Question about Dryers
Thermalfuse in whirlpool duet electric dryer blows every few months - what is causing this? Had servive 4 times inlast 10 months - keep replacing the thermalfuse and also shortened the vent hose for better airflow - still continues to happen
  • Dryers Master
  • 7,482 Answers
Hi miralou
Check for lint buildup and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is blowing out a good stream of air.
If you are running too hot you are not moving enough air thru the system and it will normally blow the thermostat/thermistor.
Check to see:
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted impeading the air flow.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Free Answer...Please take time to rate me.
Posted on May 26, 2011
Why does my whirlpool duet dryer door keep popping open? After a few minutes, the top latch of the dryer pops open and the dryer stops. Visual inspection of the dryer yields no issues. The door has...
The latch is shot I would replace both top and bottom. Most of the time all you need is a needle nose plier to perform the task. There are some good tutorials online that walk you through the steps. The actual latches a fairly inexpensive and you should be able to find them from a supply store that specifies in home appliance repair.
Jul 28, 2014 | Whirlpool WED9400S Electric Dryer
Hi, the dryer keeps stopping (the timer jumps), only runs for about 10 mins at a time AND the part that worries me the most is that I haven't had to empty the lint trap which I usually do after e
sounds like the vent tubing is not hooked up as it should be and that can cause a lot of lint buildup inside of the dryer parts. take it apart again and clean out all of the lint because this is a fire hazard. make sure that the vent is connected to the lint trap and try working it again. it sounds like maybe the buildup of lint is making the drying hard to do.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
The dryer keeps stopping (the timer skips from 50 mins to 10 mins in secs) AND what worries me the most is, I haven't needed to empty the lint trap.
Well, well.
Am I to understand the timer dial is going really fast as you watch it?
I didn't know that was possible, but maybe the wiring has been compromised (shorted out) somehow. If so, you would need to take it all back apart and look for a wire that is pinched or incorrectly hooked up. Some Whirlpool dryers have numbers on the back of the timer that are supposed to match numbers that are actually printed on the wires themselves.
As far as the lint trap, perhaps one of the "pipes" inside the dryer is unhooked or loose causing the hot air to miss the screen.
Be blessed.
some were he has blocked the out let for lint trap the reason its stopping is its over heating don't use untill sorted it will cause a fire if left
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Whirlpool duet gas dryer. was working fine now all light and time amount work but will not start and beeps 3 times
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirpool duet dryer
Press/hold start for 5-10 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 12, 2009 | Whirlpool GEW9250 Electric Dryer
I HAVE A WHIRLPOOL DUET GAS DRYER MODEL NO. GGW9250PL0 THAT KEEPS BEEPING EVERY FEW SECONDS AND THE DIGITAL MINUTE DISPLAY IS ERRATICALLY CHANGING THE NUMBER OF MINUTES WHEN TRYING TO SELECT DRYER SETTING....
We had the same problem. Sometimes unplugging it for a few days, it would work when plugged back in. We replaced the user interface which is part #19 on the Whirlpool parts list, the front circuit board. The part alone was $160 at the cheapest place we found. http://www.appliancepartspros.com/
Dec 11, 2008 | Whirlpool GEW9250 Electric Dryer
Duet blowing breaker
the heating element is probably broken and shorting out, causing no heat and blowing the breaker. if you are mechanically/electrically inclined then take off the top and take a look, it should be obvious. if not, then you need to have a proffessional look at it.
May 27, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
