Question about Garden
Parts for a Master craft model #105112 sabre saw, is it possible to get parts still the part the holds in the blade with the screw cracked and I need to replace it?
  • 3 Answers
SOURCE: Jack's Poer Juicer model #CL0003AP
http://www.schooleyweb.com/sites/jacksjuicer/questions.php
I found this instruction on the web at the above site. Now, I just need to figure out the name of the part and maybe I can order a new one. Hope this helps everyone!
"See the back inside cover of the instruction manual for the spare parts order form or call 1-800-460-6210. You can also e-mail us at help@productsontv.tv "
Posted on Jan 07, 2008
  • 9 Answers
SOURCE: The starter rope on my echo chainsaw model CS 280E
i believe its a non servicable part and a replacement is required. its a simple swap out
Posted on Apr 22, 2009
  • 9 Answers
SOURCE: craftman sabre saw manual model 315-172100 or copy of original ok
Go to sears parts website and it guide you through to enter your part number and it will show you a parts diagram and how to order as well
Posted on Jun 14, 2009
Mike258
  • 1498 Answers
SOURCE: How do I replace the blade?
Hi rq,
Look at the base of the blade, there is either a half twist quick disconnect or an allen screw.
Safety first: Unplug the saw.
If its the allen screw it will be located to one side of the blade. Just loosen it , pull the blade out.
The half twist ring doesa what its name implies. Twist it as far as you can (holding the saw with the bladed to the ground allows it to drop out) to free the blade.
Best reqards
Mike
Posted on Sep 11, 2009
SOURCE: Rival Mfg. Co Food Slicer 1101E/7 - replacement screws
1101E part number for thumb nut 994-572, threaded shaft 995-254, blade 993-386, idler gear 348-077, washer 854-023, these are the Rival part numbers from the orginal owners manuel
Posted on Sep 12, 2009
I need a blade clamp for a model 105112 Mastercraft jig saw. Is there a substitute or universal clamp that fits?
Jig Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/jig-saw.html
  1. Cached
  2. Similar
Shop online for jig saw replacement parts for fourteen of the world's most trusted brands at Tool Parts Direct. We have the largest online inventory of Bosch jigsaw parts, Dewalt jigsaw parts, Black and Decker jigsaw parts, as well as replacement parts from other top manufacturers ...
mastercraft jig saw model 105112 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
  1. Cached
  2. Similar
Find solutions to your mastercraft jig saw model 105112 question. ... i need a parts list for a mastercraft jigsaw/sabre saw model 105-106 See this webpage: ...
Craftsman Jig Saw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-jig-saw-parts-c-158286_171667.html
  1. Cached
  2. Similar
Repair Parts Home Power Tool Parts Craftsman Parts Craftsman Jig Saw Parts. ... 07021 Craftsman Sabre Saw Parts. ... 315171600 Craftsman Sabre Saw 1/2 Inch Stroke Variable Speed Parts. 105112 Mastercraft jig saw Google Search
Nov 23, 2016 | Saws
How do we get the blade out
You need to provide more details like what type of tool, what model, whether or not the blade release lever is functioning, or if it an older model with a set screw holding the blade (pre-blade release lever). Provide photos (if possible).
I'm going to assume you are talking about a sawzall here.
If it is an older model with a set screw, then there will be a hole, or slot on the side near the blade.
First line up the set screw with the slot.
Insert the appropriate size Allen wrench into the set screw by going through the slot.
Turn the screw counter clockwise several turns until the blade will wiggle loose.
*Be careful not to take it all the way out. They are a pain to put back in sometimes.
If the blade doesn't start to wiggle after a few turns, then it might be a little rusted. It happens sometimes. Even when kept in the garage if you live in a humid area. Spray a minimal amount of penetrating oil into the blade Chuck near the base if the blade while holding the saw nose up. Be careful not to flood your saw with penetrating oil.
It's good practice to lubricate this part often with a dab of oil.
