Question about Sony PCMD50 (4096 MB 125 Hours) Handheld Digital Voice Recorder
Sony PCM-D50 Mu Sony PCM-D50 takes between 3 and 20 attempts to boot up. Once on, if the unit is left idle for more than 6 seconds, all the controls will freeze - it will not even switch off. The only way to prevent this freeze is to enter pause / record as soon as the unit comes to life. The hold switch is definitely off and the batteries are new. I suspect this is a software problem - is there any way to perform a hard or soft reset on the Sony PCM-D50?
  • gazgoldstar
    gazgoldstar Nov 24, 2012
    Hi, I am having exactly the same problem as you have described. Can't find answers anywhere and Sony have been unhelpful too. Have you had any joy since you posted this issue?
  • 566 Answers
SOURCE: sony ic recorder software download
Download Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000.
64 bit version operating systems are not supported,
Posted on Jul 28, 2009
SOURCE: digital voice recorder completely 'locked-up'
I have a sony IC recorder B600 and it has frozen up with err access. I have 4 hours of info that I need on this unit can I get it back and how
Posted on Oct 02, 2009
  • 12 Answers
SOURCE: Sony ICD-B500 recorder keeps flashing HOLD.
Look on the case. You'll see a button that slides. It takes it off of HOLD. HOLD mode is good to protect the recordings while the unit gets put in a pocket or purse.
Posted on Sep 17, 2010
Testimonial: "That was nice of someone to take the time to answer, altho I figured it out not long after I posted!"
  • 300 Answers
SOURCE: I have a sony icd bx800 I have recordings I need
Nothing to worry about.
Your recorder has what is called a "Flash Memory" 2 GB I believe, which will retain whatever you recorded pretty much indefinitely.
Posted on Jun 29, 2011
Testimonial: "Thanks this was very helpful! "
SOURCE: Sony PCM-D50 Mu Sony PCM-D50 takes between 3 and
i dont have a solution but this seems like the only way to contact a user. im experiencing the EXACT same problem right now with a pcm d50. Did you ever figure out what to do?
Posted on Feb 17, 2012
How do I fix my PCM-M10 Sony audio recorder? I haven't changed the batteries for a while and it looks like they are corroded. The recorder won't switch on. Is it fixable?
Carefully remove the batteries and remove the corrosion. Outdoor is better to reduce being exposed by breathing it in. After removing corrosion, add new batteries and try again.
Oct 03, 2015 | Sony Pcm-d50 Portable Linear Pcm Recorder
Code p0506 on a 03 grandmarquis battery light comes on and stalls.
Does yours have electronic throttle control ?
P0506 - Idle Air Control System RPM Lower Than Expected (Electronic Throttle Control [ETC] Vehicles) The PCM attempts to control engine speed during KOER self-test. The test fails when the desired rpm could not be reached or controlled during the self-test.
  • Air intake restriction
  • Exhaust restriction
  • Engine mechanical fault
  • Damaged electronic throttle body (ETB)
  • Damaged PCM
This DTC is informational only and it may be accompanied by other DTCs. Diagnose other DTCs first. If other DTCs are not present inspect the intake air system for air or vacuum leaks and damage. If no concerns are present, clear the DTC and retest. P0506 - Idle Air Control System RPM Lower Than Expected (All Others) The PCM attempts to control engine speed during KOER self-test. The test fails when the desired rpm could not be reached or controlled during the self-test.
  • IAC circuit shorted to PWR
  • VPWR to IAC solenoid open
  • IAC circuit open
  • Damaged IAC valve
  • Damaged PCM
  • Air inlet is plugged
The IAC solenoid resistance is from 6 to 13 ohms. Monitor IAC PID duty cycle and/or voltage.
Jun 21, 2015 | Cars & Trucks
Sony pcm d50
I also have had the exact problem with my PCM D 50`s (I have 20 machines because I teach radio journalism). 8 of my D 50`s are not working. They don´t start, freezes and nothing helps. I´ve been in contact with Sony and they say it´s a problem with "the power board". What´s the problem, they will not tell. It would cost me about 300 dollars to fix the problem. Instead I´ve bought new Sony M 10 for less money. They work just fine.
Dec 13, 2013 | Sony PCMD50 (4096 MB 125 Hours) Handheld...
Pcm d50 common trouble
best solution is to contact sony advise try an dget a replacement
Jul 26, 2012 | Sony PCM-D50 Handheld 24/96 Recorder
Sony PCM-D50 Mu Sony PCM-D50 takes between 3 and 20 attempts to boot up. Once on, if the unit is left idle for more than 6 seconds, all the controls will freeze - it will not even switch off. The only way...
Apr 29, 2011 | Sony PCMD50 (4096 MB 125 Hours) Handheld...
I have Grand Cherokee 1999 V8 4.7 220700 mphproblem: obd Give P 0505 1. Start good rbm at 750 as it heat rbm go up till 1500 2. When the heat come to middle oil pump fall down for a second and come...
P0505 - Idle Air Control System Malfunction The PCM attempts to control engine speed during KOER self-test. The test fails when the desired rpm could not be reached or controlled during the self-test. IAC circuit open
Damaged IAC valve
Damaged PCM
Check it.
Jul 02, 2010 | 1991 Jeep Cherokee Briarwood
Screen going blank on system boot and on switch off/on
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a fraction of seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 08, 2010 | Sony SDM-HS75 17" LCD Monitor
2004 dodge stratus will not idle after battery change
Low voltage during engine start means there might not be enough electrical poop to actually accomplish all steps as commanded, which is where the problem arises. Once lost, the PCM will believe the IAC to be in a much farther open position than it actually is, so it sees no need to open further. Start-stall or no-start episodes follow
This would be a good time to reset your IAC step count. It can be done with a battery disconnect of about 30 seconds, which will occur automatically if you happen to replace the battery.
Roll the key on and wait 5 seconds before starting the engine. This gives the PCM time to relearn IAC step count without the complication of trying to keep the engine running. After five seconds, go ahead and crank the engine. It should start, flare and settle to a nice idle if the IAC motor and controls are in good shape. While it's rare for an IAC motor to give this type of trouble in my experience, your unit may be 6 years old now... and they do wear out. If the reset prodecure is ineffective... or it works for a little while and reverts to stalling... you may have a bad IAC motor. It's the 4-wire device on the back side of your throttle body, removed with a #25 Torx driver. Perform a relearn after installation.
If not effective, you need to clean the throttle body. I'd expect it to start and idle regardless of TB deposits, but cleaning deposit buildup from the throttle body blades and bore will restore minimum airflow lost over time and will help support idle control. Minimum airflow is basically a safety net for the idle system... something that supplies up to 70% of the air needed for idle control to take some of the load off the IAC controls.
Good luck and keep me posted if your still having problems.
Feb 22, 2010 | 2004 Dodge Stratus
Start up problems with Sony Vaio VGN-A517S
remove your screen saver program form computer.go to control panel in settigns u se dispaly open it then set desktop as win xp.
Feb 03, 2009 | Sony VAIO PCV-J200 PC Desktop
Printing issue
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
Sep 24, 2008 | Minolta magicolor 3100 Laser Printer
Sony PCMD50 (4096 MB 125 Hours) Handheld Digital Voice Recorder Logo
90 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
