Question about Sony HVR-V1U Mini DV Digital Camcorder
Neither my speed shutter or gain are working. My camera is not in auto lock or so. Can you help me? I have 7 cameras like this and it's not working in either one. Maybe I have some wrong settings
In the menu go to camera set > exposure/iris > dial assign > select "IRIS" I think it's stupid that this isn't the default setting.
Posted on Sep 12, 2011
  • yerblues Sep 12, 2011
    and hit the silver button above the iris wheel once to switch it to manual iris.
How to fix slow shutter speed?
When in Any auto mode or P or A your camera automatically will adjust your shutter speed for ambient light conditions. So if your having issues where your camera is choosing to slow a shutter speed and you photos are coming out blurry then there isn't enough light either because other settings in the camera are limiting light or where ever you are taking photos is poorly lit. Setting your ISO Higher should allow the camera to increase the shutter speed, but will often introduce noise to your photos. The more you play with your camera and learn digital photography the more you'll understand how to make your photos the best they possibly can be. For the time being if getting a no blurr shot is key put your camera in S mode which means shutter priority this will allow you to control and lock your shutter speed and set your ISO to auto this will force the ISO and Aperture to change instead of your shutter speed to get a good photo.
Jul 21, 2014 | Panasonic Lumix DMC-FZ30 Digital Camera
Why does my Nikon D60 while on auto focus or quick shutter speed either not focus and take the pic or focus and not take pics?
I have a 5D Mark II that has acted up like this. 99% of the time it will reset itself it you power off, remove the lense and allow them to sync up. Try this, it may work for you too!
Apr 22, 2012 | Nikon D60 Digital Camera with 18-55mm lens
Whenever I touch the operating button to meter, the "under-range LED" will not stop blinking. No shutter speeds illuminate, not even the one I have the shutter set to. The only LED's that...
Be sure your mode dial is not in the auto position. If it is, the camera will only function with the lense also locked to the auto position, which will either be the lowest aperture (highest number) or sometimes an "A" setting separate from the normal aperture settings. That's generally what this type of indication means on program/manual models - that you're trying to use manual settings, when the camera is set up for auto program exposure.
Sep 08, 2011 | Minolta X-700 35mm SLR Camera
Manual that came with camera does not explain symbols for setting the mode. Amazing! What do M, A,S,P, N and SP 1 and SP2 stand for? the only things I understand are Auto and Panorama.
M stands for 'Manual mode'. This is the mode wherein you set your shutter speed and aperture setting. A stands for 'Aperture Priority'. This is the mode where you set the aperture or opening of the lens and the camera sets the shutter speed. The lower the aperture number setting, the more light penetrates the lens, a faster shutter speed is needed. This setting is usually used for portrait scenarios. S stands for 'Shutter priority'. This is the mode where you set the shutter speed and the camera sets the aperture. The higher shutter speed number, the lower aperture number is set by the camera to accommodate more light into the lens. This setting is usually used for capturing moving objects like cars. P stands for 'Program Mode'. The camera takes care of different settings except for the aperture and the shutter speed. You get to choose combinations of aperture and shutter speed settings that will not change the exposure of your scene. This is like a combined 'A' and 'S' mode with different combinations. N stands for 'Natural Light'. The camera tries to make use of available light. This is ideal for indoor use when flash is prohibited or when you just want to capture the ambiance of the scene. The camera sets a high sensitivity setting to handle low light conditions. The drawback of this would be grainier pictures. SP1 and SP2 stand for Scene Position 1 and 2. This is like a memory setting for most commonly used scene settings. For example, you can assign SP1 for landscape mode scene and SP2 for night mode scene. You have 13 scenes to choose from in your camera, 2 of which you can assign in SP1 or SP2. The default setting for SP1 is Portrait mode and for SP2, it is Landscape mode.
Hope this helps.
Apr 15, 2011 | Fuji FinePix S1000FD Digital Camera
Hi, I've just recieved my nikon d90 back from a repair and service, and although everything appears to be working fine, whenever I want to change shooting modes,( auto, P, M, flash off etc), they only work...
I'm going to assume at this point that the camera has been serviced correctly. What I'd suggest is that you look in your manual and find where you can reset your camera back to the factory default settings. Okay here are a few thoughts that might be what is happening again I'm assuming the service was done correctly. In "Auto" mode the camera is in full control and what might be happening is the camera has selected a shutter speed many seconds long to achieve a correct exposure, most DSLR's will have a 30 second shutter speed. Also the mirror up function my be activated so first the mirror comes up then the shutter delay happens. The mirror lock up function on my fleet of digital cameras locks up every time I trip the shutter until I set the function to off. It'll really throw you off if the mirror lock up is activated, the camera is set for a time delay be this 5 or 10 seconds and then you have a long exposure on top of that, feels like forever before the picture is actually taken. By going into your setting or custom functions and setting the the camera back to factory default so bring you back to the setting the camera had when you first got it.
Dec 20, 2010 | Nikon D90 Digital Camera with 18-105mm...
Shutter speed on the auto mode of my s1000 camera seems slow. how can it be increased in the auto mode? This is a Fuji camera and by the time I press the shutter button subjects have moved. I have set the...
You need to press the shutter button half-way and allow the camera to lock in the focus before you press the rest of the way. This eliminates "shutter lag".
Dec 30, 2009 | Fuji FinePix S1000FD Digital Camera
Gain and shutter buttons doesn't work
look on page 33 of the manual.
or you can do this
in the menu
camera set > exposure/Iris > select "iris"
make sure the switch on the back is not on auto lock or hold
Dec 30, 2009 | Sony HVR-V1U Mini DV Digital Camcorder
Canon power shot s3is, picture quality is not good, we have use flash every time. otherwise images are very blurred and dull. what change i have to made to my camera. any suggestions will help full for me
If you can are turning the flash off and on, you are no longer in the "Auto" mode. Rotate the top selector dial to select the green "Auto" position. This will enable the camera to automatically select the best aperture and shutter speed based on the available lighting. It will also decide whether it needs flash or not.
As you gain confidence in your abilities, experiment with the other settings on the dial. May I suggest first trying the "P" program setting. This is similar to auto, but will enable you to turn off the flash during low-light level shots. Still the camera will select the best aperture and shutter speed based on the lighting. But in very low lighting, you may have to keep the camera extra steady (such as with a tripod) to minimize camera shake as the picture is taken.
Sep 27, 2009 | Canon PowerShot S3 IS Digital Camera
D300 long shutter delay
are you using mirror lock-up or live-view feature?
Jun 02, 2009 | Nikon D300 Body Only Digital Camera
Cannot manually adjust or access menu on Sony Dvcam DSR-PD170
you need to set the auto lock to centre position , and then you need to check the camcorder,if still it doesnt work then you need to take the camera to a good engineer for repairs
Jan 03, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony HVR-V1U Mini DV Digital Camcorder Logo
105 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
