Question about Hitachi P50H401 50 in. Plasma HDTV
My Hitachi HD 1080 will not let me access the Channel Manager function. I'm told the function is not available. How do I enable this function
I am also having the same problem.how do you do a manual rescan
Posted on Jun 16, 2011
Why is channel manager option grayed out?
Channel manager may not be an available option for over-the-air viewing
Jan 27, 2014 | Hitachi 42 in. Plasma TV
Can't get channel manager to come up. Can't change channels. Electric went out from a thunder storm. Transformer hit by lighting. Now can't get channel manager to come up and can't cha
If you have not tried it: UNPLUG THE SET FOR A WHILE then plug b a c k and see if helped-----what can happen if power outage is microprocessor in set gets confused.
Let me know if questions or if this helped.
Mar 23, 2012 | Hitachi P50V702 50 in. Plasma HDTV
Is the integral Freeview on my 32 inch Full HD TV HD or Not
Simple answer. No. But please read on . . .
Full HD Freeview, i.e 1080p does not exist. The four HD channels currently available on Freeview all transmit at 720p resolution. There is insufficient bandwidth in the TV transmission range for the HD channels to transmit at 1080p. It could be done, but it would be at the expense of other channels.
Your TV, however, is Full HD, as indicated by the 1080p in the specifications. This means it can display a full HD picture from a device which outputs at 1080p resolution. Devices which generally output at 1080p resolution include Blu-ray DVD players, games systems and PCs.
When viewing a Freeview HD channel, your TV will display the picture in 1080i (interlace) resolution. This is not true/full HD. The transmitted picture comprises of 720 horizontal lines and the software inside the TV is creating the additional 360 lines and interlacing them between the 720 lines from the original transmission in order to create a 1080 line picture which fills the entire screen.This process is commonly known as 'upscaling' and can cause deterioration in the overall picture quality, most noticably on poor quality, cheap TVs.
Hope that explains it for you sufficiently!
Nov 10, 2011 | Televison & Video
Okay, have Hitachi 1080 HD. Called several times to Customer Service but they couldnt help. Cannot get the words in English to appear on screen for hard of hearing.
Look in the tv menu for SET UP or AUDIO options.
Look for CAPTION VISION and set to CC1.
Now exit the menu screen.
Now use the INFO or DISPLAY button on the remote to activate the closed captioning.
It should say something like CC1 ON once you get it right.
That should be about it.
Note that not every single channel has closed captioning for every single show and that the words usually take a few seconds to show up on the screen when you change to a new channel.
Good luck, hope this helps. Keep us updated on your progress.
Jan 21, 2011 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
I just set it up (it is used) and I can't get to the "Channel Manager" in the setup menu, as it is grayed out. I can't auto program because of my inability to access this menu function.
Channel menu will be grayed out if tv is set on AV Input, select TV source by remote or press any channel number to set tv on tv source, this will enable channel manager/ menu to tune channels in tv.
Hope these info will help you.
Thanks
Nov 25, 2010 | Hitachi 51F59 51" HDTV Projection...
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Mar 27, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Switching between a 720 hd channel and a 1080 hd
The unit has an auto detection circuit to determine what signal is being input, it then processes it, however if the signal is altered (different channel) the TV will at times try to process it through the wrong resolution circuit causing problems. Change the input of the TV and then change it back and it will redetect the 720p instead of the 1080i and display it properly. Check with Sony for possible updates.
Crampy
Nov 28, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I just subscribed to HD service, But my mitsubishi 55807 tv wont display 1080 it stays on 480. the server is comcast. can you help?
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
Dec 15, 2008 | Mitsubishi WS-55807 TV
Hitachi P50H401 50 in. Plasma HDTV Logo
328 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
