and write an equation to find the number. then solve
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
The equation is easy: it's right there in what you said.
3x = x+50
which solves to give
x=25
Since this seems like a homework problem, you'll have to show your work.
Posted on May 26, 2011
How do I type this exact equation into my calculator?
You should check your manual. The FX300MS has only three calculation modes: COMP (regular calculator), SD (standard deviation) and REG (statistical regression analysis). You cannot solve equations.
Apr 28, 2016 | Casio FX300MS Scientific Calculator
X and y intercepts
First of all you equation is not one : it has nothing on the right side of the = sign. But to answer the general question let us write the equation as 50+25x-5y=0
X-intercept (also know as roots) There may be several
Definition: X-intercepts are those values of the independent variable x for which y=0. For a straight line there con be at most 1 x-intercept.
To find the intercept, set y=0 in the equation of the line and solve for x
50+25x-5(0)=0 or 50+25x=0. The solution is x=-(50/25)=-2
Y-intercept (also know as the initial value. There can only be 1 y-intercept, otherwise the expression does not represent a function.
Definition: It is the value of the dependent variable y when x=0 (where the function crosses the y-axis
To find it, set the x-value to 0 in the equation of the line.
50+25x-5y=0
50+25(0)-5y=0, or 50-5y=0. The solution is y=50/5=10
The straight line cuts the x-axis at the point (-2, 0) and the y-axis at the point (0,10)
Jan 28, 2014 | Computers & Internet
Solve the multiple angle equation cos x/2= -
variables not defined, 3/2 not a valid argument. How did this pop up under my bissell proheat 2 search?
Oct 22, 2013 | Western Digital My Book Essential Edition...
How do i input quadratics on a casio fx1500?
  • You have several memory locations you can use to store values in them. The memory locations are A,B,C,D, M, X, and Y. You use [SHIFT][RCL] and one of the variable names above. Example store 78 in C location: 78 [SHIFT] [RCL] [HYP]. To recall that value press [RCL] [HYP]
  • If you want to use the EQN (equation solving mode, press [MODE][5:EQN] then select the equation type . For example [3:aX^2+bX+c=0] will display a template wher you input the three coefficients.
  • You can also enter any type of equation and solve it with the SOLVE command. In that case you use the keyboard to enter the expression (see above how to enter variable name X). To type in the equal sign (=) use [ALPHA][ CALC]. Once the whole equation is typed in, press [SHIFT[ [SOLVE], and the calculator will prompt SOLVE for X? Confirm and press the main = sign. Press = again to get a second, a third root (if any)
Jun 06, 2012 | Casio FX-115ES Scientific Calculator
4x - 2x + 1 = 5 + x - 7
Start by combining like terms on each side of the equation.
Remember, when working with variables the real numbers always come last in the equation(i.e. 5+x-7=x+5-7)
Once you have this completed move all variables to one side and all whole numbers to the other side. Solve from there.
May 17, 2012 | MathRescue Word Problems Of Algebra Lite
I am trying to graph any possible equation and I get undefiend varialbe for any kind of equation as simple as x=7. It will always show as undefiend varialbe for any equation. I don't know why it does this.
Undefined variable error message displays when you evaluate a user-defined
function or run a user-defined program that references a local variable that is not
initialized (assigned a value). You have to type LineVert 7 and then graph function x=7. See captured image
May 02, 2011 | Texas Instruments TI-89 Calculator
I m unable to multiply two 4 cross 4 matrix ,how to solve this problem?
This calculator cannot handle matrices that have anyone dimension larger than 3.
How to solve your problem?
  1. Set up the problem by hand (pencil paper): use Cramer's rules. Make use of the calculator to perform the various calculation.
OR
  1. Sacrifice one equation which you will use to eliminate one variable of the 4 by expressing it in terms of the other three. Do the algebra to obtain a system of 3 equations in three unknowns.
  2. Use the calculator to find the solutions ( the three variables that are left).
  3. Use the 4th equation (the one you scacrificed) to obtain the value of the 4th unknown.
OR
use a computer program devoted to solving linear equations
OR buy another calculator that can handle larger systems of equations (a graphing calculator, maybe).
Feb 16, 2011 | Casio FX-115ES Scientific Calculator
How can i do algebra and keep the pronumerals and not use the inputted number? I am using the latest casio, it is a scientific calculator (not sure which model)
It is always risky to try to answer a question about a calculator of an undisclosed model.
To be able to symbolic algebra (with variables), one needs a calculator with CAS (or Computer Algebra System). These types of calculators are special graphing calculators. ( Not all graphing calculators have a CAS.)
To get back to your question: No, you cannot do algebra with a mere scientific calculator even a recent one. All you can do is define an equation with variables A,B,C,D, Y and X and press the Solve button if it exists. The calculator will ask: Solve for X?. If you say yes, you will be prompted for the values of all letters (A,B,C,D, Y) in your equation and the calculator will search for the value of X, that makes the left side of your equation equal to the right side.
It will display the X-value and the difference L-R.
Oct 31, 2010 | Casio FX-115ES Scientific Calculator
Solving multiple non-linear equations
Type it like this: solve( equation1 and equation2 and moreEquations, {list of variables to solve for})
Put all of your equations right after the opening parenthesis separated by the word and, then a comma, then within curly braces each variable you want to solve for each separated by a comma.
Apr 26, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-83 Plus Calculator Logo
57 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
