Question about Kitchen Ranges
Put on 1min - starts and stops after a second. Moved micro about month ago and put it back - works okay. Fautly again to day - moved it - connected and it works. Ready to move back to place and tested and stops again. Could it be something wrong with lead in. Its an old national - tell me how to take back off and see if there is a connection loose????
  • Anonymous Mar 26, 2014
    I rewired the power lead, so it is not the cord. I had this problem a few days ago and unplugged it and then tried again and it worked. There is no power going through it.
  • Kitchen Ranges Master
  • 43,501 Answers
Yes.... your outlet is no good...when the Micro starts to use more power the plug to outlet connection heats up a bit and the contact is momentarily broken...then it goes back on as soon as the power usage is stopped...
Replace the outlet that you are plugging the microwave into and your problem will be solved...
heatman101
Posted on May 26, 2011
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
2000 Dodge Stratus SE stalling and not restarting
Sounds like a broken wire probably close to where the computer is. I would inspect the harness here and then under and around the power distribution module (fuse and relay box under the hood) This can be removed for closer inspection of the contacts underneath.
Check all sensor connections especially the crank
Pull the MAP sensor plug connector out and try to start the car, if it starts and runs rough and then wont when the map is plugged in then replace it and you are a go.
I think this is your problem or fuel pump or the fuel pump wire is corroded typically where it connects to the harness and then goes into the body.
This is somewhere to start at least.
Sep 23, 2012 | Dodge Cars & Trucks
1996 impala ss (TRUE SS)
It could have a dead solenoid or a blockage in the valve body.
Sep 22, 2012 | Cars & Trucks
Ethernet plug stopped working.
yes from its a desktop it can be replaced
Aug 29, 2012 | Dell OptiPlex 210L PC Desktop
Freezer comes off and on.
try leaving it uplugged for at least 6 hours after it has been moved in order for the oil and gas to seperate and settle. Then it should work okay
Dec 28, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Nissan pulsar n13 fautly water temp gauge
Switch ig. on, ground the sender unit wire for about 3 seconds see if the temp. gauge moves, if so change sender unit, if not then it is a faulty gauge reader.also check instrument voltage stabilizer.
Dec 23, 2008 | 1988 Nissan Pulsar
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
