Question about Craftsman Garden
I have craftman lawn mower it has honda motor gcv160. i had old fuel in the tank now i try to start my lawn mower but doesn't start. i changed sparkplug but didn't work. then i had to clean the carburetor. i cleaned it and put it back but provlem is now fuel leaking from air filter. what did i do wrong. please help me
  • Craftsman Master
  • 7,482 Answers
Hi islamamin200..
You have a problem with the inlet float, there is something holding it from closing totally.
When you cleaned the carburetor did you clean it with a cleaning solution such as lacquer thinner, this is used to cut the "varnish" buildup in the jets and needle valves of the carburetor.
Follow the directions below:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 26, 2011
    Guru:
  • 479 Answers
If the carburettor has a float bowl, remove it and check that the float is cutting off the fuel supply when it is pushed upwards. If it doesn't, there may be some dirt or other obstruction preventing the valve from sealing allowing the float bowl to overflow into the intake of the carburettor.
Hi I have a brand new Victa Mustang with the Honda GCV160 4 stroke. Hve fuelled up, added oil, turned on fuel tap but it won't start. Any ideas?
Has it been sitting? Has the gas been sitting? I'm sure the carb is all clogged and gummed up with stale gas and dried ethanol. Buy a new carb, GCV160 carbs are like $20 shipped on eBay.
Dec 09, 2014 | Honda Garden
How to remove silver cover on front of motor
Either the blade is loose, or the flywheel key has sheared.
Aug 24, 2013 | Husqvarna 21" Lawn Mower with Honda GCV160...
Lawn mower starts dies
Try running it with a loose fuel cap. If it runs fine the fuel tank vent is plugged. Some mowers have a little hole in the fuel cap that gets plogged up.Use a pin to clean it out.
May 29, 2013 | Husqvarna 7021P 21-Inch 160cc Honda GCV160...
Honda gcv160 governer problem
try looking at anotherone and look at the long wire cord maybe u took the carb off and didnt put it in the right hole..or forgot to put the spring on or have that in the wrong place the honda carbs suck it goes in and out when the carb is faulty..check the carb get it rebuilt or just change the pin on the float..
Nov 18, 2012 | Husqvarna 21" Lawn Mower with Honda GCV160...
Have a 4.0 quattro Briggs and Stratton lawn mower. Starts up great and doesn't stall out. Has this annoying surge and slow down of motor. Removed gas from tank and sprayed some gum remover in tank and...
it does sound like a carb issue it may need to be rebuilt also check your fuel line and if you have a fuel filter check the filter clean the gov. assembly with carb cleaner
Jul 30, 2012 | Garden
I have a craftmans riding mower I replaced the solenoid and the carb but when the mower has been shut off for a couple of days the fuel drains out of it what could be wrong
Depending how old it is...the rubber hoses on most lawn equipment is prone to going cracking and leaking. I'd start with checking fuel lines coming from the fuel tank to the engine first, see if they show any signs of wear or leakage.
Jul 15, 2012 | Craftsman Garden
Need a Honda GCV160 mower owner op-manual
You will need to know your serial number. They are free to download, but if you want to order a paper copy, you have to pay for it. Hope this helps and please don't forget to rate!
http://engines.honda.com/parts-and-support/owners-manuals/GCV160
Jun 24, 2012 | Garden
My neighbor has a Honda Yard-Man GCV160 lawn mower. She says it takes an oil and gas mix for the gas tank, but it also has a seperate tank for oil only. What fuel powers it?
Hi, it uses unleaded fuel with no oil. It will need the sparkplug cleaning if they have been mixing oil with the fuel. Hope this helps, regards Phil.
Jul 12, 2011 | Garden
Garden Logo
199 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
