Question about Whirlpool Duet GHW9150P Front Load Washer
I have a front loader Duet W10254043A washing machine. In the spin cyle the machine started humming and did not spin out the clothes. F 27 was showing on the display. What does this mean?
  • 67 Answers
SOURCE: duet Washing Machine spin cycle is spinning slow
make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Posted on Mar 20, 2007
  • 19 Answers
SOURCE: Whirlpool Duet Washer won't spin
Sounds like the whirling noise is the pump, pumping. Does it drain at all? Check the drive belt and make sure that it is not broken. This system uses a drive belt with a clutch system to agitate back and forth. The clutch system could be bad as well.
This might not be a cheap fix, these are the main components of the system
Posted on Mar 15, 2009
  • 1294 Answers
SOURCE: i have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Posted on Apr 08, 2009
  • 111 Answers
SOURCE: Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
Posted on May 21, 2009
rylee_smith
  • 8619 Answers
SOURCE: My whirlpool duet keeps displaying F35 and will
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed, there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 19, 2009
My Frigidaire gallery front loader series model GLTF2940FSO stopped working during quick load - water still in machine, started making buzzing/humming sound but wouldn't drain or finish cyle. Unplugg
Sounds like a bad start capacitor in your drive motor. Not expensive to fix, but you have to know what you're doing. If you're not handy at that sort of thing, I'd suggest a handyman who fixes washers.
Dec 31, 2014 | Frigidaire Washing Machines
I bought the Whirlpool Duet to replace my old standard washer & dryer and I find that the wash time is longer than the old washer. Even the quick wash takes about 1 hour. Am I doing something wrong...
I assume from your comment that your old washer was a top loader. Yes, front loading machines typically have longer cycle times than top loaders. There are several contibuting factors... first of all, the wash action of a front load is to oscillate the drum back and forth as well as provide a slow tumbling motion whereas a top loader w/ agitator or impeller has a more aggressive action. The more aggressive action rolls and tumbles your clothes more often and therefore cleans faster. Also, because front loaders spin very fast (up to twice as fast as top loaders) to reduce the amount of moisture left in the clothes, they need to have balanced loads. They accomplish this by testing and rebalancing your load several times during each cycle before beginning to spin.
That was a long answer to your question- no, you are not doing anything wrong.
Good luck.
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle very loud and makes a humming noise when finishing the cyle
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Maytag Washing Machines
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin cyle problem
it sounds like you have a blockage some were around your pump best thing to do is try and unblock it
Jun 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW8400TB leaking and not spinning
Send it back and get yourself a nice top loader w/o digital settings. The front loaders look good and all but i see so many unhappy post about them I myself will wash in a bucket before accepting on of the front loads free.
Apr 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Allergic to detergent for front loaders
I have always used regular Tide powder in mine and my kids use Tide liquid in it. You just need to use about half as much. My man is a motor head so he gets DIRTY and I have three teens so I wash a lot of very dirty clothes. My clothes get very clean and I have never purchased the "special" Detergent.
I have had my Duet for three years.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
151 people viewed this question
Dan Webster
Dan Webster
Sal De
