Question about Ryobi 10 In Miter Saw With Laser
My saw blade stops when it contacts the wood I assume the blade may be lose but it feels tight any suggestions
  • Larry ONeil May 26, 2011
    Why would the blade on my Ryobi mitre saw stop when it contacts the wood?
  • Larry ONeil May 27, 2011
    I checked the areas you recommended but now after I replaced the blade I can not get the bolt that goes throughout the laser and into the flange to thread Is there a bushing that could be offset preventing the proper line up?
  • 3,740 Answers
I take it the blade is spinning on the mandrel it stops and the motor keeps running. Now the problem I have is there are 2 versions of this Miter saw... the 10 Amp and the 14 amp ones. I am going to assume you have the 10 amp one. The models numbers are TS1355LA and TS1342L. IF your model number begins with a Z it is a factory re-conditioned saw.
Parts manual is here: (for the TS1342L)
http://www.ereplacementparts.com/images/ryobi/TS1342L.pdf
Make sure that the flange PN 588035105 is not installed backward. After that you need to look at the gear and Parallel key (Items 44 and 42) as the probably cause for blade stoppage. If the Mandrel stops also look at those 2 items. Take a look at the shaft item 41 too, Last possibility is the splines on the end of the armature item 27.
Thanks for choosing FixYa,
Kelly
Posted on May 26, 2011
  • 43,501 Answers
Is this a used saw and have you changed the blade???
Yes, it does seem as though the blade is just loose....I would get a socket on the bolt...press in the shaft lock and rotate the shaft until it goes on in and stops the shaft... then use the socket to make sure that the bolt is very tight...
If you have recently replaced the blade, make sure that the heavy washers are on either side of the blade, the blade is on the shaft correctly and the bolt is tight....
heatman101
  • D. Floyd Kolb
    D. Floyd Kolb May 26, 2011
    Why would you not even comment back??? There is not that much that can be wrong... they are not that complicated... what else could it be??? What are you looking for if you just throw a perfectly good answer away like that??? You could not have even taken the time to check it out...
    Please at least make a comment that helps to clear up your problem, or you will just keep getting the same answers...
  • D. Floyd Kolb
    D. Floyd Kolb May 27, 2011
    getting everything to line up correctly and go together enough to get the bolt in can be very tricky!!! Check for the different shapes and then fit them all together...they can be a real pain in the ****!!
    If you have a model number for the saw you can go here... www.ereplacementparts.com they will have an exploded view that will show you how the parts are all supposed to go together...
I have installed a new blade in my circular saw R32021 and the blade stalls even before I begin to cut wood
by stalling do you mean that the blade stops spinning or the motor stops turning
if the blade stops spinning then the mounting bolt for the blade is not tight enough
if the motor stops spinning , junk it and get a new unit
Jan 20, 2017 | Blade Saws
The saw blade moves but stops when attempting to cut through even a small piece of wood.
You do not mention what say you have but did say it is a circular saw so I am assuming it is a hand help 5.5 inch cordless saw. Sounds as though you do not have the retainer nut tight our if it is you have the wrong blade on. The hole in the blade is too large. There is a knock out hole in the blade maybe that is gone? Maybe the washer on the retaining bold is missing.
This is a rather strange thing to happen. I would suggest you purchase another blade making sure it is made for your saw and try that.
Good luck.
Apr 20, 2016 | Ryobi Saws
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
Saw stops when i start cutting 1/2 plywood.
If it actually binds and stops the motor...... it sounds like the motor is bad, the bearings are bad, or the blade is on backwards. If the motor keeps spinning, but the blade stops then the gears are bad or the blade bolt is not tight.
Dec 10, 2012 | Worx Versacut Mini Circular Saw
I bought a ls1016 coupond mitre saw this week. I was cutting cedar 2x6 's today and had a few kick backs. I am building my deck and do not feel safe using the saw after the kick backs. Why as this...
Sounds as if the blade is dull. Or perhaps bent. A dull or bent blade blade will 'grab' the wood, rather than cut it, resulting in binding, or kickbacks.
Solution; replace the blade with a fine-toothed, good quality blade. If the blade is new, then check that the blade is bolted tight on the arbor. If the blade is loose, it can result in kickbacks.
Also, check that all the bolts/fasteners/locking mechanisms on the saw are tight, and in good working order. Sometimes a tool new out-of-the-box will have loose screws/nuts/bolts that need to be tightened up.
Also, when cutting, use a smooth, slow, motion, being sure to give the saw the time it needs to make the cut.
Jun 19, 2011 | Makita LS1016LX 10inch DualSlide Miter Saw...
I cannot loosen the bolt that holds the blade on my 7 1/4 Makita circular saw. How do I make the blade stop spinning to loosen it?
they make a blade holder now but usually if you hold the blade against a wood block real tight you can loosen the bold / screw . most warn against over tightening them
Sep 04, 2010 | Makita 18V LXT Circular Saw
I do not have a compound saw, just a regular Hitachi skill saw. Often when I'm cutting through wood, the blade will suddently stop with trigger depressed. I can back it up and it immediatly starts again....
I would suggest 2 things... first check that your blade is tight... and second make sure that your power supply is adequate...no long skinny cords or sharing outlets
Jun 10, 2010 | Hitachi C10FSH 10" Dual Bevel Slide...
When using saw the blade comes to a stop on its own thro wood
Does the motor continue to run? If so, the blade retaining bolt may not be tight enough. Most saws have a 'stop' pin which locks the drive during the blade tightening procedure. Make sure the blade is very sharp to reduce cutting effort. Hope this helps!
Feb 07, 2010 | Saws
I can't get the blade tight enough
If you tightened it enough and it still slips than it may be missing a spacer Try adding a washer to the arbor of the same size on the nut side of the blade.
Apr 16, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Need to change saw blade, lost instructions
1st, !!UNPLUG the saw!! Wear gloves to prevent nicks from contact with the saw blades.
If this is a handheld 'skill-saw' type saw, use a piece of wood to chock the saw blade from turning as you use a proper size socket/wrench to loosen the bolt which holds the blade.
The bolt will loosen counter-clock wise. It will probably be very tight, and you will have to use some effort to loosen it.
Remove the bolt, lift the follow guard and remove the blade.
Replace the blade with a like size diameter blade by raising the follow guard, inserting the blade, replacing the bolt, using a piece of wood to keep the blade from rotating and TIGHTEN the bolt. You will almost feel as if you need three hands to accomplish this procedure but its been done millions of successful times.
Good luck. :)
Mar 11, 2009 | Hand Tools
Ryobi 10 In Miter Saw With Laser Logo
202 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
