Question about Sony Cyber-shot DSC-W50 Digital Camera
My pictures come out with a yellow color - Sony Cyber-shot DSC-W50 Digital Camera
    Master:
  • 340 Answers
It's seems you should set the White balance to Auto WB Learn more camera tips
Posted on May 26, 2011
  • kathy_enna May 26, 2011
    that is not the problem did nothing to help
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
My tv sceen has a stain that makes anything white look yellow.
The color image is comprised of three colors, Red, Green, and Blue.
All the other colors are mixtures of those colors. The yellow picture indicates that your set is lacking sufficient blue drive.
First of all check to make sure that the tint control is not misadjusted.
The next thing is dependent upon the age of your television. If it's an older set that yellow tint is a sign of an aging picture tube.
If it's a newer set, less than 5 years old, have it analyzed by a electronics technician that is familiar with televisions if he is skilled enough he will know right away if it's the picture tube or not.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Only prints in yellow color
The printer must be able print all colors in order to execute the alignment. Part of the alignment process involves scanning printed colored (all colors including yellow) bars. See the web page below for a sample of the printout. I suggest that you clean the carriage and cartridge electrical contacts with a cotton swab moistened with water. If you still fail to get yellow, test the cartridge in another printer. ping me for the make of printer, anyways if it an HP series refer to the website below
http://h20015.www2.hp.com/en/document.jhtml?lc=en&docName=bpu00657
May 01, 2009 | Computers & Internet
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
You are missing either red drive signal to CRT or you have a cold / fractured solder joint on the television. Also with the set unplugged check with a non metalic object like a ruler or a wooden spoon and start tapping around in the front or back of set and see what happens. See if you can narrow which area of the set has a problem... Good luck future technician.. Happy holidays.. Jay
Dec 08, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Yellow haze
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 23, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow Haze Center Screen
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow pictures
If it is in proper colors in daylight, It has to be no FLASH, or a bad CD.
I assume both video and STILL pictures are the same.
Did you ever get good pictures??
colors can be SHIFTED in most DIGITAL photo programs, your pictures may be saved (able).
David
Dec 26, 2007 | Jazz DV-179 Digital Camera
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
YThe colors in my picture have yellow/green color cast.
When you take pictures under certain artificial lighting conditions- such as fluorescent, incandescent, or halogen lighting, the colors in your image may take on a yellow or green cast. You can use HotShots to touch-up the colors; see Chapter 7 for instructions.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
24 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
