Television switch does not bring set on immediately...set comes on some time later.surprising everyone.What is the problem?
  • 927 Answers
Good Day, faymirurhead;
Slow to come on can be caused by several things. If you have a DLP or LCD rear projection the LAMP may be getting weak. Also, make sure is plugged into an a/coutlet directly and not a cable/sat. box.
I hope this was helpful, big IRISH.
Posted on Aug 16, 2008
Da pic. Just disappeared
Replace da set! (It be old!) ;)
Seriously, you could invest a great deal of time and money in diagnosis and parts and have something else on a set that old simply fail immediately. Better off replacing it with a later LCD or LED set for a few hundred dollars.
May 12, 2015 | Toshiba 65H83 65" Rear Projection...
My question is on my acura mdx 2003. The left front wheel was worked on and somehow the mechanic damaged the sensor there. I guess the abs sensor. This made the ABS, VSA,VTM-4 and a triangle light came on....
When you clear the codes and the problem has not been fix after 10 miles of driving the warnings return. I am sorry but I am not sure what is causing the indicator lights. Have you looked up all the remaining codes?
May 02, 2017 | 2003 Acura MDX
Power supply isn't working
dOES SET COME ON WITH POWER LIGHT ON AND A FEW SECONDS LATER SHUTS OFF?
WHEN it turns off press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both.
watch for power light to blink a two digit error code like 1 blink, 2 blinks and then pause and repeat the code for about 5 times .
Let me know what code you find .
Dec 21, 2012 | Mitsubishi VS-70707 70" Rear Projection...
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
TURNS ON, IMMEDIATELY TURNS OFF
Most common is convergence chips problem.
Apr 19, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Hooked up cables cant get video or audio
Make sure that your pluged into the proper inputs on the rear of the television. Double check them... (I've done this before too).
If you are sure the inputs are ok then make sure that your television is set to the proper input. Toggle the button on your television remote (input - source - device) for your input. Everyone is labled a bit differently.
This should bring up your dvd player when you reach the correct input.
Jan 23, 2009 | Samsung DVD-R130 DVD Recorder
My Emerson flat screen
If it's like mine, you would have to keep replacing the inverter transformer. It's a junk part that everyone is having a common problem. The repair shop may have replaced the bad one, but that doesn't mean the others will go bad later. I have a 32" that uses 6 inverter transformers.
Dec 28, 2008 | Emerson EWL3706 37 in. LCD Television
Tv won't come on
Typical reset sequence is: unplug the set, press the power button a few times ( Yes, with the set unplugged ). Then, hold the power button down and at the same time ( maybe with your other hand ) plug the set in. If that doesn't do it, there may be a button marked reset on the back of the set. If there was a lightning strike nearby, your set is probably toast. The antenna or cable brings it into the house.
Dec 26, 2008 | RCA R52WH76 Television
Dell W2600 LCD will not power up
Hi everyone!
Most of the time Dell W2600 has Control Module issues.
I do have them in stock.
Please feel free to contact me at plasmatech@gmail.com
Oct 18, 2008 | Dell W2600 26 in. LCD Television
Whine-no picture-audio only,1 channel
bring up the menu screen the tv and auto program the channels this lock out all un wanted and only allow the rf tuner input channel from the box if your using rf cable hook up,if not un plug the unit for 1 min. and try it again.
Dec 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
