Question about Philips LX3900SA System
Hello, I have a home theater philips "lx3900sa",when I conect it to main supply,it goes to standby,(standby light on),when I push the standby button,then ventilator works about 10 seconds( nothing more works include the display),after that became standby . Every voltage in the power supply is correct( inthe standby mode,and ON mode).Can you help me about? Thanks Francisco Rodrigues
  • 1779 Answers
SOURCE: Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
Posted on Apr 11, 2008
SOURCE: Unlock Philips HTS-3565
Hi
TURN ON THE PLAYER
PRESS OPEN/CLOSE TO OPEN THE TRAY
WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL BE DISPLAYED.
PRESS "0" TO UNLOCK ALL
PRESS "OK"
Posted on Oct 06, 2008
  • 26 Answers
SOURCE: STANDBY LIGHT KEEPS BLINKING
Unplug the power cord, wait for 5 minutes, plug the power cord back in and try to operate the unit.
If this does not work, you will have to get a technician to look at it for you.
Please rate this solution - THANKS
Posted on Feb 28, 2009
  • 15 Answers
SOURCE: How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
Posted on Jun 02, 2009
SOURCE: I have a HTS3410D Home Theater system. I cannot
a blinking or pulsing power light usualy means a problem with the power supply. Check for burned resistors or swallen capacitors on the power board it will be the one with the one with the main power running to it.
Posted on Dec 29, 2009
RCA DVD home theater system RTD215 red standby light comes on but when you push button to turn on nothing happens and red light goes off. Checked fuse and it is good. Please help.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2016 | RCA Audio Players & Recorders
Model No. PWR2006-37. Where can I buy a power supply?
Before rushing off to buy a replacement power supply, open your sub and check for a blown fuse.
Sep 01, 2015 | Philips Hts3450 5.1 Channel Home Theater...
Main Board with 5v in short. How do I detect the failure component ?
Contact Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en They might have a fast answer for this.
Mar 22, 2015 | Philips HTR-5000 Theater System
Will not power on. The red standby light stays lit. The green light shows up for 2 seconds only when first plugged in and then goes back to red.
Solutions:
Check and Try
1. Pull out the flex cable attached power supply to AMP PCB. Check power ON of unit.
2. Pull out flex cable of the ROM
Check Power ON of unit
Probably AMP PCB doesn't work
Oct 05, 2013 | Philips Audio Players & Recorders
Hallo, here Andrea From Italy. Now o try to describe problem: On Philips LX3900SA when I turn on the console and turn off everything works. when I turn on the MRI works, but if I turn off from RM, the...
Since U are using a universal remote control, these are bound to happen. Please try another code using the same universal remote control or get the original one. Use the auto-search function for your device on your universal remote control. I think you first: 1. Hold the set key, then the power button 9a red light should be observed at this time on the remote control), 2. Release the buttons, and the light will start to blink at intervals (Make sure at this time, the remote is pointed to the device sensor,and monitor this closely). 3. Once it is able to put your device off, quickly press the set button. Then 'on' you go. Enjoy.
Apr 21, 2011 | Philips LX3900SA System
I am purchase last 4.5 years back Philips LX3900SA Home Theater System RS.18000.00 i am solve so many problem last 3 month having power supply go to service center his *** said me this problem not to...
if your completely against their products i wouldn't go for an x-ray anytime soon it's not plillips as much as just getting a lemon in a bunch of apples and if you got close to 5 years out a boxed-theater set-up i'd say you did ok learn from it and get a set-up more apt to fit what you felt that system lacked in the sound department i did ok in the local classifieds and built a system worth about 3000$ for under 750$ by finding pieces at budget deals and always checking user reviews for items i am going to purchase because 1000 opinions usually lead to find the good and bad points of a product hope this helps and sorry to hear your bad luck with your equipment
Nov 22, 2010 | Philips LX3900SA System
Nov 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Philips LX600
my decoder is not on when i give power supply
Sep 06, 2009 | Philips Home Cinema Amp + Speaker system...
NEW DVD DRIVE AS MINE DOES NOT WANT TO PLAY NO DVDS NO MORE, IT SPINS THEN STOPS THAN SPINS THEN STOPS THEN SAYS NO DICS!!! CLEANED MAGID EYE BUT STILL DONT WORK
run ur pc in safe mode and insert dvd disc and then use this around 2min and then start ur window normally and ur dvd drive working
May 07, 2009 | Philips LX3900SA System
Dec 26, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Philips LX3900SA System Logo
133 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
