Question about Tascam CC-222mkIII CD Player / Recorder
Out put need to know where to put the wiers in
    Brigadier General:
  • 8,546 Answers
The obvious answer is - according to the manual and where they fit. OUTs go to INs.
http://tascam.com/product/cc-222mkiii/downloads/
http://tascam.com/content/downloads/products/342/CC-222MK3_manual.pdf
This unit supports just about every audio source including PHONO. THAT is ONLY FOR A TURNTABLE.
http://tascam.com/product/cc-222mkiii/specifications/
http://tascam.com/content/images/universal/product_detail/342/large/cc222mkIII-rear.jpg
Posted on May 26, 2011
How many wieres go to the starter on a 1995 lincon town car
the small wire attaches to the small solenoid lug and the two large battery cables in red connect to the one large stud on the solenoid
Aug 23, 2012 | Lincoln Town Car Cars & Trucks
Got a problems with the lights on my kawasaki kmx 125 i put a new bartery on it and a new relay and the light still wont work if you put a wier from the relay to batery and they work but if you pull off ...
Check if the fuse is blown. You can check if the fuse is blown either by visual inspection or continuity test. If the fuse is blown then replace it with new one and you are ready to go.
Mar 02, 2011 | 2002 kawasaki KMX 125
Bought new heat sequencer ,took old one of so i would know what to get did not note position of wiers need to know how to reconect wiers
one of the larger set of wires is your heater element common. the other one goes to the common to the sequencer line side. the control wires are smaller. one is common to the coil(s) the others go to the timers that kick in the elements one at a time for heat as it is desired.
Oct 19, 2009 | Heating & Cooling
How do you wier up a bench grinder
I would suggest (just from you saying you dont know wireing that well) you should have someone else do it. But if you are determined white to white black to black(or red) make sure you are grounded and check amp to make sure you have the right breaker. I think you should get someone to help you as electrical fires are #1 on home fires .
I hope I helped
Oct 02, 2009 | Clarke Power Products Grinders
Gauges wont work,horn keeps blowing
you have a crots wier or bar wiers in the wiering to solve this you ned to
track the wiers amd put eletrikel tap arond war it is bar or put the wiers in the rit plas
Sep 12, 2009 | 1996 Dodge Caravan
1993 buick park avenue ignition spark issue.....my car will not fire on the lowest coil in the coil pack. i have changed the coils and also moved them around to ensure not a faulty coil. i just put an...
the problem has to be wireing.checking with an ohm meter will not tell you for sure how much current the wier will carry so you need need to find where it starts and ends and disconnect bothe ends.put a jumper to ground in one end then hook a test light to your positive battery terminal,put in the other end of the harness and see if the light is bright or dim.
Jul 30, 2009 | 1993 Buick Park Avenue
Changed plugs wier roter and cap still number 3 plug misfires
Well i would double check the plug we all know these are a pain in the **** to put plugs in it possible that one got cracked. Also have you ever replaced the intake gaskets ? or any fuel in jection parts ? regulator or popets/injectors
Jan 18, 2009 | 1997 GMC Jimmy
Alternator not charging
Hi
If you have a volt meter, set it to volts and hold the negative probe to the alternator body and the positive to the battery positive. If you don't get battery voltage then the alternator isn't grounded and the probable cause is the main engine ground cable either breaking or coming loose.
Very best regards
Geordie
Jun 10, 2008 | 1982 Ford F 150
Tascam CC-222mkIII CD Player / Recorder Logo
85 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