If you have a modern saw with a quick release lever, its near the nose of the saw on the side. Just pry it up. It shouldn't take much pressure. If it's hard to pull, then your blade Chuck is frozen. Do not try to force it. It can break your blade release lever (been there, done that).
To fix this, move your blade shaft to its longest position. Hold the saw like above nose up, and lubricate lightly. Prop it up, and let it sit for a while.
When you come back, bring a pair of small channel locks, or slip joint pliers. Give the blade slot another small squirt of penetrating oil. Wipe down the blade Chuck with a rag to get the excess, and then grab it with your pliers and twist it in the same direction as the spring slot is pointing. Always turn it towards the slot. It's like a convenient little arrow to guide you.
This should break the release loose freeing up your blade. Take it out, open it again and relubricate it.
Should you happen to break your release mechanism, well... Things just got tougher. Now ya gotta find some parts. That's a lesson for a different day.
Jun 30, 2015 | Saws
Need manual sabre saw model 900.272510
That's a discontinued Craftsman model.
If you need replacement parts, you'll probably find that parts are difficult to find and way overpriced from Sears.
I'd check into used saber saws on CraigsList.
I needed a blade hub for a worm drive saw for a Craftsman saw and they wanted $46 and it would have to be ordered. (Its a flanged spacer that has the diamond shape that fits in the diamond knock-out in the blade.) The exact same part was used on several other brands including Milwaukee, Hitachi and Bosch. I bought a Bosch one from a local tool store for under $7.
Oct 18, 2014 | Saws
Washers that hold blade in place
Go to eReplacementparts.com. Enter your make and model and find your part.
Sep 12, 2014 | Master Mechanic 13-Amp 7-1/4-Inch Circular...
Blade guard for power craft compound mitre saw WK 1200
Lows, Home Deport, Ace Hardware, Tractor Supply, Target, Wal-Mart. Kmart, about any major store. Harbor Fright. Etc.......
Jun 23, 2013 | Saws
I need the screw that hold the blade on the saw. its the model # cs185cf
Fixya does not sell replacement screws. Your saw probably uses a flanged cap screw with a standard thread.
Apr 07, 2013 | Kraft Tech Krafttech 12 Amp 7-1/4"...
We have a ryobi rj150v model reciprocating saw (older model) which needs the blade replaced. It had a broken part, which I ordered several years ago. My husband's FINALLY going to replace the blade,...
There are 2 types of clamps that hold the blade in that type of saw.
Since this is an older one it most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Ryobi Saws
Where can i find a sprocket assembly for a master craft electric
Master Craft became RemingtonPower
With a little work on your part (the correct model number) you can find an IPL here:
Remington.com
http://www.desaparts.com/index.htm
RemingtonPower is no longer producing anything. Replacement parts are limited to what is on hand and it appears have been exhausted. We are not affiliated with them in any way, and had nothing to do with their decision to end production. We like you are limited to an on line search for any parts.
If you decide to replace this I suggest you spend a bit more and purchase a name brand (McCulloch/Poulan, 8 electric models, some at Lowes). These companies are owned by Husqvarna and I expect all to continue providing great customer service for many years to come. HTH
Link to a Master Craft Owner’s Manual
http://lawnandgarden.manualsonline.com/manuals/mfg/mastercraft/10052401_cs120cb.html
What few parts are listed cross to RemingtonPower models LNT-2 and EL-7
Harbor Freight
http://www.harborfreight.com/manuals/38000-38999/38086.PDF HTH
Lou
Oct 24, 2009 | McCulloch Garden
My blade broke off in the lock of my craftman scrolling sabre saw and I can't get the part that is left inside out. Therefore I cannot put a new blade in. Is there a way to fix this?
Take off the clamp that holds the blade in place. Use a good degreaser (Electronics quality is best, it leaves no residue) and spray it into the blade holder. Next, blow it out with compressed air. The blade should be easily "bumped" out now. Oils & dust residue will hold the stub in, until you clean it out.
Oct 20, 2009 | Craftsman Saws
Garden Logo
228 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
