Question about Kitchen Ranges
I need a wiring diagram for an AO Smith mod 326P185 motor
  • 96 Answers
SOURCE: Need connection diagram, AO Smith motor FDL 1056
Black is high , Blue is med. , red is low
Posted on Feb 19, 2009
john224
  • 1378 Answers
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
  • 24 Answers
SOURCE: capacitor wiring on a ao smith M#-C48L2N134B1.
The single lead goes to one leg, the split wired leg in the same spade goes to the other. They are usually yellow wires. As far as Hayward, Jacuzzi and Starite are concerned.
Posted on Dec 17, 2009
john224
  • 1378 Answers
SOURCE: what do wire colors mean for ao smith dl1056
Thank you for posting your question here on Fixya.com.
White is common, Black high speed, blue medium speed, red low speed; Brown wires are for the capacitor; The remaining 4 are for selecting the rotation.
For details look at the AOSmith print here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jul 31, 2010
kingbrizzle
  • 407 Answers
SOURCE: Need wiring diagram for installation of an A.O.
These wire colors are the different speeds for the motor. You will have 1 wire going to the heat, 1 wire going to the cool, and 2 wires on the park terminals on the board if available. It will actually tell you the speeds of the colors provided on the motor itself i.e. BLACK=High and so on. Without knowing what model of unit you are working on, it's hard to say where exactly the wires will hook up, but the majority of the time you will have a electrical board inside the furnace and the terminals that I described will be marked. Hope this helps and good luck!
Posted on Aug 05, 2010
Wiring diagram AO Smith ST1102 pump motor
There is almost always the wiring diagram on the outside of every spa motor.
Bath Spa Parts Online
Jul 24, 2016 | AO Smith Pool & Spa
Wiring issue
Without model info, try this link. Most motor brands follow pretty standard wiring setups. Please rate me if this helps.
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Apr 16, 2014 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Im replacing a 2 speed Hayward motor with a AO smith 1 speed motor. I need to no how to wire the 1 speed
to wire a single speed motor you use only the black, white and green wire. there is usually a wiring diagram on the side of the motor to show how this is done.
no wiring diagram then put the black wire on the L1 or H1 post and the white wire to the common and of course the green to ground
Aug 21, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
Need wiring diagram for BN34 motor 2 speed 1.5 hp 230 volt
Usually the wiring diagram is on the nameplat of the motor. I hope this helps.
Aug 16, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
